Arai Drum brake help
Hi all
There seems to be a lot of knowledge here, so I hope I'll be able to find a solution to my problem.
I have a Dawes tandem with an Arai drum brake. For all of my efforts I just cant get the wheel in the bike without the backing plate going out of adjustment. I have found various 'how-to' guides and have applied the brakes whilst tightening the lock-nut, but when I do the axle nuts up it causes the shoes to bind and scrape on the drum.
If any of that makes sense, I would be forever in your debt if someone has a workaround to stop this from happening.
I appreciate any help you may be able to provide.
Regards
Flipper71
Regards
Flipper71
Hi Rick, thank you for your reply. I'm not sure pics would help When I put the backing plate on there is a tiny gap around the hole, so after tightening the locknut (and applying the brake to centralize the shoes) the wheel spins freely, but after putting the wheel into the frames and tightening the wheel nuts it then starts to catch on the drum. Its almost like the backing plate is moving a minute amount, but just enough to cause the rubbing. It's to the point the wheel just doesn't spin freely. I have taken the wheel off about 10 times now and corrected it, but I just don't seem to be able to do anything with it to stop it from happening.
Bikes: 2000 Santana Sovereign SE; 2005 Co-Motion Speedster; Kona Kilauea with various dorky commuter accoutrements; Mercier Kilo TT fixie; Burley Fladbed trailer for groceries, bags of cement and the like.
Quoted: 95 Post(s)
Liked 85 Times
Flipper71: Please review this PDF and then describe the problem again.
A bunch of us here have experience with Arais, and pix always help.
Based on your description, I wonder if the hole isn't too big for your axle? (I believe I've read here that the housings came with differing hole sizes.) So maybe the stationary housing isn't resting up against the stationary hub axle when you tighten it, but pressing beyond and onto part of the hub that rotates (sorry for the inelegant terminology!)
But: pix.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
1. If you disconnect the brake cable while the wheel is installed does the drum still drag?
2. Is the backing plate rigidly held, or does it wobble around a bit when the wheel is installed?
3. Is the drag you are experiencing a light rub once per wheel revolution, or enough that the whee doesn’t want to spin freely?
Pictures always help.
By your description it sounds like the brake shoe assembly (#2 in the pdf) is being displaced, or moved out of perpendicularity with the axle when the wheel is tightened in the dropouts. I would check both the drop outs to insure they are aligned as well as the axle is not bent
I am potato.
Quoted: 1784 Post(s)
Liked 1,622 Times
Diagram 2, 12-15mm spacing.
It's not uncommon to lose the washer in the "guts" section of item number 8.
Your local hardware will have a suitable thick or thin washer. Installing the washer between the shoe plate & the inner axle nut will prevent the shoes & shoe plate from being smashed into the drum when the axle nut is tightened by physically moving the shoe plate outboard.
Per diagram 2, you have up to 15mm protrusion allowable & still be within specs. Surely, a 1 or 2mm washer could help, no?
xlbs
Bikes: True North TI, Miyata 1000LT, Rodriguez tandem, Fontan vintage road, Sekine vintage road, Catrike recumbent
Quoted: 10 Post(s)
Liked 7 Times
By your description you need a bushing to take up the small difference in diameter of the axle. Washers will not work to center the axle because the braking force on the hub will push the hub off center. They will help to secure the wheel...
I am potato.
Liked 1,622 Times
The hole in the shoe plate allows the shoe plate to center to the drum.
The shoe plate is centered to the drum by using your forefinger & thumb to squeeze the brake lever arm towards the reaction arm thereby causing to brake pads to move outward towards the drum & move the plate to the actual "in-use" center.
When it is in the actual "in-use" center, apply the jam nut to the axle secure the shoe plate in place.
Release your thumb & forefinger & install the wheel.
The slight play between the axle nub & hole in the shoe plate is necessary so that both shoes apply to the drum equally & concentrically.
Arai offered the "backing plate" with different diameter center-bore holes to fit different axle diameters. I believe they offered 14mm to fit Edco/Hadley hubs and 10mm for others (like Shimano). From your description it sounds like your plate has a larger hole than the diameter of your axle, causing the plate to shift enough that the pads rub. Short of getting a plate with the correct size bore, not sure how you could remedy this without some custom machining or something. Precision Tandems suggests that you could weld up the hole and redrill it to the smaller size, but that would take some serious precision work as the hole has to be perfectly redrilled or else you're back to the same issues. https://www.precisiontandems.com/arai.htm
Quoted: 127 Post(s)
Liked 133 Times
https://www.bikeforums.net/22040486-post6.html
