Change My Mind (or don't)
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Today's first world problem: I've got a 1974 Masi Gran Criterium, serial number 119 from the Carlsbad shop. It's a very nice bike with Nuovo Record components in excellent condition.
The problem is, while I really enjoy looking at it, I don't ride it often. As some of you know, I can't make much use of 52-42 cranksets, and I just generally prefer newer components, especially dual pivot brakes. So, I'm thinking about committing the heresy of making yet another 3x10 Campy build out of this. I know, I know, I've got plenty of bikes like that, why do it to this Masi?
Here's why I think it's OK:
1. It's been repainted.
2. It's had some extra braze-ons added.
3. Nothing I have planned would be irreversible.
4. I'd ride it more often.
Let me emphasize that 1 and 2 above were not my doing. I bought it like that. I'm not sure how much variability there was in these early California builds, so I don't know exactly how much was added. It has two sets of water bottle bosses, brazed on shift lever mounts, brazed on top tube cable guides, and a fairly ridiculous looking pump peg sprouting from one of the lugs.
What do you think? Will the Prince of Insufficient Light dang me to heck for this? Or am I OK?
My Bikes
My Bikes
Likes For Andy_K:
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Make it 3X11 Campy.
Likes For Polaris OBark:
Likes For daverup:
Quoted: 359 Post(s)
Liked 582 Times
One idea:
-10-sp Campy bar end shifters: remove the rubber, add a NR backing plate, and now you have engraved 3x10 DT shifters.
-Centaur polished FD, RD, crankset..
-keep your brake levers
-keep your calipers (or go Centaur)
-wheelset and cassette (more affordable every day-especially tubular)
Ride where you thought you couldn't.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
3x10 Dura Ace.
I used to be pretty "purist" in my pursuit of things- guitars, amps, bikes... I don't know when I realized that 6 speed worked better for me than 5 speed. Then I realized a lot of late 80s and early 90s stuff looked better and worked better than the early/mid 80s stuff... then I just sorta jumped in to 10 speed. If it makes you ride it- cool. If you're not wrecking history with a significant bike- cool. But a refinished, messed with frame- I'd hang whatever I deemed worthy on it.
Commence to jigglin’ huh?!?!
Likes For Roger M:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times
I'm in favor of anything that makes a bike more useful to its owner. Racks, bags, flat pedals, gearing, whatever floats your boat. I have put taller stems, wider bars, and SPD pedals on most of my bikes because that is what I like.
Likes For Pompiere:
Quoted: 4511 Post(s)
Liked 6,378 Times
Likes For merziac:
Liked 6,378 Times
Get to it lad, forth with.
Likes For merziac:
Quoted: 3241 Post(s)
Liked 2,512 Times
How about about a 3X build from an Italian component company other than Campy with Campy where there is no option. Sakae makes a 110/74 copy of the Ofmega Mistral.
Likes For seypat:
Quoted: 359 Post(s)
Liked 582 Times
3x10 Dura Ace.
-7700/7800/7900 shifters (and a couple on Microshifts)
-polished cranksets from 7-sp to 10-sp.
RSX had polished compact square taper cranksets that used symmetrical BB's.
Specialized also had compact polished triple cranksets.
105 and Ultegra came in 9-sp triple and looked great
-polished calipers, same large range, from single pivot 105's to plenty of dual pivots if you actually want to stop well.
-polished long cage RD's, triple FD's in 5500 and 6500, especially, but also 7700 and 7800.
Keep your range narrow on the cassette, and you can use polished short cage RD's with a Roadlink.
Some members here have successfully used double FD's on triple setups.
-affordable and easily obtained brake levers, from "classic" to affordable Tektro's.
Liked 2,512 Times
Here you go. Not much "grouping" on either bike. Doesn't stop them from looking and riding good. The black one is 9, but could be 10. It has 9/10 chainrings.
Likes For seypat:
Quoted: 3810 Post(s)
Liked 6,690 Times
I say go Sensah 1x11!
https://www.ebay.com/itm/13414632339...mis&media=COPY
Quoted: 1949 Post(s)
Liked 2,010 Times
I think you just get one of those new old-fashioned $$$$ cranksets and keep the Masi an otherwise NR double.
Maybe add a few more drilliums.
Likes For Classtime:
Quoted: 2338 Post(s)
Liked 2,822 Times
Go for it. the bike and you will be much happier if it is getting ridden more
Likes For squirtdad:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Make it so you ride man!
this has to be the ultimate enabling site.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
I'm shocked. As my publicist, how could you forget a full Gugificazione 650b low trail rack and bag conversion as the only option?
Likes For gugie:
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Chacun a son gout.
I recently started a thread on my Bianchi -- gearing and brakes.
I now have Shimano aero brake levers (a conversion I did 15 years ago, since these fit my hands properly), Shimano Teflon-lined cable housings, and Shimano dual-pivot calipers, and the difference in braking performance is unbelievable.
I experimented with re-gearing, but my current 50-42 / 14-16-18-20-23-26 shifts beautifully and provides a very nice 1.5-step ratio progression, so I have decided to keep it and tough up the hills. If it gets to be too much, Plan B is 46-38 / 13-15-17-20-23-26, which will drop my bottom ratio by 10%.
My current project build is the Carlton, which already had a SunTour VGT rear derailleur, which I'll probably retain, when I got it. It is getting SunTour barcons. I am keeping the original Weinmann calipers and levers, but with new KoolStop pads and modern cabling.
Likes For John E:
Bikes: Yes
Liked 3,868 Times
The problem with 3x11 Campy is that it's either black or doesn't function as well, sometimes both. I've got one bike with 3x11 Athena. Like the silver Potenza and 11-speed Centaur, it has the downgraded Powershift shifting mechanism. I much prefer the Ultrashift of the old 10-speed stuff. I've thought about cobbling something together with Potenza/Centaur brake blades and maybe Chorus Ultrashift assembly, but that's a lot of expense to solve what's essentially a non-problem.
My Bikes
My Bikes
Likes For Andy_K:
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
Likes For Andy_K:
car dodger
wait, does R. Herse offer drillium chainrings now?
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Bikes: Yes
Liked 3,868 Times
Beyond that, the brakes and levers are the really obstacle here. I've got the Gios and De Rosa set up with stealth triples that give me a decent gearing range as long as I'm not doing any serious climbs, but I just don't like the ergonomics of the vintage brake systems.
My Bikes
My Bikes
Likes For Andy_K:
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
I was thinking of asking you just to remove the pump peg, but I'm not sure I want to get this bike that close to the torch. You never know what might happen.
My Bikes
My Bikes
