Singlespeed Conversion Help!
Quoted: 21 Post(s)
Liked 9 Times
Hi guys,
I have a BTWIN Rockrider 540 that I am converting to singlespeed. So far, I have the sprocket and spacers ordered and the chain from Amazon. I have two main questions that I hope can be answered. I am a complete beginner at bike engineering so forgive any ignorance that may come across.
Q1. I am aware that because my bike has vertical dropouts, that I'll need a chain tensioner. How can I go about figuring out if this will attach to my bike or not? I took the rear derailleur off and it appears I may need a derailleur hanger to attach a tensioner to, or am I overthinking things?
Q2. Currently, I have the standard 3 piece crank set that came with the bike still attached. I noticed that on the middle cog, there are 32 teeth. Would it be possible to get away with just wrapping the chain around this, instead of having to order a single speed chain ring?
Thanks in advance.
Thanks in advance.
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
1- a chain tensioner typically mounts to the same hole that a rear derailleur threads into. Just put your hanger back on the bike.
2- If you use the middle ring of your current crankset, you need to make sure the chain is shortened to accommodate for the smaller ring. Also, that middle ring is usually ramped to aid in easy shifting. This means it is not designed to hold onto the chain, and with single speed you want to hold onto the chain.
Personally? I would question if single speed with a chain tensioner is worth the time and result. You lose out on the direct feel of single speed when you have a chain tensioner. And I would buy a narrow-wide chainring to hold the chain better then remove the other rings up front.
If you are going to just have a tensioner and keep your current triple crankset, why do the conversion at all? Just ride the bike as is in whatever single gear you want and call it good. Just dont shift and you will have the same setup you are spending time and money on achieving.
Likes For mstateglfr:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
This is obviously a mechanical thread and should be posted in 'bicycle mechanics' not GD.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Bikes: 70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, '11 Shimano Masi Partenza
Quoted: 109 Post(s)
Liked 19 Times
Quoted: 21 Post(s)
Liked 9 Times
Sunshine
Liked 7,473 Times
Its easier to not swim upstream.
Quoted: 21 Post(s)
Liked 9 Times
Anything about gravel bikes should be in the gravel cx forum, anything about bikes from 30+ years ago should be in the involved forum, anything about road bikes should be in the road forum, anything about hybrids should be in the hybrid forum, etc etc etc.
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
48/18 is more typical for single speed on a 700C road bike. About 72 gear inches. It’s at the upper end of what I would use in our moderately hilly terrain.
Something more like a 2:1 ratio or less and about 50 gear inches or so would be more typical for a SS MTB, assuming it’s to be ridden on single track. The recommendation for 34/18 on 27.5 wheels is right about there at just over 50 gear inches.
Otto
Otto
Quoted: 21 Post(s)
Liked 9 Times
That’s a huge gear for a single speed
Should probably contemplate more like a 34 x 18
But depends on how big your wheels are
And I would ditch the rear derailer and go with the tensioner also. Especially if you’re talking about saving a couple of grams
Or else why not just convert it to a one-by drive train
Quoted: 21 Post(s)
Liked 9 Times
Updating this thread incase anyone stumbles accros it from Google. A 34 tooth chainring with an 18 tooth rear cog is WAY too easy to pedal. I'm not sure why people are recommending this ratio, maybe I just ride differently? The terrain where I live is flat and then some uphill but there's barely any resistance whilst pedaling. If you're like me and like to really work yourself with not sitting down and constantly powering through uphil gradients, then definitely go for a higher toothed chainring. I'm ordering a 40 tooth and will update further with the results.
Quoted: 4227 Post(s)
Liked 2,488 Times
Quoted: 21 Post(s)
Liked 9 Times
I would recommend starting out with a gear ratio of around 63 - 65 gear inches...To achieve this ratio you will need a 42 or 44 chainring up front and a 18 tooth rear cog....34 x18 ratio which you have right now is good for singletrack and off road use and not for pavement.
Quoted: 21 Post(s)
Liked 9 Times
Update: I am now using a 42T chainring and 18T rear cog and the pedalling is much better. It's actually still a little bit too easy, so I'm downsizing the rear cog to 14T.
So in the end, I went with 14 teeth on the rear cog and 42 teeth on the front chainring.
Thanks all for the guidance.
The time to determine the gears you wanted should have been before you removed the multi-gear system.
