Crank bolt cover/BB
Crank bolt cover/BB
I want to disassemble this to service BB.
1) Does the crankbolt cover unscrew or pry out? I would like to not damage this if possible.
2) Is this tool what I need to remove the lockring on the BB? I know I can get it off with a punch or pipe wrench but would like to do it properly.
3) After the lockring comes off, is there a specific tool to remove the next part, or can I do it with a large adjustable wrench?
Amazon.com : Park Tool (109917) HCW-5 Lock Spanner : Bike Hand Tools : Sports & Outdoors
Happy With My Bikes
Quoted: 868 Post(s)
Liked 2,278 Times
The cap should remove with a dime or large screwdriver. It may be stuck pretty well and some damage may occur. Can't say exactly but that appears to be an appropriate spanner for the lock ring. You will also need a crank arm puller.
Likes For Chuck M:
Quoted: 5703 Post(s)
Liked 2,432 Times
It's supposed to screw out. Use something wide, like a quarter. A narrower screwdriver blade will likely gouge the plastic.
Worst case, they can also be pried out without damaging the crank's threads.
Likes For FBinNY:
Thanks. I do have a crank puller. I have taken this type of BB apart before, but always on bikes where it didn't matter if there were to marks left on the parts. Just trying to do it right (for a change )
Happy With My Bikes
Quoted: 868 Post(s)
Liked 2,278 Times
You will never know if it is done right in the age of Internet forums. People will debate argue if leaving the fixed cup on the other side alone or removing it too is the right way. I'm middle of the road on it. If it comes out great, but if it is going to take a lot of force and I'm not painting the frame, I leave well enough alone.
Quoted: 4260 Post(s)
Liked 1,458 Times
This is a very standard BB type. Please go to the Park website and read the tutorial, then buy the correct tools. The questions you're asking suggest you are about to damage something out of a lack of familiarity.
Quoted: 3431 Post(s)
Liked 2,826 Times
Those dust covers are plentiful on eBay, should you damage it.
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
If you're lucky, the cup will not be too difficult to remove, in which case a 16mm cone wrench or even an adjustable wrench may work, if you're careful.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
if it's a really old plastic cover, it will be brittle.. they crack 6 times out of ten tries.
when the outer portion of the cover breaks away, i've had to chisel the remaining threaded sections out many times.
the trick is to not damage the crank's threads.... and to work within the confine created by the nut or bolt holding the crank on the spindle...
Sometimes you can remove the nut or bolt first... it requires a thin walled, 14mm socket.
Old guy & bikes
Liked 739 Times
actually, no, you don't... but it sure helps.
and there are times when you CAN'T remove the nut since it's trapped by the cap's threaded section and there's no room to insert a socket.
i have about 75 bikes loaded in a trailer to be hauled to the scrap yard that say i know this subject well.
i use a specially ordered Snap-on Flat blade Screwdriver socket to remove the slotted caps.. the tip is @ 3/4' wide... i bought that tool to adjust mower reel bearings on an old Jacobsen Gang Mower.
what do you use?
what do you use?
Quoted: 444 Post(s)
Liked 404 Times
Liked 2,826 Times
