What is this spacer, with the raises pieces?
Bikes: (shortlist) Cyclops, Marinoni, Mariposa, Air Firday, Pocket Rocket Pro, NWT, SLX Fuso, Claude Pottie (France) x3, Masi Team 3v, Lemond Zurich, Bianchi OS
Quoted: 166 Post(s)
Liked 33 Times
I haven't seen this style cassette spacer before.
this was with a 7S cassette but why does it have these three raised pieces?
Does it work one way as 8S and the other way as 7S spacer?
Quoted: 5781 Post(s)
Liked 2,576 Times
A photo might help.
FB
Chain-L site
FB
Chain-L site
Really Old Senior Member
Totally agree!
I'm going to play psychic though, remembering when I bought my first new 7 speed cassette and wondering what the "weird" spacer was for.
The only one WITHOUT 3 bumps. (reverse psychic because one figures the OP missed there too)
IF it's a thin "serrated" one (maybe about .25mm? thick) I believe it's because the end cog is a 7 or 8 speed cog.
The spacer is omitted on 8 speed because or the narrower cog spacing.
I gotta look up an EV for a 7 speed cassette though to make sure I'm remembering right. Maybe it has 3 "bumps" to add thickness instead of making a new part#. It's hard to envision Shimano trying to limit part#'s though.
So much for playing psychic-
Quoted: 2026 Post(s)
Liked 1,096 Times
This is just a guess but 7-speed cassettes often had the largest 4 or 5 cogs bolted together and what you are seeing is the bolt heads. They are not "spacers".
Quoted: 166 Post(s)
Liked 33 Times
sorry. I thought I had posted a photo. it didn't seem to upload. It is up now, in the first post, above
Peter
Peter
Quoted: 166 Post(s)
Liked 33 Times
I finally found my calipers and the spacer measures 3.0mm (standard 8S Shimano) and the three flanges measure 4.0mm. so that is not 7S spacing.
they must just be to position the spacer. when positioned with the flangers pointing towards the centre of the hub, the do sit flush, in the right position. (flipped the other way they hold the next outside sprocket out a bit and space it too much.)
Quoted: 4201 Post(s)
Liked 3,857 Times
No, 8 spd has a narrower cog C-C dimension by (IIRC) .2mm. Close enough to 7 spd dimensions to be thought is the same, but not quite. Now Campy 8 spd does use the same 5mm C-C as Shimano 7 does. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Spacers with tabs that were wider than the spacer's normal width was used during the uniglide and early hyperglide days. See the diagrams for some of the Shimano freehubs, such as the FH-6400 or cassettes for CS-M732.
Since the tab in the same position that the long screw holding the cogs together, it would have to match a cog that didn't have a 'teeth' on the inside. Don't know about the spacer and cogs thickness from back in those years.
Sr Member on Sr bikes
Dan
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Those little raised nubs fit into notches on cogs from that era. Yeah, I call em that.
Once you take the cassette apart, totally useless. I cut the nubs off, myself.
