Rim internal width 19mm, which size rim tape?
As per title, which size rim tape do I need to get ? Do I need to get something longer than 19 or shorter ?
Old fart
Quoted: 3571 Post(s)
Liked 3,366 Times
You want the tape wide enough to fully cover the spoke holes, but not so wide that it interferes with mounting the tires.
Likes For JohnDThompson:
Quoted: 4171 Post(s)
Liked 3,791 Times
Are we to assume a tubed type set up? If so than John's answer is right. Andy
AndrewRStewart
AndrewRStewart
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1876 Post(s)
Liked 1,411 Times
FFWD specifies 25 mm wide rim tape for the 622 x 19C wheels I recently bought. As far as I know, rim tape must be wide enough to be completely pressed into the center channel and reach the side walls.
Liked 3,791 Times
You forgot to specify "for tubeless set ups". When using a tubed system one rarely wants the rim tape under the tire's bead. Andy
AndrewRStewart
AndrewRStewart
Liked 1,411 Times
I was merely describing what I saw with my new wheels, that the rim tape is just wide enough to be applied into the center channel and still reach (but do not go up) the sidewalls. So it does not look like any rim tape would sit between the tire bead and the sidewalls of the rim.
In my experience, one nearly always wants rim tape under the tire's bead. Most rims are dimensioned for it, and can suffer from sloppy tire fitment otherwise. Tape that only covers the middle can also be prone to lateral crawl; I've been in situations where a rim had to have its tape re-set when repairing a flat, which isn't a huge deal, but it's an easily-avoidable annoyance.
The main situations that come to mind where tape should be excluded from the bead seat shoulder are if you're using single-wall rims (where the tape is intended to be well-contained by a steep-sided center channel) and some rims with no spoke access holes in the tire seating bed (if they're intended to be used with no tape at all).
Likes For HTupolev:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 669 Post(s)
Liked 725 Times
Add about 2 mm to the spec inner width, so the tape snugs up against the wall without climbing it.
Lately I've been using tubeless rim tape, two wraps for my high pressure tires. Works great, and makes tire removal easier.
Quoted: 850 Post(s)
Liked 344 Times
I would add 4mm to the inner (hooked) width. So a 19mm rim would need a 23mm tape. You can probably get away with +/- 1mm. The advantage of wall to wall tape for TL is obvious, but it helps with tubes as well because it means the tape is way less likely to get damaged from removing/installing tires.
Quoted: 3426 Post(s)
Liked 2,816 Times
For tubed tires I'm with JohnDThompson--I use rim tape just wide enough to cover the spoke holes--nothing more. Velox is the tape I prefer.
Likes For smd4:
Bikes: More bikes than riders
Quoted: 1438 Post(s)
Liked 749 Times
I will say that I'm sure the very thin mylar/tubeless type rim tapes don't increase the bead seat diameter appreciably...my practice of avoiding the bead seat area comes from when I used to use Velox on everything.
On older non-tubeless double-wall rims that were designed for use with cotton tape, a wall-to-wall wrap of cotton tape usually works great. Actually, cotton tape can be more convenient with these rims than tubeless tape, because it can take multiple wraps of tubeless tape to achieve sufficient bead seat shoulder height. The Rhyno Lite rims on my gravel bike have either 3 or 4 layers of tape (can't remember), because any less and the tires simply would not mount without a bit of ripple, no matter how much I massaged them or tried to snap them in place with high pressure; cotton would have been an easier solution.
Likes For HTupolev:
Liked 749 Times
I have a set of double wall Trek Matrix rims from the '90s that are my most difficult to mount tires to. I presumed that it's because they're just a slight smidge larger than my other rims (in terms of bead seat diameter), and the tire doesn't seat evenly around the circumference without a lot of coaxing. I have other rims where the tire seems to simply mount itself...and airs up straight the first time without a lot of air pressure.
The same tires I had trouble mounting before seem to mount easier since I removed the old Velox (which did wrap up towards the rim wall) and replace it with mylar/tubeless rim tape. I chalked this up to reducing the rim diameter as much as I could (especially down in the spoke valley) by using thinner rim tape. My experience is apparently not universal. Studying the theory of what should and should not work best, regardless of anyone's lived experience, is pretty interesting to me.
Liked 749 Times
Thinking more about what you're saying HTupolev I see what you're saying -- tires that mount with a hop or sag aren't non-uniform because the bead isn't getting up on the bead seat area itself...they're non-uniform because the bead isn't coaxed to "sit up tall" against the rim hook -- and this is where the extra thickness of something like Velox should help? Interesting... Maybe I need to re-examine what I thought I've learned over the years.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
It's too bad more (non-tubeless) rims weren't made like these Araya 20As. They're double-walled rims, with a shallow 10mm channel for the rim tape. The tape stays put and doesn't interfere with the mounting of the tires at all. They're a joy to use.
Likes For ThermionicScott:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 900 Post(s)
Liked 1,842 Times
bumping this up so what size Velox tape would be best on this wheel, 16mm or 22mm? tube type 18.6mm inner width. my gut says 16mm but brain says 22mm.
https://www.velocityusa.com/product/rims/dyad-26
Liked 2,816 Times
Senior member
Quoted: 937 Post(s)
Liked 652 Times
Velocity offers two widths of Velotape and lists the rims each is suitable for on their website.
https://www.velocityusa.com/product/...ries/velotape1
Likes For Dan Burkhart:
Quoted: 900 Post(s)
Liked 1,842 Times
Likes For jadmt:
