Power Meter Solution for 2 Road Bikes?
#76
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I got an email from Favero that they just release the "Duo-Shi" which allows you to mount the Favero meter spindle into Shimano pedals ..
that's some weird internet timing, but a cool sounding product
https://cycling.favero.com/shop/assioma-duo-shi
Likes For Broctoon:
#77
Quoted: 16 Post(s)
A friend of mine uses this...Interesting little device and easily swaps between bikes as it has the capability for multiple bike setup.
https://powermetercity.com/product/p...d-power-meter/
SparkyCanada
#78
Quoted: 18883 Post(s)
Liked 10,646 Times
That's a lot to pay for estimated power. Strava does it for free.
#79
not real-time while you're riding, which is where you'll get the most benefit from having a power meter. Plus, the Strava estimates, while good, are much less accurate than a power meter and can't account for many things like wind
#80
No love for PowerPods? DCRainmaker says "it can be solidly accurate", it's cheap and easily swappable between bikes. Maybe not good enough for serious training but if you're just curious about your in-flight power then it should do the trick. I'm happy with mine, but I just use it as a reminder not to get lazy.
Likes For mplee:
#81
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4376 Post(s)
Liked 3,013 Times
"Assioma DUO-Shi is compatible with the following Shimano® pedal bodies: PD-R8000, PD-R7000, PD-6800, PD-R550 and PD-R540."
#82
Liked 10,646 Times
There's a data field for Garmins that will estimate your power in real time. I don't think these different estimates are fundamentally different, one may have some modest insight into wind conditions but doesn't know your body position, whether you're drafting, or what your rolling resistance is like.
#83
I'm thinking I might pull the trigger on a Garmin Rally RS100. I did see a review with the Youtuber Shane Miller
It indicated a slight accuracy issue with the Garmin Rally pedals? Has anyone heard anything that backs up his findings or has anyone seen any field reports on their performance? I wasn't aware the Garmin Vectors had so many problems.
