9 to 8 speed cassette needs new free hub?
Old 05-23-14, 03:47 PM
lungimsam
Liked 2 Times in 1 Post
How can I tell if I need an 8 speed freehub, or if the one I have with the 9 will work?
The new cassette will have the same size outer cogs (11-32T).
lungimsam is offline
Old 05-23-14, 03:55 PM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 10146 Post(s)
Liked 5,132 Times in 2,682 Posts
If it doesn't work it can be made to work with a spacer. Even if it does work you may want to add a spacer to get a perfect chain line. Some cassettes have blobby soldered-in pins (or maybe tack-welded?) that won't work so well with some spacers. Zig-zaggy type spacers can sometimes avoid the blobs, but to make sure get a grinder or file and work them down a little flatter.
spacer
Zig Zaggy spacer
LesterOfPuppets is offline
Old 05-23-14, 06:12 PM
HillRider
Quoted: 1963 Post(s)
Liked 977 Times in 675 Posts
All Shimano freehubs that take a 9-speed cassette will also take an 8-speed or a 10-speed cassette. No extra spacers are needed for the 8-speed. You would need a 4.5 mm spacer to fit a 7-speed cassette and a 1 mm spacer (it comes with the cassettes) to use a 10-speed cassette.
HillRider is offline
Old 05-23-14, 08:02 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 184 Post(s)
Liked 89 Times in 74 Posts
HillRider's got it, as usual.
Short version: you do not need a different freehub.
FastJake is offline
Old 05-24-14, 07:30 AM
lungimsam
Thanks, y'all. Glad to know I am not opening a can of worms with this mod.
scuzzo
Bicycle Mechanics
5
09-04-16 05:32 PM
gearhead82
Bicycle Mechanics
3
07-15-14 11:04 AM
BROOKLINEBIKER
Bicycle Mechanics
4
02-26-14 06:19 PM
adamjmeek
Bicycle Mechanics
21
11-25-12 05:28 AM
tommyd49
Bicycle Mechanics
2
04-23-12 08:24 AM
