Ruler and Chain Checker are Diverging
I measured the chain wear on one of my bikes today. On the Pedro Chain Checker Plus II, the #3 hook is easily going into links, which indicates a wear rate greater than .75%. However, when I measured the chain wear with a ruler, it only stretched by 1/32 of an inch. Based on these measurements, should I replace the chain immediately? Or, can I get a little bit more life out of my chain?
Really Old Senior Member
Ruler trumps chain checker.
Use the checker for a quick check. You now know that it reads .25% high on the .75% scale.
Not uncommon at all for them to be "generous".
You might want to use a 3' section of tape measure. It'll give you 3X the resolution vs checking a 12" section. I use the 1 & 37" marks to avoid dealing with the hook.
That would give a little better idea of the chain checkers true error.
Likes For Bill Kapaun:
Quoted: 4369 Post(s)
Liked 1,546 Times
Chain checker trumps a ruler. You're attempting to avoid wearing out your sprockets, and sprockets run on the rollers the checker measures, not the pins a ruler measures.
And this is what that looks like when there is no pin stretch (ruler) but roller wear:
Likes For Kontact:
Quoted: 506 Post(s)
Liked 638 Times
While Kontact is theoretically correct his example assumes a significantly different wear rate on rollers vs. pins, which is not the case. There are lots of examples of chain checkers being wrong, but rulers never lie.
Likes For KerryIrons:
Liked 1,546 Times
The rule for chain replacement is 1/16" elongation, so your ruler is saying 50% and the chain checker is saying 75% (and might have read 25% on a brand new chain). And don't get confused that there is a magic "worn vs. not worn" point. Wear is linear, not digital. Things don't instantaneously get bad when chain wear crosses a threshold.
What examples do you have of chain checkers being wrong? How did you test that they were wrong?
And the whole 25% thing is a canard. It doesn't matter what the chain measures until that measure exceeds whatever tolerance the manufacturer recommends as "No go". We don't measure the chain to monitor its wear - that wear might not be linear. We measure the chain to take note of whether it is still in-spec or not. When it is not, you replace it to keep the rest of the drivetrain in shape.
Likes For Kontact:
Quoted: 2333 Post(s)
Liked 2,097 Times
Chain wear absolutely 100% is not linear.
The easiest way to measure for me is hanging the entire cleaned chain against a new one. Measure in mm with one of those digital vernier caliper thingies. Makes the math easier.
My eyeballs are not so good at 1/32, they like 5 or 6 mm better
Quoted: 506 Post(s)
Liked 638 Times
My example shows how roller wear alone can damage the sprockets. But roller wear AND pin wear don't cancel each other out - together they are going to produce the geometrical effect depicted in the graphic - that the pitch of the chain is effectively different when curved around a sprocket.
Over the decades lots of people have reported their chain checker showing 75% wear on a brand new chain. That sounds wrong to me.
Quoted: 506 Post(s)
Liked 638 Times
There is no need to be able to see 1/32" since it is 1/16" that is considered the replacement point. That is easy to see in a 12" length of chain, even with a cheap ruler that has only 1/8" gradations. There's no need to remove, clean, and hand a chain to see if it is worn out. Just measure it on the bike.
Liked 1,546 Times
Some chain checkers may be out of spec. When I ran service departments I rounded up all the chain checkers and allowed only one model to be used, then checked all examples as behaving the same on several examples of worn and new chains. There is little chance that four Park CC 3.2 are all wrong and by exactly the same amount.
A home mechanic would be wise to check their tool against new chains as well.
Elongation alone may work fine - if the rollers hold up as well as the part of the chain that's being measured. If the rollers wear faster than the pins and links, then you're measuring the wrong thing.
The goal here is to replace your chain before it puts unnecessary wear on other components. I have yet to hear anyone complain that their chain checker caused them to replace their properly lubricated chain every 500 miles.
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
There’s also the problem of how the chain is measured with a rule. If the chain slack or tight? If it is slack, that’s going to throw off the measurement. Tight will give you a better measurement, something that chain checkers do automatically. The advantages of a chain checker are that it tightens the chain and it doesn’t depend on reading anything.
Some people suggest using a 12” rule and then estimating that last 1/16”. Estimating anything is by definition not accurate. Additionally 1/16” is only 0.5% wear. Most chain checkers will give 0.75% as the no go measurement for 10 speed and lower chains and 0.5% wear for 11 to 12 speed chains. 0.75% on a chain would be 3/32”, not 1/16”. That’s even harder to measure and especially to “estimate”
I was not suggesting that roller and pin wear cancel each other out. I'm simply stating that chains don't exclusively wear on one or the other, which would be the argument that a ruler is not a good way to measure chain wear. If the chain is wearing, the rollers are wearing AND the pins are wearing and the ruler will show the latter, which is a good marker for roller wear as well. For years Campagnolo used simple elongation as the measurement for wear. While roller wear might be slightly more precise than just length, most chain checkers offer no real advantage over a ruler and several mislead the user.
Stuart Black
Stuart Black
Likes For cyccommute:
Clark W. Griswold
Quoted: 4343 Post(s)
Liked 3,978 Times
Also make sure the chain is nice and clean before using a chain checker. I am sure a straight edge measuring tool is a fine tool but the chain checker is generally my go to so long as you have a clean chain. However anything can be inaccurate like cyccommute said it just depends on the user and the quality of instruments.
Quoted: 2601 Post(s)
Liked 1,925 Times
My normal routine is to use a chain gauge (coincidentally, the CC-3.2 @Kontact mentioned) to find out if it's time to break out the ruler. However . . .
Using a ruler isn't automatic. I'll go with a longer rule, such as a measuring tape or the Park SBC-1, so I can center the beginning (1" on the tape or the triangle on the Park) on a rivet. Measure to the center of the '12" rivet', then go back and make sure the beginning mark didn't shift. Repeat at least one more time to make sure you've got the right measure. Or you can measure to one end or the other of the rivet, if you're not sure you can eyeball the middle of a rivet accurately.
And then go measure another one or two 12" sections of chain, to see if the measurements match or are longer than you want the chain to be to stay on the bike. If there's significant divergence, go with the longer measurement IME, and replace the chain.
IIRC the Pedros tool is supposed to take roller slop out of the measurement, FWIW.
My guess is that your "ruler" moved while you looked from one end to the other. That's one free opinion that's worth everything you paid for it!
Liked 2,097 Times
My "linear" comment was meant to be a contrast with the "go/no-go" mindset induced by chain checkers. I don't know that anyone has ever published research showing that the rate of chain wear somehow changes as the mileage increases, but perhaps you can share what you know.
aside from measurement sensitivity, crude inside will invalidate the measurement
Measuring 24 links of chain requires good light, sharp eyes, and sometimes reading glasses. You need to clean the chain and measure it with a rule or a set of calipers. This method, quite obviously, is less convenient than simply using a chain gauge.
Sr Member on Sr bikes
I find it interesting that people who staunchly rely on dedicated brandname bicycle tools like Park or Pedro’s won’t trust the chain checking tools from those companies. I mean they produce accurate tools for every other aspect of bicycle maintenance…including torque wrenches for delicate CF fixtures. But for some reason their chain checkers can’t be trusted??? I even know of one case where a person deferred to a Park Tool ruler instead of a chain checking tool. If the chain checker is supposedly inaccurate…who’s to say the ruler sold by the same company isn’t inaccurate?
Dan
Dan
Likes For _ForceD_:
Expired Member
Quoted: 3658 Post(s)
Liked 5,404 Times
I've found the newer Park CC 3.2 with the .5 measurement easy to use and sufficient. I wouldn't discourage anyone from using a ruler but how do you find one to trust? Is a HF China- made assumed to be accurate? Or is it accurate enough, same as a tool?
Liked 1,925 Times
If this is aimed at my post, the answer's simple. There've been many laborious threads on why chain checkers aren't reliabile, having to do with precisely what is being measured. The Park chain checker works well for me as a gross check, but roller wear means that after the 0.5% mark, I trust a ruler more than any chain checker.
Dan
Quoted: 960 Post(s)
Liked 1,626 Times
I am one of those guys that buys economical freewheels and chains. I also ride allot of dusty trails so I end up cleaning my chains frequently. I have wasted my money on three different chain-wear tools and none of them beat my ruler so I am sticking with that. Further more I have finally learned that replacing bike chains is much better then replacing cogs and rings. Bill's 3' trick is one I am going to use from now on...
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1236 Post(s)
Liked 318 Times
I've never used a chain checker clown device. Never will. LOL.
Measuring any distance more than 12" is just plain dumb. Slackness will make a difference.
Of course you look at 10" to 22" or something, using a roll tape measure is best.
My last 1/8" IGH chain has never had any lube in over 3,000 miles. Lubes all suck dirt.
Expired Member
Liked 5,404 Times
Liked 4,212 Times
Unfortunately, people don’t read the manual. From Park
- 5-to-10-speed chains: replace chain at or just before 0.75%
- 11-to-12-speed chains*: replace at or just before 0.5%
Stuart Black
Stuart Black
Liked 2,097 Times
5mm is easy to measure with my micrometer.
Clean the chain and hang it side by side with a new chain.
5mm is 0.4% and time for a new one.
A nail is cheaper than a Park go/no go gauge
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
1/32 inch is only half time. Replace when it wears 1/16 inch.
Good write up and illustrations below:
https://atbicycle.blogspot.com/2014/0...nch-ruler.html
New chain:
Worn 1/16 inch - Replace chain.
Worn 1/8 inch - Your cassette is probably trashed at this point.
Likes For Lombard:
Sock Puppet
Liked 863 Times
I find it interesting that people who staunchly rely on dedicated brandname bicycle tools like Park or Pedro’s won’t trust the chain checking tools from those companies. I mean they produce accurate tools for every other aspect of bicycle maintenance…including torque wrenches............
Liked 4,212 Times
I’m glad you posted the pictures below. It will illustrate my point about the 12” rule nonsense. I don’t usually leave the pictures in a quote but I’ll do so here.
Bicycle: Measuring Chain Wear using a 12-Inch Ruler
New chain:
New chain:
Stuart Black
Stuart Black
