Dura Ace bearings? ( DA 7400 bottom bracket)
Old 10-29-13, 11:06 AM
ModeratedUser
Quoted: 54 Post(s)
Hello all,
I'm working on a Dura Ace 7400 bottom bracket and I'm looking to replace the bearings. I was at my LBS yesterday (without my parts) and was looking around at what was offered. They pretty much told me that there really isn't any "quality" bearings I can get. They mentioned ceramics but that's not what I had in mind. So is there any bearings I should be looking at and any I should be staying away from?
Thanks for any and all responses. They will always be most welcomed.
ModeratedUser is offline
Old 10-29-13, 11:43 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,345 Times in 852 Posts
.. as a Loose Ball cup and cone BB you just need to get a set of fresh Bearing Balls of same size
[typically 0.25"]
[aside]Decades ago, I got a thousand grade 25 in a small bag At an Industrial Bearing Supply stores*
rather than Bike shops, for my own use, (* LA/Long Beach there will be several)
but working in Bike shops the ordering of a plastic jar of them is convenient ,
and they come with the rest of the parts orders.]
NOW, If the races on the axle , and the cups in the frame are unDamaged..
to determine this, you have to clean them
and inspect.
leave the right / fixed cup in place, unless damaged, it does not have to come out..
fietsbob is offline
Old 10-29-13, 01:32 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3242 Post(s)
Liked 2,643 Times in 1,535 Posts
Grade 25 1/4" steel balls should be a stock item at any decent bike shop. If your shop doesn't have them, it's time to find a better shop.
JohnDThompson is offline
Ex Pres
Cat 6
Ex Pres's Avatar
Quoted: 492 Post(s)
Liked 161 Times in 107 Posts
Grade 25 1/4" balls should be a stock item at any decent bike shop. If your shop doesn't have them, it's time to find a better shop.
+1000
Ex Pres is offline
Old 10-29-13, 01:33 PM
FBinNY
Quoted: 4884 Post(s)
Liked 924 Times in 554 Posts
Originally Posted by User1 View Post
Hello all,
The "bearings" are the bottom bracket and spindle themselves. All you need is a set of 1/4" balls, and some grease. I can't believe that the shop didn't have these for you, and ceramic balls would cost you more and not help since it's the races (spindle and cups) that wear, not the balls.
Shop around and buy a bag of Grade 25 1/4" balls (confirm size), and load them loose using the grease to keep them home until the spindle is in. Grade 25 is way better than necessary, but the difference in cost is small enough that you might as well go 1st class. The retainer doesn't serve any function save for ease and speed in assembly.
As said above, leave the left cup in place, and simply clean the inside thoroughly.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 10-29-13, 03:47 PM
ModeratedUser
Quoted: 54 Post(s)
Sorry, I didn't mean to lead on that the shop didn't have the bearings. I just didn't have my parts with me when I stopped in. Thought I'd just shop around. I'm sure what they showed me is what I'm going to pick up. I'll call around for the grade 25 bearings and see anyone has these first.
Thanks everyone for the feedback. Most helpful!
Old 10-29-13, 05:18 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 184 Post(s)
Liked 89 Times in 74 Posts
The shop saying there aren't any "quality bearings" and suggesting ceramic says they have no idea what they're talking about. Go to a different shop.
I buy grade 25 balls on ebay, I got a 150 count bottle for $10 or something. Enough to do several BBs and hubs.
FastJake is offline
Old 10-30-13, 07:18 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1493 Post(s)
Liked 700 Times in 495 Posts
LOL, FB works on his bikes upside-down
Hang on, it's FB here...
/googles manual page
Yeah, what I said
...No, wait - that could be some sly old-timery workaround to avoid adjusting the BB again.
Damn you, FB!
/shakes fist
One day!
Kimmo is offline
CmereTme
Track Cycling: Velodrome Racing and Training Area
2
08-30-18 05:33 AM
CliffordK
Bicycle Mechanics
3
11-01-17 05:22 PM
lowlux
Bicycle Mechanics
12
07-14-17 02:26 PM
stan_road
Bicycle Mechanics
19
03-12-17 07:27 AM
Nagrom_
Bicycle Mechanics
2
06-25-12 02:49 PM
