Ear protection when pumping tires
Old 07-06-22, 01:49 PM
  #76
livedarklions
Tragically Ignorant
livedarklions's Avatar
Quoted: 8186 Post(s)
Liked 9,098 Times in 5,054 Posts
Originally Posted by smd4
You absolutely inferred that when Larry said "narrow," he meant 23c. But feel free to continue moving the goal post.
Talk about not making sense. I didn't infer anything from his text. After reading it, I did independent research and simply googled what size tire were they running in the TdeF, and the 25c quote came up. Why did you assume I inferred 25 mm from his text??
Geez, talk about moving the goalposts!
I don't even get what it is you think you're arguing for. You seem to be arguing that 23 mm is not narrower than 25mm, I guess.
I do most of my riding on 25s at 95-100 psi. I want nothing to do with 23s. I don't think that's an unusual line on BF, even in General Cycling.
livedarklions is offline
Old 07-06-22, 01:55 PM
  #77
smd4
Quoted: 3504 Post(s)
Liked 2,922 Times in 1,774 Posts
A lot of you seem to be reading-comprehension-impaired, but for me, the takeaway that a lot of the TdeF guys are running tires as narrow as 25c and as high as 160 psi is enlightening, and seems to give lie to "the pros are going to way wider tires at much lower pressures" type-statements that are frequently found here. Apparently, wider/softer = better/faster doesn't always seem to be the case.
smd4 is offline
  #78
frogman
frogman's Avatar
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times in 158 Posts
Originally Posted by Rdmonster69
My bike with 32's is not a gravel bike, has drop bars and is strictly made for the road. Also has a pretty narrow saddle and isn't an "upright fuddy duddy" by a long shot..
Have fun on your 23s. I ran mine at 120-130 for years and the whole set up about rattled my teeth out. 32s at 70-80 psi are smooth as butter and fast. Far faster than my bikes with 23's and 25's.
The same scenario here. Love the 32's now
frogman is offline
Likes For frogman:
Old 07-06-22, 01:58 PM
  #79
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22590 Post(s)
Liked 8,924 Times in 4,157 Posts
This is a parody thread, right?
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Likes For datlas:
Old 07-06-22, 02:01 PM
  #80
79pmooney
79pmooney's Avatar
Quoted: 4802 Post(s)
Liked 3,923 Times in 2,552 Posts
I have no ax to grind in this fight. But I did go to the Geek Cyclist site posted above to see what this year's Tour riders were using. More than half the teams are still using tubulars. Most, Continental. Almost as many Vittoria. The popular Vittorias are the Corsa G+. Didn't see the width but I believe 25c.
I've just started using 28c Corsa Control G+ tubulars on my namesake Mooney. I'm going to get 25c's for my fix gear (which cannot fit 28s when the wheel is slid forward for the biggest cog and lowest gear). Great tires. Easy rolling and secure on just about any surface. The 28c is 300 grams. Yup, Ii weighed them. Not a "fictional" spec. 300 grams for tire, tube, valve. The whole works. I'm running them on heavy, go-forever rims but I could glue them to rims weighing 300 grams or less. (To be fully honest, there is the weight of the glue; a variable. Probably not far off the weight of a clincher/tubeless rim strip so I just ignore it and call it a toss.) One thing that comes across making this switch, clincher to tubular, is that tubulars one or even two sizes smaller work just as well (for cornering, comfort, secure grip, road reliability, etc.)
But the point is not that they are light and fast. The point is that there is no sacrifice in reliability to get those features. Those tires don't care what the pavement is and do just fine off it. The 28c is so comfortable going down to 25c would be very little sacrifice and might be 35 grams lighter. That could be really fun to ride! (I used to race on 250 gram silk tubulars. Probably 21c although in those days we never measured tire width. I would have ridden those tires all the time except they were expensive, not easy to get and silk so not liking wet or improper storage. With the right bank account and a miracle synthetic silk-like casing, wonderful everyday riders! Well, except that at those widths, rims take a beating on the New England potholes!
Best part about good tubulars (and why pro riders often insist, even paying for them out of their own pockets if the team is sponsored with clincher/tubeless), when well glued, you have a surface on those rims that is rideable safely at any speed, even after a flat or blowout. Peace on mind on screaming descents. Also, I don't know the physics of this but I feel it - all the air inside the tire is used to keep the rim off the pavement. None of it is "hiding" inside the rim between the sidewalls. Feels more secure on rough roads, cracks, cornering, etc. I felt I lost that when I switched to clinchers in the 90s. Going back to tubulars and having just ridden two long rides on them last week, it's "Oh yeah! Now I remember why I like these tires so much!"
79pmooney is offline
Likes For 79pmooney:
Old 07-06-22, 02:05 PM
  #81
tomato coupe
Quoted: 3948 Post(s)
Liked 7,291 Times in 2,945 Posts
Originally Posted by genejockey
Now you're simply denying reality.
If you're going to deny something, it might as well be reality.
tomato coupe is offline
Likes For tomato coupe:
Old 07-06-22, 02:07 PM
  #82
Rdmonster69
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times in 216 Posts
Actually comparing the type of equipment a 150 pound professional cyclist uses and benefits from with what a 200+ pound weekend warrior who uses his bike to haul groceries will benefit from is kinda ....nonsense really.
Pro's generally need narrower tires because they are able to produce speeds that cause the wind resistance of a larger tire to be a factor...at speeds above a certain MPH wider tires cause more wind resistance that negates their other advantages. Most recreational cyclists can not produce these types of sustained speeds.
And their is some impairment here but I doubt it is of the reading comprehension variety.
Rdmonster69 is offline
Likes For Rdmonster69:
Old 07-06-22, 02:09 PM
  #83
livedarklions
Tragically Ignorant
I think your perspective here is rather limited, many of us are old enough to remember 25s being referred to as "wide tires" in the racing context, and now you're actually seeing 26s on the Tour which would have been unthinkable just a little bit ago.
All of which is a red herring to this thread anyway because there's no getting around the fact that putting Larry and his groceries on over-inflated 23s and 25s is bananas.
Likes For livedarklions:
  #84
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 996 Post(s)
Liked 1,204 Times in 690 Posts
Originally Posted by LarrySellerz
Why do you guys think wider tires for heavier riders are ideal?
pinch > < no pinch
It's like riding a bicycle
urbanknight is offline
Likes For urbanknight:
Old 07-06-22, 02:10 PM
  #85
smd4
You're right. It's probably the spelling kind.
smd4 is offline
Old 07-06-22, 02:13 PM
  #86
tomato coupe
As a representative of Big Gravel, I just want to emphasize one point -- whenever someone buys a 23mm or 25mm tire, a kitten dies. Do the right thing, buy wide tires.
Old 07-06-22, 02:19 PM
  #87
Rdmonster69
Shawn of the Dead
Quoted: 277 Post(s)
I've been waiting for big gravel to chime in. My wide tires have no knobbies and actually aren't even that wide. Who should I be mad at.
Old 07-06-22, 02:23 PM
  #88
tomato coupe
I've been waiting for big gravel to chime in. My wide tires have no knobbies and actually aren't even that wide. Who should I be mad at?
Your mother, because she never really loved you. But, Big Gravel loves you and wants to help you.
Old 07-06-22, 02:26 PM
  #89
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times in 368 Posts
Do any of you have like having hearing protection the pumping a tire? Recently ive had multiple blowouts (I sometimes get frustrated/rushed when patching tubes and reinstalling)
Back when I ran tubes, I was pretty good at never pinching one between the tyre and rim. In fact, I only did it once…when trying to impress my wife with how fast I could swap out a punctured tube, but that was after an evening in the local pub with some friends….and anyhow, tubes are for suckers. Go tubeless, and skip the ear pro and the annoying mid-ride punctures.
Badger6 is offline
Likes For Badger6:
Old 07-06-22, 02:29 PM
  #90
Badger6
Badger6's Avatar
Quoted: 532 Post(s)
kinda wanna work at a bike shop 1 day a week just to get better at fixing bikes, would have to be saturday or sunday.
Or don’t be a troll, you and I can hang out, have a few beers and we can fix our bikes. Or just grab a lemonade and watch YouTube. Wrenching on bikes is easy if you’re able to basically tell the difference from a screwdriver and a hammer. Honestly, it’s easy.
Badger6 is offline
Old 07-06-22, 02:30 PM
  #91
Badger6
Badger6's Avatar
Quoted: 532 Post(s)
Originally Posted by livedarklions
You say so. I wouldn't put 300 pounds on 25s if I had a choice.
I wouldn’t put 300 on 42s, to be honest.
Badger6 is offline
  #92
79pmooney
79pmooney's Avatar
So someone at Big Gravel is stalking our internet connections and killing kittens? I just ordered 2 25c tubbies. I think ASPCA out to be investigating Big Gravel.
Old 07-06-22, 02:32 PM
  #93
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10421 Post(s)
Liked 11,882 Times in 6,088 Posts
It's like you knew her.....
genejockey is offline
Old 07-06-22, 02:43 PM
  #94
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3661 Post(s)
Liked 5,408 Times in 2,747 Posts
Yep, and way back on page one. If weight appropriate tires aren't an option, maybe bring home 20# of groceries instead of 40#, exercise some restraint at the feed trough and the problem will diminish.
shelbyfv is offline
Old 07-06-22, 02:45 PM
  #95
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
More of a remix.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 07-06-22, 03:07 PM
  #96
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10954 Post(s)
Liked 7,483 Times in 4,185 Posts
So...in other words...you inferred.
Thanks for the clarification.
I have really enjoyed this thread.
A poster says teams have moved away from 23mm tires. Larry quotes that comment and says it is not true.
Multiple pages later, you are still arguing that Larry didn't say what he said based on saying someone incorrectly assumed/concluded/inferred the quoted response.
It's really been fun to read. More please!
mstateglfr is offline
Likes For mstateglfr:
Old 07-06-22, 03:09 PM
  #97
zandoval
zandoval's Avatar
Quoted: 961 Post(s)
Liked 1,628 Times in 1,044 Posts
Do any of you have like having hearing protection the pumping a tire?...
Hey... Don't forget the eye protection and flack vest...
zandoval is offline
Likes For zandoval:
  #98
datlas
datlas's Avatar
We all may need brain protection when reading OPs threads.
datlas is offline
Old 07-06-22, 03:12 PM
  #99
DonkeyShow
Quoted: 195 Post(s)
Liked 234 Times in 141 Posts
Good job Larry. You got a proper bike yet?
DonkeyShow is offline
Likes For DonkeyShow:
Old 07-06-22, 03:16 PM
  #100
Mojo31
Quoted: 9653 Post(s)
Liked 6,365 Times in 3,505 Posts
I've worn protection while pumping. No big deal.
Mojo31 is offline
Likes For Mojo31:
