Square taper crankarm's thread is stripped, what now?
We have a Santana tandem in for a tune. While installing new chains we discovered that the eccentric front bottom bracket would need adjusting. We have to remove both crank arms since both sides of the bottom bracket have to be adjusted equally. That is when we found that the captain's drive-side crank arm is stripped so a normal crank-puller tool won't work. We tried to get a gear puller from Harbor freight in there but the arms are thick and don't hook the back of the arm very solidly. We have to be careful so as not to damage this original, 30-year-old bottom bracket.
We also tried a torch thinking the arm might heat up more than the spindle...to no avail.
Any suggestions for getting this arm off using other methods/tools? Your creativity will be appreciated.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
1. A split plate type puller, assuming you can fit it in.
2. I’m assuming you want a non destructive method, but cutting a split in the crank arm will get it off.
3. Supporting the bike with the BB spindle resting on something to protect the bearings, you can gradually tap the arm off. This doesn’t really work well with non drive side arms.
4. Assuming you can get the other side off and remove the crank and BB from the frame, if you know someone with an arbor press they may be able to press it out.
5. Once upon a time I saw a kit for tapping a slightly larger thread in the dust cover location for just this issue, not sure how common those are.
6. If you only want to save the arm and not the spindle, you can always grind the spindle out. However this might cost you more time and grinder bits than the part is worth.
Say you do get it off, are you planning to put it back on again and repeat next time, or are you planning to replace the stripped part?
Quoted: 5703 Post(s)
Liked 2,429 Times
Quick. Easy, and gentle on components.
Jacobs chuck wedges, #6.
Fill the space with cone wrenches to get within the working range.
Likes For FBinNY:
Quoted: 580 Post(s)
Liked 921 Times
Gear puller will work but (1) you have to put something in/on the BB spindle to push against - a partially inserted crank bolt sticking out proud of the crank arm will work, and (2) you may need some additional plan for holding the 'fingers' of the puller on the back of the arm - a large pair of vise grips or a clamp or a friend holding a pair of channel lock pliers, just to keep the fingers from slipping off the back of the arm.
Quoted: 1124 Post(s)
Liked 1,704 Times
Something is not making sense, you should be able to adjust the chain tension with the cranks on.
2x on the wedges for the removal. I've also used the pickle fork method.
SE Wis
Quoted: 2731 Post(s)
Liked 3,356 Times
Mad bike riding scientist
Quoted: 6147 Post(s)
Liked 4,092 Times
Pickle fork. $13 at the O’Reilly’s near me. Put it between the frame and the crank arm and whack the end of the fork with a hammer. Should pop off without much effort.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,092 Times
Stuart Black
Stuart Black
Senior member
Quoted: 937 Post(s)
Liked 652 Times
Not worth it for a one time use but mine has been worth it over the years
Likes For Dan Burkhart:
I'm guessing you're getting a security warning from your browser. I've seen that numerous times here that turned out to be false alarms.
The BF software defaults all links to HTTPS - even if the original link posted is non-secure HTTP. My guess is that the original link was nonsecure HTTP and that the site in question doesn't do HTTPS properly (or at all). Even today, some sites don't support HTTPS for all links.
The nonsecure version of the link worked for me. Simply delete the "s" from the leading "https:" in your browser's URL window, then refresh/reload the page. (Depending on your browser's settings, you may have to enable nonsecure HTTP also).
Old fart
Quoted: 3571 Post(s)
Liked 3,366 Times
Liked 4,092 Times
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Quoted: 26243 Post(s)
Liked 10,227 Times
I assume you work in a shop. It might be worth your while to invest in something like this. https://steintool.com/portfolio-item...ractor-system/
I originally bought it when I was working Saturdays at the bike co-op here. I was seeing more and more stripped crank arms from people who didn't understand how to pull one without damaging it.
I have some of those Jacobs chuck wedges, and while they usually work, the Stein tool is just easier to use and allows you to effect a repair to the stripped threads, via an insert.
Likes For 3alarmer:
Likes For ClayH:
Liked 4,092 Times
If you don’t want to spend the money for a pickle fork, you might look into loaner tools at Autozone. They have pickle forks you can borrow. Put the bike on your car and you can probably knock off the crank in the parking lot.
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Liked 10,227 Times
Easily repair stripped out extractor threads with this piloted tap. The threads are larger in diameter than the original and have a coarser pitch, and can be used to remove the crank arm, which can then be replaced or put back into service with our dust cap extractors and made as good as new.
The set includes:
The set includes:
- Pilots for 8 and 15 mm internally threaded spindles (typical of square taper and ISIS spindles) and 10 mm stud type spindles
- Precision made hardened tool steel piloted tap
- Heavy duty shop type extractor
- Two dust cap-type one key release extractors (also available separately)
If you don't intend to reuse the crank, Unior makes a puller (#1662/4) that cuts new threads. The advantage over the Stein tool is that it's considerably cheaper. I find it takes less effort than a picklefork and it's more portable.
Likes For Gary Young:
Quoted: 3426 Post(s)
Liked 2,816 Times
Quoted: 497 Post(s)
Liked 622 Times
The easiest thing to do is remove the bolt and ride the bike. The crank arm will probably loosen up pretty quickly, but you never know as it might be corroded/frozen in place. Works every time.
Likes For KerryIrons:
Quoted: 114 Post(s)
Liked 118 Times
Liked 4,092 Times
There is that. Perhaps don’t remove the bolt completely so that the crank doesn’t fall off, however.
Stuart Black
Stuart Black
Quoted: 303 Post(s)
Liked 136 Times
the crank fixing bolt. Rode bike ~8-9 miles before it finally broke loose, had to one leg it 3-4 miles back to the car, using my R foot to hold the crank on.
So yes it works, but may take longer than expected or a good high torque hill climb to break loose.
...once more, unless you are somehow pressed for time, with the oversized crank puller from Stein and the repair inserts they sell with it as a kit, you can repair that crank arm.
...no cutting, no grinding, no pounding. Piloted tap so it goes in straight. Repair insert restores the original threading. The whole kit costs $120.
That tool looks great. Thanks for the tip.
