Help IDing a frame - S-curve seat tube
Quoted: 7 Post(s)
Hello, A friend had asked me to inquire about this bike that is he going to be looking to sell.. No markings on the frame whatsoever besides the serial number.
-Campy fork dropouts. Nothing on the rear.
-Rear dropouts are track style
-Mostly campy group. Campy hubs to a GP4 rear and GEL280 front rim - tubulars still holding air! Woo!
-Campy 6s freewheel. Looks new.
-Sedis chain
I can grab more pics if needed...
Thanks in advance
Dave
-Sedis chain
Thanks in advance
Dave
Quoted: 3811 Post(s)
Liked 3,337 Times
hello dave,
thank you for sharing this curiosity
first thought regarding frame is wonder if what we see is "as built" or if some of the braze-ons may represent additions since it is the recipient of a respray
chainstays may be fork blades
dropout stops are Simplex or Huret and are manufactured by ALGI
lugs and crown appear French
pump peg is NERVEX and is somewhat anachronistic to be seen in conjunction with the other braze-ons such as front mech, w/b & top tube guides, as by the time these latter had come into fashion framefit pumps were widely available from several makers
NERVEX also offered lugless bottom bracket shells
first guess for possible national origin is France
serial: if read in reverse it could indicate a date of May 14, 1972
one simple check you could make would be to determine headset and bottom bracket thread together with tube diameters
shall look forward to reading what the forum experts have to communicate...
usage tip -
the short chainstays found on curved seat tube cycles tend to limit the number of usable gears on a multi-gear derailleur drive train due to the crossover issue
many cycles with frames of this pattern are built up with single plateau drive trains
MauriceMoss bulgie Doug Fattic
hello dave,
usage tip -
Quoted: 7 Post(s)
hello dave,
first thought regarding frame is wonder if what we is is "as built" or if some of the braze-ons may represent additions since it is the recipient of a respray
pump peg is NERVEX
hello dave,
pump peg is NERVEX
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
Schwinn made their Paramount model with such a seat tube in the mid-1970s, but I'm pretty certain the OP's pictured bike is not a Paramount. I wonder of the RD mount has been added later?
Bob
Bob
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Jack Taylor, Bob Jackson, Roberts, KHS among others made bent seat tube bicycles.
Quoted: 3511 Post(s)
Liked 2,925 Times
Is that rear wheel laced correctly?
Liked 2,925 Times
Maybe so, but I still think it's incorrect.
If it's laced 3-cross, then the spokes at the valve should not be crossing over the valve--they should be almost parallel at the valve (like they are currently at the rim joint sticker), and crossing each other at the rim joint.
Likes For smd4:
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
This was does not look like a P, but I could be wrong......Here's a P with track drops and a RD hanger....I have on like that too.
bikecult.com > bikeworks nyc > archive bicycles > schwinn paramount track
Best, Ben
Best, Ben
Voltaire
Voltaire
Liked 3,337 Times
multi-use, employed as training bike
bitd enthusiasts would often have a single frame they would set up in differing formats depending on use
common to have three sets of wheels, for example, to use with one frame
Likes For fmradio516:
Liked 3,337 Times
terminology note -
an added gear hanger is sometimes referred to as a "tab"
terminology note -
Liked 2,180 Times
Best, Ben
Voltaire
Voltaire
Liked 3,337 Times
for a number of years Campag offered a braze-on gear hanger/tab; item number 80/1
out of production now many a yar...
[page from catalogue Nr. 14 of 1960]
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
It's "incorrect" in that such lacing increases the difficulty of getting a pump head onto the valve stem, but the wheel is not inherently weaker from being laced that way. Not really wrong, but not right.
Liked 2,925 Times
I get that the lacing itself may correct, but to me, with that fault, it was laced by someone who didn't now what they were doing--a first try, perhaps.
framebuilder
Dave, as you know, one of the best ways to increase the sale value of this rather odd bicycle is to identify its builder. As I mentioned on Paceline, it is possible it is just a mediocre frame with ratty paint. It is up to you to distinguish what it really is. We need you to provide more information and pictures. The seat lug seat stay attachment is often where builders do something distinctive. We also need close ups of the head lugs and fork crown. Those can also have defining features. Also we are waiting to hear if the BB threads are English. And what is the length of the cranks and what are the number of teeth? That looks like a very light weight American Classic seat post. Is it 27.2? It can be helpful to measure the seat tube and top tube center to center lengths.
My guess is that this is British built because it appears to be a time trail frame with a very short wheelbase. Time trials were very popular in the UK and road racing was not. I think I counted more than 53 on the front chainring. It has a very short stem. Also the head angle looks pretty steep because it doesn't have much fork rake. It is going to take a special person that thinks this frame is right for them. The heavy back rim compared to the very light front rim means an owner sometime probably changed out the back rim.
Likes For Doug Fattic:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
It reminds me of a Gillot but I can't find any curved seat tubes online.
blahblahblah chrome moly
Quoted: 1174 Post(s)
Liked 2,569 Times
Two quick things to mention about the curved-tube bike
I used to have one of those, in the older style with the hole for the spring on a Cambio Sport. Or I should say I still have one, but it's brazed to a dropout now. I "un-drewed" my '50s Follis, that came with Campy 1010 dropouts but was drewed, probably early in its life because it came to me with a 1958 Allvit on a Huret bolt-on claw. I know, weird, right? Cutting off a Campy hanger so you could use an Allvit? Who does that?!? A rabid francophile or French chauvinist in the late-'50s is my guess.
On that bike, I actually needed the extra hole for the Sport mech, because the one I installed is a hybrid, Record mech with the sprung top knuckle of a Sport grafted on. It gives the Record vastly more gear range, which I needed because I'm old and fat. It now sports (no pun intended) a 13 to 30 freewheel with a 20-tooth range triple in front. Shifts smoothly to all gears, not maxed out. An original Record (the bronze and steel one, not the later mech of the same name) was happier with a half-step double, usually 5t difference or less in front.
Mark B
- That tube is probably the one sold by Reynolds. You could bend your own of course but few people did, the "factory" 531 curved tube was nice enough. I have one, looks just like the one on OP's frame. Can't envision using it, but I just like having it. (I'm a bit of a hoarder).
- I'd recommend taking that Campy freewheel off if you're going to actually ride the bike. Not that they're bad exactly, but they're very valuable and not very durable, with almost-all-aluminum construction (both the cogs and the body). I think even the pros only used them for uphill timetrials or mountain stages.
Mark B
Likes For bulgie:
Quoted: 7 Post(s)
Quoted: 643 Post(s)
Liked 1,526 Times
I had one of these in the early 80's. Heavy beast.
Quoted: 7 Post(s)
-REAR DROPOUTS ARE CAMPY! (Its pretty worn, and hard to see in the picture, but circled in red is part of "BREV" and "CAMPAGNOLO")
-English bottom bracket
-27.0 American Classic post, but I can start a 27.2 post in it. Although its a little tough, so maybe just needs to be cleaned out a bit?
-57cm ST c-t / 56cm TT
-Cranks are 170mm 52/45 but the inner ring is Sugino, not Campy.
-Spacing is 100/125 F/R
IMAGES
Thanks!
