Saddle heights I see out there many times seems to be so high
Quite often, when I see other peoples bikes (road, gravel, cyclocross) i notice how often their saddles seem to be super high. If you look from the side, it looks like the saddle is WAY above the handles, whereas my bike (Trek Checkpoint ALR5) the saddle is maybe just slightly above the handles (and i've been fitted twice). Are many of these saddles I'm seeing out there simply too high or maybe it's just a different frame design to my Trek gravel bike? It kinda looks 'cooler' with the saddle all high but obviously this isn't important at all
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,243 Times
Has nothing to do with Handel bars height.
We all have different leg lengths.
Fred "The Real Fred"
Likes For 10 Wheels:
I'm aware of that, of course, but the vast majority of these bikes I see, it's almost always so disproportionate (saddle vs. handle bars)
Quoted: 2333 Post(s)
Liked 2,097 Times
Slamming the stem to get the handles down low is the macho thing to do.....says the old rider with 25 mm of spacers and 16 degrees up stem. Younger riders can get low and flat, which can be faster
Likes For GhostRider62:
only here for the "LIKES"
Quoted: 1642 Post(s)
Liked 2,235 Times
Likes For hazetguy:
Berg417448, BlazingPedals, BobbyG, BobsPoprad, Buzzkill53120, cabledawg, caloso, ehcoplex, Fahrenheit531, guachi, indyfabz, Inusuit, jaxgtr, Kedosto, Koyote, MattTheHat, MoAlpha, mschwett, nick_a, phughes, Polaris OBark, Reynolds, rm -rf, Road Fan, rosefarts, Route 66, rsbob, SalsaShark, ThermionicScott, Trsnrtr, urbanknight
Quoted: 1364 Post(s)
Liked 1,677 Times
Next thing you know they'll be wearing their pants below their butts.
Likes For BobbyG:
Quoted: 236 Post(s)
Liked 196 Times
Different bike geometries / rider positions.
Checkpoint is more of an endurance geometry (related to the Domane) and not as aggressively aero as the geometry of a race/speed oriented bike.
Quoted: 1943 Post(s)
Liked 2,164 Times
It’s not the saddle height, it’s the bar height.
John
John
Likes For 70sSanO:
Quoted: 427 Post(s)
Liked 699 Times
Saddle height is set (or should be) for the most efficient position in relation to the pedals. Some road bikes may have a short steerer which may not allow the rider to add spacers under the stem. Assuming the top tube is the correct length for the rider, then the rider is either: finding the handlebar position comfortable, or adapting to the position, or doesn't realize they could go with a shorter stem with more rise.
Sunshine
Quoted: 10956 Post(s)
Liked 7,485 Times
It may be a cool/macho thing for some to do, but I dont think its the motivation for most.
Saddle height should be set for an efficient and comfortable pedal stroke.
Separate from that, bar height should be set for comfort and intended use.
People with more flexibility and with more core strength often have bars lower because they are comfortable in that lower position. Also, taller riders often have a bigger saddle to bar drop than shorter riders due to body proportions and frame geometry.
I think it is pretty absurd for your takeaway to be that so many do it to look cool, especially when posters have taken time to explain the varying reasons.
Quoted: 6193 Post(s)
Liked 4,808 Times
If you ride a lot and you ride fairly hard and you compete against yourself to get better times, then you quickly will see that being more aero allows you to go faster for the same effort or farther with less effort.
The bikes don't have unusually high saddles, what they have is a lower frame stack height allowing the bars to be lower.
Likes For Iride01:
Sunshine
Liked 7,485 Times
Likes For mstateglfr:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
In general, the racier the bike the greater the drop from saddle to bar, but that depends entirely on what kind of bike we're talking about and its intended purpose.
BMX saddles are slammed to the frame with 11" tall handlebars, because riders rarely if ever sit. Observed Trials bikes don't have saddles at all. A time trial bike is designed to flatten the back of the rider as much as possible for aerodynamics. Mountain bike riser handlebars have heights that are all over the map, as well as dropper posts that lower the saddle height to well below the bar height.
I think manufacturers like to photograph their bikes with a lower bar because it gives the bike a more aggressive stance. Some people take that as an indication that their own bike should be configured similarly.
Likes For Rolla:
Quoted: 3352 Post(s)
Liked 1,056 Times
I grew up on a farm. With the saddle all jacked up like, and with their heads clear down, it reminds me of and old hen picking corn out of a cow pie.
Guest
Liked 3,270 Times
With their legs out front and their ass on the ground, recumbent riders remind me of a dog scooting its butt on the carpet.
Likes For Rolla:
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 408 Times
Riding a frame that a size or two smaller than what you'd normally ride for your height will also give your that big saddle to bar drop. Pros do this all the time as it gives them a much more aero position when on the saddle. Most recreational riders cannot sustain this position for a long time because they are 1. not flexible enough, 2. don't have sufficient core strength, and 3. don't produce enough sustained power in the legs to relieve the pressure off of hands.
Likes For mcours2006:
Quoted: 18411 Post(s)
Liked 15,531 Times
Likes For indyfabz:
Liked 15,531 Times
Likes For indyfabz:
Likes For eaglesandcycling:
Liked 15,531 Times
Likes For indyfabz:
Liked 2,164 Times
But I imagine, in some cases, slamming one's bars might make the rider feel like a messiah.
John
Likes For 70sSanO:
