Help please with Sturmey front hub brake
Liked 8 Times
I have a set of used Sturmey Archer front and rear hub brakes that I am going to get spoked up to some new alloy Pashley 28” Westwood rims to go on my very old BSA frame c. 1920s
I guess the hubs are 70s or 80s, I think off a tandem. 110mm front brake.
I am all fine with the rear hub, but not sure how to anchor the brake cable housing on the front hub. Picture attached. There is a bracket but I think it is for the rear...not sure.
Can anyone tell me what I’m missing?
thanks
Overdoing projects
Quoted: 784 Post(s)
Liked 1,237 Times
Yeah the bracket is for the rear. It looks like you have a model that relies on a hook on the frame for some reason?
I have an older rear hub here that looks similar and also lacks a hook.
On a different model they solved it by using a special bolt that would secure the arm and offer a cable stop at the same time.
Modern hubs solve this by using a built in cable stop hook.
You need something like a HSL702 to secure the arm to the frame (check the sizing, they offer different diameters).
Use a fulcrum clip to act as a cable stop.
Liked 8 Times
Thanks Jacob
I may have partly answered my own original question...I found this heritage diagram in Sturmey archives which appears the same but has part 21a instead of a plain bolt. I actually have part 21a in a plastic packet, so must have bought it at some forgotten point, but when I try to undo the plain bolt on my hub, it spins but doesn’t undo.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,237 Times
Remove the axle screw and you can lift the entire brake assembly in one piece. You can use a wrench on the inside and one on the outside to undo it.
Liked 8 Times
I found this old chart on Sheldon Brown, seems there were various ways of fixing the brake cable back in the 40s/50s. My hub seems newer than that, no model or dare stamp, so I don’t know what part I really need.
Likes For AL NZ:
Likes For AL NZ:
