Can I use old Tires as Bike Trainer Tires vs discarding them?
Can I use old Tires as Bike Trainer Tires vs discarding them? I have about six of them on my garage wall. Its snowing today.
I was going to head out and buy a bike trainer tire and then I thought, "Why not just use these?" Will they burn up or smell?
Bikes: Way too many
Quoted: 897 Post(s)
Liked 606 Times
They'll eventually burst when you wear through the tread, but if you're on a trainer that holds the bike by the axle you'll be fine.
I'm not sure I'd use them on a roller, but then I can barely stay on a roller anyway.
Quoted: 506 Post(s)
Liked 638 Times
Many people define "old tires" as slightly squared off but no where near worn out. Old and worn out tires are exactly what I use on the rollers and I've never (in 50 years) had one "burst." Without the rough surface of the road, they last forever. And regards the OP's question, a typical trainer might wear out tires faster than the road, but you have nothing to lose by putting your old tires on for that use. The only potential problem is if the rubber has hardened with age and is too slippery to properly grab the trainer roller.
Quoted: 6193 Post(s)
Liked 4,808 Times
I thought the main reason for trainer tires over regular tires was that some regular tires make more dust as they scrub some on the roller. And that doesn't look good inside on your carpet or floors and nearby walls.
Otherwise the only other concern might be if they slip on the roller. But if you try them, you'll figure out if they work for you or not. Perhaps the worst thing will be is that you'll go through all your old tires quickly and not have any old tires left to use.
Quoted: 2952 Post(s)
Liked 3,106 Times
I’ve heard they’re quieter, but I wouldn’t be able to hear the difference over the fan.
Quoted: 2604 Post(s)
Liked 1,928 Times
I'd have thought the worn/squared off tire would be the quietest possible surface.
If you use an old tire, do keep an eye on it. Older tires sometimes develop a bubble in the sidewall -- if that happens, replace it ASAP. If you don't, the blowout will scare everyone in the building and your ears will be ringing for a few hours.
Should Be More Popular
Quoted: 22595 Post(s)
Liked 8,925 Times
Likes For datlas:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
A few hours? I had a bubble explode once next to me. My one ear was ringing for about 4 months!
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,887 Times
And then I put on loud music to cover the noise of the fan(s), so I REALLY wouldn't hear the difference!
Quoted: 3949 Post(s)
Liked 7,295 Times
Quoted: 18410 Post(s)
Liked 15,530 Times
Liked 7,295 Times
Liked 1,928 Times
I've got to disagree with you. I've had a couple tires develop sidewall bubbles near the end of tire life, including one tire I took off and set aside for a couple years. It didn't have a bubble when I took it off, but within a half a day of putting it back on, there was a bubble at lunch. Only an hour or so left, so it'll last until the end of the ride, I thought. Nope! (And to make it worse, it was only a few yards past a road kill skunk.) Since it didn't show that bubble for the first 1,000 miles or so, I have a hard time ascribing it to a manufacturing defect.
Quoted: 1460 Post(s)
Liked 1,480 Times
I honestly have no idea why people buy trainer specific tires for road bikes. I can see doing this if you've got a MTB/CX/Gravel bike with knobbies and you just need a cheap slick that will only be used indoors, but otherwise just run old road tires.
Likes For msu2001la:
Liked 11,887 Times
It's what I'm doing with a GP5000 that got a cut that makes me not trust it on the road. If it blows out on the trainer, I lose nothing but my hearing.
Sock Puppet
Liked 863 Times
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
BB
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Likes For bbbean:
Quoted: 1819 Post(s)
Liked 1,693 Times
I have seen a road tire that has been used on a trainer later fall apart(almost) on the road. The tires in question were Michelin Pro4 service course, a pretty nice riding road tire. They had very little mileage before they went on the trainer. They were on my girlfriend's bike. She would come and ride with me about 50% of the time that I did almost always quitting about 2/3 of the way through my workout. They probably only had 10-15 hours on the trainer. Once we actually started riding outdoors I was riding 3 times as much as she was, but less than halfway through the summer her rear tire started splitting in the middle of the tread. My take is don't ever use really good tires on a trainer
Liked 1,693 Times
I pretty much agree with this. Trainer tires work best, but there is nothing wrong with getting that last bit of service out of your old tires
Quoted: 1109 Post(s)
Liked 1,200 Times
I recommend putting an old blanket or towel under the rear wheel area, they do put off some ground up rubber. At least they have put out a bit in the total of about 10 hours I've put on the indoor trainer in the past 10 years.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Sure you can. They will last a very short time, but what have you got to lose?
It's like riding a bicycle
Quoted: 2482 Post(s)
Liked 2,952 Times
Likes For Trakhak:
Bikes: Way too many
Quoted: 897 Post(s)
Liked 606 Times
If you wear any tire long enough it'll eventually burst when you've worn it away to the point it can't handle the pressure coming from the tube. It could take thousands of "miles" though.
Sock Puppet
Liked 863 Times
The solution is simple. Wear hearing protection when riding your worn out tires on the trainer.
https://www.amazon.com/Cyber-Profess.../dp/B078JWXMVR
Likes For Lombard:
