Raleigh 575sl want to give some insight if I can.
Old 11-03-21, 10:21 AM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1762 Post(s)
Liked 2,870 Times in 1,342 Posts
I just picked up a USA Raleigh Olympian with the tube decal 575sl. I know this is a made up tube set name but I always wondered what it really was. I don't have the bike home yet but I will update with seatpost diameter when I get home. It's an extremely well made frameset with functional entry level components... Shimano light action12 speed and diacomp quick release sidepulls. A sakae sa crank and laprade seatpost. Hopefully not stuck.
52telecaster is offline
Likes For 52telecaster:
Old 11-03-21, 11:55 AM
T-Mar
Quoted: 4710 Post(s)
Liked 2,999 Times in 1,854 Posts
Give the era and level of the bicycle, I suspect it is one of the seamed, CrMo tubesets. I can't tell if the decal says double, triple or quadruple butted. Ishiwata's seamed CrMo tubesets of this era were either triple butted (EX series) or quadruple buttted (EXO series). Both EX and EXO came in three different gauges and also a tretubi and carbon-manganese version. Double butting would more likely be Tange (900, 1000 or Infinity). Tange 900 was basically a seamed version of #1, while 1000 was basically a seamed version of #2.
I notice the decal mentions "main tubes", so presumably it's using lower grade material in the forks and stays, either carbon-manganese or hi-tensile steel. That's not uncommon, given the era and level.
The "SL" designation implies a lighter gauge set. Assuming Tange, that suggests 900. The lightest Ishiwata sets were EX-F or EXO-L. Of course, we can't rule out the possibility that it truly was a custom set and that it wasn't just a rebadged or slightly modified standard offering.
T-Mar is offline
Likes For T-Mar:
Old 11-03-21, 01:53 PM
scarlson
scarlson's Avatar
Quoted: 935 Post(s)
Liked 1,372 Times in 697 Posts
I always thought this tubing was pretty good. The mixte version of the Raleigh Olympian is one of the best mixte frames available, in my experience - and that's partially owing to the decent quality tubing. It was surprisingly light, although I couldn't give you an exact measurement. I know a couple people who really love theirs, both mixte version and regular diamond frame. I spread one Raleigh Olympian 575sl mixte to 135mm and it was much stiffer and harder to do than your average hi-tensile frame. Felt a bit more like a midlevel Japanese bike, but not quite as stiff as a 531 rear triangle. I felt one of these bikes was good enough to justify brazing on some canti posts and rack mounts for the owner.
Here's another thread about it, in case you haven't seen it.
scarlson is offline
Likes For scarlson:
Old 11-03-21, 02:14 PM
zukahn1
zukahn1's Avatar
Quoted: 677 Post(s)
Liked 1,179 Times in 469 Posts
RBCA made bikes of this era had slightly oversized double butted sl cro-mo main tubes and strait gauge 4120 stays and seat tube. Most of the Raliegh Amercan stuff had mixed tubing. Very well made sturdy great riding frames. Most of these had a 26.4 seatpost.
zukahn1 is offline
Likes For zukahn1:
Old 11-03-21, 04:33 PM
52telecaster
ambulatory senior
The seat post comes out!!! And it's 26.6 also the sticker says triple butted. The frame with components is certainly light enough. It seems to be as well made as my 81 miyata 912. Of course that 912 had a high tensile fork. Also the brake reach is fairly tight. I'm guessing 1 1/4 x27 would make fenders very close. Of course if I build it it will have 700c. Anyway thanks for all the info.
Old 11-03-21, 04:41 PM
52telecaster
ambulatory senior
Down tube brazeons
Double eyelets in front
Raleigh branded sealed hubs
Old 11-03-21, 04:58 PM
3speedslow
3speedslow's Avatar
Bikes: A few
Quoted: 1906 Post(s)
Liked 931 Times in 569 Posts
Raleigh branding on those are EVERYWHERE!
seriously would love to get my hands on one of those. Awesome colour!
3speedslow is offline
Likes For 3speedslow:
Old 11-03-21, 05:12 PM
52telecaster
ambulatory senior
I'm going to give it a good clean and if the hubs are sound I may build new rims around at least the back one. Lately I am enjoying old suntour freewheels.
Old 11-03-21, 05:38 PM
OldCoot
Bikes: 82 Univega Specialissima, Bike Friday Pocket Rocket, Kona Wheelhouse, Rocky Mtn Thunderbolt, Viner Strada Bianca, ~73 Bob Jackson, ~75 Volkscycle Mark100.
Quoted: 44 Post(s)
Liked 123 Times in 49 Posts
I have had an 1985 Grand Prix and it was labeled 555sl. While one might assume since 575sl is a higher number it would better tubing... Yet, I think that would be a dangerous conclusion, especially in light of the fact that the Olympian was a 'lesser' model ( at least in an 1985 catalog). Raleigh just came up with their own labeling system. I never found anything definitive regarding this re-labeled tubing. The bike was quite stiff.... almost dead , which to me means thick tubes ( modulus of elasticity is almost identical across all steels, so similar external diameter tubes, a set of tubes to be stiffer must have thicker walls...). Do you know what year it is?
OldCoot is offline
Likes For OldCoot:
Old 11-03-21, 06:47 PM
52telecaster
ambulatory senior
I don't know but the 84 Olympian had a claw for the rear derailleur and stem shifters with Raleigh (502).
This one has down tube bosses, cast dropouts with a derailleur hanger and the 575sl. It doesn't show up in the 85 or 86 catalogue this way so it may be later.
Old 11-03-21, 09:15 PM
Schreck83
Schreck83's Avatar
Quoted: 141 Post(s)
Liked 228 Times in 124 Posts
One time I counted how many instances of the name "Raleigh" were on my Alyeska. I don't remember the count but I'm sure it was more than 30. Idea for a new thread: how branded is your bike?
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
Schreck83 is offline
Likes For Schreck83:
Old 11-03-21, 09:32 PM
52telecaster
ambulatory senior
It is quite ridiculous. Almost as of they are trying to convince us it really is a Raleigh.
Old 11-04-21, 10:57 AM
3speedslow
3speedslow's Avatar
Bikes: A few
When are we going to get a full frame shot.
Old 11-04-21, 12:01 PM
scarlson
scarlson's Avatar
Quoted: 935 Post(s)
Also funny how much the 575SL decal is made to look like a Reynolds decal. When I first saw one, years ago, I thought it was Reynolds until I did a double-take and saw that it said Raleigh.
But, for all our ridicule, I do appreciate these bikes and I think they are pretty decent quality.
scarlson is offline
Likes For scarlson:
Old 11-04-21, 12:43 PM
52telecaster
ambulatory senior
Decent clearance with 38s and a tektro 559 will reach.
Full shot with 700c upfront and 650b in back.... Decisions decisions...
Old 11-04-21, 12:45 PM
52telecaster
ambulatory senior
I think they are too. In particular the later ones. It seems they got upspecced as the years went by. I'm curious to see what it's like with good stuff.
Old 11-04-21, 12:46 PM
52telecaster
ambulatory senior
Got it with the wrong wheels.
Old 11-04-21, 02:34 PM
scarlson
scarlson's Avatar
Quoted: 935 Post(s)
Yeah these really don't have very good clearances with the 27" wheels they came with! But, I have done 700c and 650b to the mixte version I talked about earlier, and they are both good. The BB seemed pretty high so 650b didn't seem like a problem.
Now why stop at 38s and sidepulls? Gugificazione with cantis and a bit more aggressive indenting will get you to 42s and fenders, no problem. Could even rake up the fork a little to lower the trail. You'll have yourself a nice faux Herse!
scarlson is offline
Likes For scarlson:
Old 11-04-21, 03:14 PM
52telecaster
ambulatory senior
I have other frames I would do that with if I were to go that far but it is definitely a worthwhile frame.
Old 11-04-21, 10:27 PM
OldCoot
Quoted: 44 Post(s)
After poking around in Raleigh catalogs, This is the same color combo as shown in the 1983 catalog. The specs for that year just call out "Raleigh engineered" chrome moly tubes. No statement about butting of tubes or not. Still these asian made Raleighs were and good value in my estimation. Always enjoyed the pantographed on top of the forks. Nice touch at this level.
Enjoy the bike.
OldCoot is offline
Old 11-04-21, 10:33 PM
52telecaster
ambulatory senior
Enjoy the bike.
In a package I was giving with the bike they had a 1986 owners manual. What confuses me is the 86 catalogue shows the downtime shifters and rear derailleur hanger but calls the tubing 555sl. This one has the 575sl sticker. Who knows if the catalogue right or not. Going to clean it up and may set it up as 650b.
Old 11-05-21, 08:04 AM
OldCoot
Quoted: 44 Post(s)
Hmmmm.... U have also owned a Supercourse and Grand Prix from 1986, which is when they went Reynolds 531 butted main tubes. Sure enough catalog says 555 for the Olympian. Misprint in catalog or the label, or maybe an intentional mid year switch? Nice that you can squeeze in fat tires. The Supercourse and Grand Prix maxed out 700c x 25c ( brake clearance issue).
OldCoot is offline
Likes For OldCoot:
Old 11-05-21, 08:09 AM
52telecaster
ambulatory senior
It was specced with 27s so it has a bit more room. I actually own a 73 competition and super course. They are wonderful riding machines.
This morning I removed the bottom bracket on the Olympic and it was in decent shape but I am installing an idle grand Crue crank and bottom bracket. The bike is getting significantly lighter.
Old 11-05-21, 10:04 AM
dweenk
dweenk's Avatar
Quoted: 878 Post(s)
Liked 319 Times in 217 Posts
My Olympian with 650B's and fenders. Same color too.
I hope...that all mankind will at length…have reason and sense enough to settle their differences without cutting throats. Ben Franklin
dweenk is offline
Likes For dweenk:
Old 11-05-21, 10:14 AM
52telecaster
ambulatory senior
Looks great. What brakes did you use?
