Wheel builders : another spoke length question
Quoted: 12 Post(s)
Liked 42 Times
question for you experienced wheel builders. i'm building my first wheelset from scratch. i plugged in the numbers for dura-ace 7400 freewheel hubs + pacenti brevet 650b rims
front spokes : 280.5mm
rear spokes : 279.5mm left / 278mm driveside
do you think it's ok to use an average length for all spokes involved? either all 279mm or all 280mm ?
i read there's 1 to 2 mm of spoke length leeway and wondered for simplicity / cost savings if it makes sense to build around one spoke length in this instance ?
thanks for your feedback !
Quoted: 2685 Post(s)
Liked 1,729 Times
280 and 278.
the difference in the rear wheel makes building easier once you take a spike wrench to it.
Likes For repechage:
Quoted: 1575 Post(s)
Liked 1,259 Times
If I had the spokes on hand, I would try it. If you are buying spokes, get as close as you can to the calculated value.
edit: first build: buy correct spokes and round up not down.
Likes For Classtime:
Mad bike riding scientist
Quoted: 5388 Post(s)
Liked 2,982 Times
If you can get the proper sized spokes, go with the 278mm for the drive side and 280mm everywhere else. If you can’t find 278mm spokes, 280s will work but they aren’t optimal
Stuart Black
Stuart Black
señor miembro
Quoted: 2938 Post(s)
Liked 4,238 Times
I'm not sure I buy that simplicity is a benefit, although you certainly don't have to worry about which stack to pull from when you're building the rear. But I have to ask, is it really a cost savings? How so? How much?
Bikes: A bunch of old bikes.
Quoted: 201 Post(s)
Liked 555 Times
For me, it seems easier with different length spokes on the rear hubs. I think it's easier to start the correct dish that way.
Likes For daverup:
You can get longer nipples to accommodate slightly short spokes but that is obviously not the optimal solution. Use the correct length to start with and like was said before, always round up. ALWAYS.
Likes For brooklyn_bike:
Bikes: '38 Schwinn New World, '72 Peugeot PX-10, ‘7? Valgan, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ’97 Cannondale T900, '98 Peugeot Appalaches, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Herc
Quoted: 545 Post(s)
Liked 970 Times
As a fairly recent initiate to wheelbuilding (I've built up 5 wheelsets now, over the past year), I'd echo what others have said about having as close to the 'right' length spokes, especially for your first couple builds. Being able to use a nipple driver is super handy to quickly get a somewhat even tension (all around for the front, per-side for rear/dished). I think after you've built a few sets of wheels and developed a feel (& sense of confidence) having exactly 'right' spoke lengths becomes somewhat less important.
Likes For ehcoplex:
Stop reading my posts!
Quoted: 1176 Post(s)
Liked 718 Times
I have built a number of wheels and typically check with about 6 different spoke-length calculation tools before I order spokes. I find even with averaging the many results it's safer to round DOWN about 1mm.
And "longer nipples" may be longer in their OA external dimension (which can be important when you build with something like "deep V" rims) but the length of threading is usually the same between externally "short" and "long" spoke nipples.
Check some examples for yourself and see.
YMMV but I hate it when I have finished building to discover the spokes were too long to tension and have to re-order and start over. The guys I buy spokes/nipples from don't take them back.
Likes For unworthy1:
I disagree, but to each his/her own since YMMV.
Check some examples for yourself and see..
ambulatory senior
Quoted: 1683 Post(s)
Liked 2,468 Times
I'd say getting proper length for each side is the way to go but when I can get a better price buying a pack of 100 I will use all the same length. It's not kosher but it isn't hard to dish and true the wheels.
Likes For 52telecaster:
Bikes: 1981 Lotus Classique + 1986 Bianchi Sport SX + 1980 Dawes Super Galaxy + 2021 Zizzo Liberté
Quoted: 111 Post(s)
Liked 256 Times
Sorry for piggybacking but I've been shopping around for spokes to build my first complete wheel (have done a couple of full drive side replacements) and what the hay is up with prices here in the US? I actually ordered Sapim spokes from bike24 in Germany the last time but won't do that again, as it took forever and the first shipment arrived incomplete due to inadequate packaging.
So I was really psyched to find Wheel Master non-butted 2.0 at 27 cents each including nipples, at Carson City Bike Shop--only to get an "item can't be shipped to your location" error in my shopping cart. They acknowledged it's a glitch in their database and are working with their provider to fix it.
Liked 1,729 Times
I like them filled with the spoke.
sure, plenty of wheels get built or were built decades ago, I have a bike that the original wheels were built with spokes 2-3 mm too short.
I took them apart and will rebuild with longer.
308 vs 305, high flange 36, 4x as originsl.
not my fav, but the holes in the hub are "set"
Quoted: 545 Post(s)
Liked 970 Times
Likes For ehcoplex:
Quoted: 111 Post(s)
Liked 256 Times
I may end up doing that but I was very pleased they responded to my issue (which I submitted through the website's contact form) right away, on a Saturday. Yes, the website is terrible--every spoke in every length is a separate entry, and no way to filter. Typing the mm length into the search box seems like the least aggravating way to drill down.
Likes For EVlove:
ambulatory senior
Liked 2,468 Times
I do not like unsupported nipples at the end.
So I guess it depends on the spokes?
Ride, Wrench, Swap, Race
Quoted: 1363 Post(s)
Liked 924 Times
Whenever I am expecting a selected length of spoke to be to the long side of calculated-perfect, I will forcibly pre-fit every spoke nipple to every affected spoke before assembling the wheel, using grease in the nipple threads and on the spoke threads. A bit of back-and-forth with the spoke wrench frees up the threaded interface nicely.
I find that when the spoke protrudes well above the head that the threads start to bind, but I force them past this point several turns, as this will make it much, much easier to turn the nipples (without twisting the spokes) later when the wheel has been put together.
Sure, there is some loss of threaded engagement from the un-threaded portion of the spoke reaching a mm or two into the nipple threads, but this literally never presents as a problem if the nipple can be turned freely enough to achieve tension.
All of the pre-greasing and pre-threading makes for an easy time achieving max spoke tensions on any spokes that are slightly long, and one will never have the heads breaking off of the nipples unless perhaps corrosive tire sealant ends up inside of the internal rim cavity.
Alternately, I have used a drill with a piece of tubing as a drill-stop to pre-drill every affected spoke nipple to a depth of perhaps a couple of millimeters into the nipple threads, again no problems building the wheel with too-long spokes, and no long-term reliability problems with nipples/threads.
Likes For dddd:
