Dura Ace 7700 was the best Shimano road group ever
Quoted: 2432 Post(s)
Liked 638 Times
I had that group on a Serotta Atlanta and it was the best ever.
I've always thought 9 cogs was the perfect number. A 10th just was not needed for me personally and fine tuning became more finicky. Also needs a narrower, IE weaker chain. The external shift cable routing has less friction and shifts crisper, and that style of brake hood was (is, I have an older Tiagra) more comfortable on my hands. All the modern internal routing Shimano STI's make my fingers numb. And the whole group was light as hell.
It was beautiful as well. The biggest drawback is the clear coating that peels off. Hard to find used components that still look good.
What is this place ? 😁
i agree
7700 shifters are far superior to 7800 and 7900
positive mechanical click, bulletproof
7800, good but less reliable, need clean and lube and they fail
7900, not good, they fail
ask me how i know, got them all
i do prefer 7800 cranks, even if they are heavier
i agree
Likes For reissue59:
I just wish you could get new hoods.
Likes For natterberry:
Likes For CABELLOJO:
Likes For BFisher:
Quoted: 85 Post(s)
Liked 74 Times
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
I've overhauled many STIs, but I have a set of ST-7700s that I couldn't get going again.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
The thing I never liked about Ultegra 6500 (6503 to be specific) was the lack of trim for the big ring of a triple. 6603 has it, and to me shifts just a bit cleaner and has more comfortable hoods.
The real deal-breaker with 6603 is the front derailleur shape which is incompatible with my preferred 52/42/30 triple. It’s designed for a larger tooth difference from the big to middle ring (52 -> 39) and the inner cage will hit the 42 tooth ring unless set so high that it won’t shift cleanly. A 105-level 5603 FD will give passable front shifting (designed for 50 -> 39) but it always annoyed me to have to compromise.
bike whisperer
Liked 716 Times
Although it's getting a bit academic, since you can't get the middle rings anymore...
I have two nearly new Stronglight triples (a Pulsion and. Fission), both with 52/42/30 9/10 speed rings so I’m good there.
Worst case, I’ve been known to make parts to solve my problems
Quoted: 2952 Post(s)
Liked 3,106 Times
The 7700 crankset was beautiful, but the external BB 7800 was a breakthrough.
Likes For caloso:
Likes For Lazyass:
Quoted: 1943 Post(s)
Liked 2,164 Times
Except the 7700 triple crankset with it’s planned obsolescence spider.
Oh... and it would have been nice to have a titanium axle in the freehub like the XTR 950.
Other than that, probably one of the best groups.
John
Edit Added: And the double rebuildable/adjustable cartridge BB didn’t have a lot of fans. The triple cartridge was plug and play.
John
Likes For Wileyone:
Friendship is Magic
Bikes: old ones
Quoted: 26392 Post(s)
Liked 10,366 Times
bike whisperer
Liked 716 Times
All this love for HT2, and not a word about scuffed cranks due to lack of heel clearance. I'm annoyed Shimano never offered a BB30 version of their cranks; pair that with a PF30, or better yet, T47 frame and it'd be almost pure win.
Although it'd be nice to have some delrin between the ally spindle and the steel bearings... wonder if there's room for that in T47?
Friendship is Magic
Bikes: old ones
Liked 10,366 Times
...I have always hated watches, and never wore one. If I had one on, it would just remind me I'm late for something. Watches are horrible things, and the ones you wear on your wrist are just a fashion statement that you are more organized than me.
Wait, I just remembered I wore a watch when diving. I don't know why, because I was gonna run out of air regardless of what time it was.
bike whisperer
Liked 716 Times
Best watch I ever saw showed the time on its edge, so you could discretely peek down your sleeve without letting on that you're bored out of your mind.
Likes For Kimmo:
Quoted: 1858 Post(s)
Liked 606 Times
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 57 Times
Agree, my PDG Series Paramount has all 7700 except for the brakes which are 7800 (best brakes ever), and the outer chain ring which is a 7800 ring, I just like the way the 7800 outer ring looks, kind of like a meat slicer!
Friendship is Magic
Bikes: old ones
Liked 10,366 Times
