Sturmey Archer oil ports
Bikes: 1959 & 1960 BSA Star Riders and 2011 Muddyfox Mountain bike :-))
I have two old BSA bikes, one has a 1959 SW 3 speed hub (which works like a dream believe it or not and is totally silent freewheeling) the other is a 1960 AW 3 speed hub. They both have tiny little plastic oil ports. I damaged the one on the AW hub, trying to put it back in after I knocked it out trying to clean all the gunk from around it. Is there anywhere I can get new oil ports from, preferably metal ones like the older bikes had?
ANy advice appreciated, thanks.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Metal ones come from parts bikes and as GB said leak, always. Plastic was an improvement and unless you're doing a faithfull restoration, plastic is the way to go. See you LBS or on line at shops like Harris.
Bikes: 1961 Raleigh Sports
According to Sheldon Brown, the plastic oil ports work much better than the old metal ports, which according to him was one of the few instances where things improved on an English 3 speed by replacing a metal piece for a plastic piece. Harris Cyclery carries them for about 2 USD (as well as a bunch of other S/A spares). The spare oil cap can be installed using a blunt pencil to hold it as it is being screwed in.
Count Orlok Member
Bikes: 1983 Peugeot UO14, KHS Green-Heavily modified, 1972 Raleigh Sprite 27" (work in progress)
Harris sells replacements for a $1.95 at the time of this posting:
https://harriscyclery.net/product/stu...il-cap-816.htm
Wood
Bikes: Raleigh Sports: hers. Vianelli Professional & Bridgestone 300: mine
Quoted: 8 Post(s)
Liked 12 Times
If the hub is not leaking, how are you supposed to know when to add oil?
No Money and No Sense
Don't use sewing machine oil. It's too thin.
Thanks for your replies. I would prefer it not to leak TOO much after I have spent hours polishing all the chrome up! However judging by the accumulated oil and crud that I cleaned off they must leak a fair bit. If I can get hold of anything at all it will be better than having a hole in the hub though. I will try Harris Cyclery, however I am in the UK and we tend to get hammered for import duty ordering from the US which is damned annoying.
Just looked on the Harris website and they won't ship overseas less than $75! Must be somewhere I can get these in the UK.
Liked 8 Times
If you're in UK, try phoning Fuller's Cycles in Dorking, Surrey - I bought a few plastic oil ports there a year ago. The guy in the shop is keen on old 3 speeds, so know his stuff.
Mine have travelled with me back to NZ - export quality !
Bicycle Repairman
Lots of interesting articles out there about this unique hub, including some on how to improve their operation.
https://www.squidoo.com/sturmey-archer-SW
https://www.sheldonbrown.com/sw.html
Palmer
Bikes: Mike Melton custom, 1982 Stumpjumper, Alex Moulton AM, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2021 Motobecane Turino 1x12
Quoted: 1646 Post(s)
Liked 1,785 Times
The SW was supposed to be a totally silent hub. They're scarce today and parts are hard to get for them.
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
This looks like a good vintage friendly shop in the UK:
https://https://www.theoldbicycleshowroom.co.uk/index.asp
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
I,d try a small cork from the hardware store. I bet it would be almost as tight as the plastic but better looking.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
You can thread a small plug in there...just don't recall the thread size. The old white plastic port covers are threaded, the newer black ones aren't. The old holes were round the ones that take the black port appear to be stamped and have several distinct sides. I will have to take a closer look when it cools off, over 115* in my shop at the moment
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Hi guys, I got a proper white plastic oiler today from The "old bike Trader" in the UK! Thanks for your input.
https://www.oldbiketrader.co.uk/
