For the love of English 3 speeds...
#2851
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 9 Times
Wax will help a little bit, but linseed oil works far better atmo. There are lots of other folks here on the forum that are advocates of the linseed oil approach too. I was a naysayer but then I tried it and am now a true believer.
#2852
K2ProFlex baby!
Location: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Quoted: 16 Post(s)
Liked 56 Times
So, Ilikebikes, have you ridden that James much yet? I have that hub on one of my bikes, and am about to put it on a second. I like it a lot.
Can you adjust that front rack so the top is horizontal? That oblique angle bugs me.
Don't listen to Photogravity, he's just jealous. A SA S5 really is a three speed hub; just a little better-- it's actually two three speed hubs in the same shell. Neat trick.
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
#2853
multimodal commuter
Quoted: 1907 Post(s)
Liked 572 Times
+1 on linseed oil. It soaks into the rust and dries into like a varnish, after which you can add more. It works on painted areas as well as chromed. I've also used Tung oil, which seems to dry a little better. Shinier.
#2854
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Does it darken in time? I've got a darkened clear coat on an old English frame that I can't seem to remove.
#2855
Bikes: Somebody stole them all... I walk now.
Found some linseed oil and applied it. I'm guessing the more coats the better.
Whew, is the oil supposed to smell bad though? I hope it doesn't linger, smells like something that I pulled from the trash.
#2856
multimodal commuter
Liked 572 Times
Yes, I imagine linseed oil would darken over time. I doubt that's what your clearcoat is, though. More likely a lacquer or varnish of some kind, both of which could/would darken as well.
Smell bad? I suppose so. But I've done a lot of woodwork and some oil painting over the years, and I've come to love the smell. If it really smells like something that died, maybe there's something wrong with the oil.
#2857
Bikes: Schwinn: Twinn Sport, Super Sport and Suburban. Raleigh Grand Prix, Competition, and Super Course, plus New Clubman.
Can any of you guys comment on 3 speed gearing? I'm running an AW with (I think) 48 front to a 20 tooth sprocket and find the cruising ratios awkward. I'm generally looking for something in between middle and top. That probably makes sense since I gravitate to a 75" gear on my ten speeds (in the flat with no wind) and the AW works out to about 86" for top and 65" for 2nd.
Any experiences with 4 speeds (FM and FW)?
David
David
#2858
Half way there
Bikes: 69 Hercules, 73 Raleigh Sports, 74 Raliegh Competition, 78 Nishiki Professional, 79 Nishiki International, 83 Colnago Super, 83 Viner Junior
#2859
multimodal commuter
Liked 572 Times
David
David
The steps between the gears of an FW are slightly smaller, which is definitely better though the difference is pretty subtle. The steps between the higher three gears of an FM are so small I often can't decide whether the hub shifted correctly or not. I had an FM hub for a while, didn't really like it, and traded it to a friend. But several months later I changed my mind and got it back... and haven't ridden it much yet.
If you are generally looking for something between 2 and 3, I'd say change the cog --this is really easy to do-- to either 18 or 22 and see how that feels. I'd recommend the 22. If you can pick up an FW or S5 hub it is pretty easy to switch out the guts of the AW for the guts of the other; you'll probably need a different trigger shifter as well. The guts of an FM hub do not fit the AW shell.
#2860
Bicycle Repair Man !!!
David
David
With 26 by 1 3/8 inch wheels a 46/20 gives you a gearing of 47/62/83 and a 22 tooth cog would give you 43/57/75.
With 3 speeds I like to set the 3 gear as flat gear and then have two steps down rather than having my 2nd as my primary drive gear... my 20's are set up with 46/18 to give me a 36/48/64 which is great for urban assaults where quicker acceleration and a lower 1st makes hauling cargo a lot easier.
#2861
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
One needs to know the wheel size you are running to determine gear ratios... 86 gear inches is pretty steep for 3rd and think that unless you are riding a much older Raleigh that the front chain wheel is a 46 tooth.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
#2863
Liked 9 Times
#2864
I recently bought a dozen 24t cogs from an eBay seller in Germany, so I have enough to put 24t cogs on most of my IGH bikes. So with a 46/24 setup and 26x1-3/8 wheels I'm at 37/50/66. I have a Raleigh 44t chainring I bought a while back but haven't yet installed which will put my gearing at 36/48/63. Around these parts, I'm more concerned with climbing hills than I am with going fast so if I'm geared low on the flats, so be it.
#2865
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
[QUOTE][Yes, I imagine linseed oil would darken over time. I doubt that's what your clearcoat is, though. More likely a lacquer or varnish of some kind, both of which could/would darken as well.
/QUOTE]
If it is darkened lacquer or varnish, any ideas on how to lighten or remove it without removing paint and decals?
/QUOTE]
#2866
This is actually on my Dad's Schwinn Suburban. I rechecked the crank and it is 46, rear sprocket is 20, wheels are 27". By my calcs thats 83/62/46.6. A 22 sprocket would give about 75 top and 56 2nd, so I would have my cruising gear but I wonder if 2nd wouldn't be a little low?
With limited choices I ideally want a gear pitched for in-the-flats with 5 mile tailwind as top, and in-the-flats with 5 mile headwind as second gear and a third that gets me up the easy hills (I'll walk the steep ones).
An FW with top set about 78-80 sounds about right. I'm thinking about a Clubman type path racer made from an old Raleigh Record, in all this.
David
#2868
multimodal commuter
Liked 572 Times
Thanks for the answers, guys.
David
David
#2869
Maybe I should spin a little faster, but I can spend most rides in a 75" gear. Being lazy I'll even do short hills in that gear rather than shift. (fixie candidate?)
I realized this after noticing that on most my ten speeds that I was almost always on the big chain wheel and middle sprocket. For most of them that worked out to about a 75" gear and a speed of 15-17mph, more or less.
David
David
#2870
Quoted: 70 Post(s)
Liked 15 Times
[QUOTE=Velognome;13655253]
If it is lacquer try denatured alcohol, varnish is a crap shoot depending on the type, I would try mineral spirits first. Also try both of these in an out of the way place to see what they do to the lacquer/varnish finish.
Aaron
/QUOTE]
/QUOTE]
Aaron
#2871
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
Thanx
#2872
Bikes: 1983 Peugeot UO14, KHS Green-Heavily modified, 1972 Raleigh Sprite 27" (work in progress)
Anyone ever fix a dry accumulator/filter switch unit (with 3 small terminals and one large central terminal? I've tried the original wiring configuration and another posted online and I believe the rectifier circuit may not be functional.
Edit: The battery function now works, dynamo connection through the unit doesn't appear to work as far as I can tell thusfar.
Last edited by Fenway; 01-03-12 at 09:32 PM. Reason: Update: got the battery terminals to work
#2873
I'm sure this is common knowlege to most, but linseed oil soaked rags are very flammable. They can sponateously combust. I either allow them to dry flat or store them in an air tight metal container with a tight fitting lid.
#2875
Working on another English three speed here... my friend's '53 Rudge... and it looks so much better now than it does here.
Opted for the Path racer as he already has an upright 3 speed which I helped with last January when I was here.
