Bottom brackets on a 1972 Raleigh Record
Not too long ago I found a Raleigh Record at a dumpster and took it open myself to start fixing it up. I have repaired most everything on the bike and its running better than ever except a slight ticking sound whenever I pedal the bike, and the sound always occurs at the same pedal location. I am pretty unfamiliar with fixing and diagnosing bikes but I believe the ticking sound is due to the bottom brackets, (correct me if I am wrong) But my question is what kind or size bracket I would need to properly replace it and also if I would need anything else if I repair the bracket. Any help is much appreciated.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Likes For dedhed:
Quoted: 523 Post(s)
Liked 229 Times
When the Japanese adopted a standard for bottom brackets they chose to use the English standard so Japanese made bottom brackets have the same thread as English made bottom brackets. It's easy to find ones with the English thread today versus trying to find one like the French threaded BB on my 73 Motobecane Le Champion with Stronglight cranks. The main consideration is type of axle (square taper?) and width. You may need to find someone with a BB cup remover for the fixed side when you go to replace it. with a newer sealed bearing unit It's never easy to get that side off and with a bike this old may be really difficult. If you are lucky it may only be a problem of replacing the bearings if the bearing races are not damaged.
Quoted: 1819 Post(s)
Liked 1,693 Times
Quoted: 912 Post(s)
Liked 515 Times
Edit: Sorry, the '72 in thread title went over my head
Quoted: 6193 Post(s)
Liked 4,808 Times
If it turns out that your Raleigh Record has a BB that isn't BSA threaded, then toss it back in the bin, the scrap metal bin so it gets re-cycled. No pun intended, might wind up being a can for pork and beans. Raleigh Records, while pretty aren't anything special. And fixing and maintaining a bike that doesn't hold to any standard component still made today will be expensive if you have to pay ebay prices for NOS (new old stock) and already worn out parts sold there.
However if you have it in mostly working condition, then good for you. Ride it. The sound you hear might be from anywhere. For various reasons, many sounds just seem to come from the BB. Usually they aren't.
If you feel the click more so than hear the click, then I'd first swap the pedals on your bike for some others. There is already a current thread on this in the Bicycle Mechanics where this question should have been posted. And many others about mysterious clicks.
Click
Welcome to BF
Click
Welcome to BF
Quoted: 581 Post(s)
Liked 921 Times
Don't assume it is the bottom bracket - pedal bearings are very prone to wear out and develop ticks and creaks and pops. Slap a known-good set of pedals on and take 'er for a rip and see if it is improved.
Fast Old Guy
Quoted: 145 Post(s)
Liked 672 Times
Likes For Straightblock:
Quoted: 912 Post(s)
Liked 515 Times
In my 2¢ worth of experience, with respect to rhythmic clicking or ticking, would be to lubricate any metal to metal interfaces of the saddle/pillar including rivets.
Likes For FBOATSB:
Quoted: 581 Post(s)
Liked 921 Times
Quoted: 3811 Post(s)
Liked 3,336 Times
if your example came through with Brit produced pedals would suggest disassembling them and counting the bearings in each of the four races
inconsistencies at this location were common in Brit pedals at this epoch
this could cause the noise you describe...
Likes For juvela:
Quoted: 702 Post(s)
Liked 672 Times
The threading of a 1972 Raleigh Record is likely 26 tpi rather than the more common 24 tpi so replacing it will take some effort so it's better to just re-use what you have as long as the bearing surfaces aren't badly pitted or worn.
Quoted: 702 Post(s)
Liked 672 Times
Here's a thread showing what you are likely to encounter, it's a early 1970's Grand Prix which used the exact same BB as the Record of the era...
https://www.bikeforums.net/classic-v...ket-crank.html
Quoted: 3464 Post(s)
Liked 2,829 Times
Likes For repechage:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
If the cups are still serviceable, you may be able to use a standard square taper spindle. That's how I got a crank for my daughter's Raleigh 3-speed frame.
Likes For JohnDThompson:
Quoted: 1872 Post(s)
Liked 692 Times
Does it click no matter which chainring you're in? Or only on one of them?
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 1856 Post(s)
Liked 664 Times
Another issue is that 99.9% chance that this crankset/BB uses cotter pins, not a cotterless arrangement. You need to look at Sheldon’s stuff to see how to work on it. What’s wrong with it? Squeaky? Rough? The petaling noise suggests it just needs to be overhauled, cleaned and regreased with new balls. From some I’ve seen lately, the cups and spindle could easily be like new. I would certainly try to repair versus replace.
Liked 664 Times
Yes, a repair along these lines is certainly possible, I’m following this path on my 1952 Rudge! I’m trying to find a pista crank for it.
