SF Peninsula C&V Ride: First Saturday of the month
#226
Bikes: 57 ExpressWerke, 58 CinelliB, 62 CinelliB Altenberger, 70 Cinelli SC, 76 Masi, 77 Colin Laing, 78 Ritchey, 80 Jack Taylor, 82 Appel, 82 Davidson, 85 Ironman, 92? Andy Gilmour, 04 Peter Johnson, 91 Ed Litton, 11 Bianchi
Quoted: 96 Post(s)
Liked 450 Times
Three diehards showed up for the ride today. Cool start, but the temp warmed a bit and allowed for a nice swift pace. Images included. Mike on his restored Bianchi (sweet), Doug on his mouthwatering Ritchey and me with my 71' Witcomb (UK).
Likes For cinelliguy:
Likes For orbeamike:
#228
Bikes: 1981 Bianchi Specialissim, 1976 Colnago Super. 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1
Quoted: 275 Post(s)
Liked 940 Times
It looks like the rain won’t hit till late Saturday. I’m planning on being there with a bike I haven’t brought before…. Windsor or Paramount. It’ll probably be a Saturday morning decision.
Likes For SwimmerMike:
#229
Quoted: 275 Post(s)
Liked 940 Times
It forecast is still looking good. I've decided on the Windsor.
#230
Crawlin' up, flyin' down
Quoted: 1021 Post(s)
Liked 2,513 Times
I don't know what it is about first Saturdays this year, but once again, life is getting in the way of important stuff, like riding on the Peninsula with good people.
I will be at the Giro d'Vino on Sunday, though. For those of you not familiar with the GdV, it is a winery crawl (at least a dozen wineries, and tasting fees are waived for those who paid the entry fee) cleverly disguised as a 40ish-mile bike ride circumnavigating Lodi. You literally ride completely around Lodi without ever actually entering the town. If you buy anything, the organizers haul your loot back to the start/finish for you to pick up after you've staggered back in. It's about as pancake-flat as riding gets - the climbing is limited to two overpasses over Highway 99. Alpe d'Huez or Mont Ventoux they ain't.
When I was a kid/teenager growing up in Livermore, Lodi was a subject of some derision (thanks largely but not exclusively to Creedence Clearwater's immortal tune), and its reputation for wine began and ended with jug wine made with the infamous Okay Tokay grape. That may or may not have been accurate then, but it certainly is not accurate now. There are a bunch of wineries surrounding Lodi now, and most of them make some darn fine vino.
Likes For bikingshearer:
#232
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,860 Times
I think I've brought every bike I own that's made of metal. I may throw tradition to the wind and ride the Bianchi - sure, it's CF and has brifters, but it's 16 years old!!! Doesn't that make it "vintage"? And the last time I took it to the LBS, the wrench said it was "a really classic Italian bike".
Or maybe the Lotus Supreme. I'll figure it out tomorrow morning, I guess!!!
#233
ignominious poltroon
Quoted: 2228 Post(s)
Liked 3,412 Times
Does 2007 count?
Yes, if I can ride my steel steed instead.
Nice bike. They are doing controlled burns in Wilder at the moment, but when they are done, that bike looks ideally suited.
Any interest in a gravel ride in the Santa Cruz Mountains?
#234
Any year is welcome, I enjoy going out and hitting some dirt trails just for a change of pace and scenery.
#235
Quoted: 96 Post(s)
Liked 450 Times
Met up with the group today but I had to drop out due to a bottom bracket backing out. My bad. The weather was cool, not cold, almost no wind, rain expected later today. Anyway, the ride must to on! Here are some images from the starting point.
#236
Liked 2,513 Times
Italian threaded fixed cup, huh? Been there, done that.
#237
Quoted: 96 Post(s)
Liked 450 Times
#238
Quoted: 4510 Post(s)
Liked 6,374 Times
#239
Liked 11,860 Times
Well, now you have something for the "C&V Pet Peeves" thread!
#240
Liked 11,860 Times
It's not obvious from the pics, but this month seemed to be Chromed Lugs Month. Just by chance, too.
Likes For genejockey:
#241
Liked 2,513 Times
I use blue LocTite, tighten the fixed cup until it screams for mercy, and then tighten it a little more. That usually works. Usually.
#242
Liked 6,374 Times
I've probably never ridden any of mine far or hard enough.
That said, I don't believe there is such a thing as "LocTite" other than red and it fails often enough.
All the others are oxymorons at best, I've never had any of them stop me from getting anything apart or hold as prescribed either.
I use super glue and vary the amount and prep according to the application now days, it has never failed.
#243
Liked 2,513 Times
#244
Quoted: 96 Post(s)
Liked 450 Times
LocTite bottles/tubes are all red. It's what's inside that varies in color, and the label says if it is "Blue 242" or "Red 271." My exhaustive interwebs research (about ten seconds worth) says the red LocTite requires heating to 500* F. to undo the bond, while blue LocTite only requires a wrench and some grunting. I can vouch for the claim regarding blue. I cannot verify the claim regarding red, but it is line with what I have heard before from sources long since forgotten.
#245
Liked 6,374 Times
Yep, all bottles are red, I'm only talking about what's inside.
I've been an ASE and FOMOCO Senior Master Technician as well as a mech/tech all my life.
Fixed a lot of auto's, MC's and bikes at work, on the road, the dragstrip and everywhere in between.
If I'm going to use any LocTite, I'm going to make sure it "adheres" to the premise that its not coming loose no matter what, I've never had to use any heat to undo it.
Likes For merziac:
#246
Quoted: 96 Post(s)
Liked 450 Times
No confusion here.
"PERMANENT FIX: Permanent seal prevents tampering and is only removable once cured by heating parts up to 500°F (260°C)"
I use is because it helps prevent loosening under high heat conditions. Me...still learning stuff. Thanks guys.
#247
Liked 6,374 Times
Before this exchange, I had never noticed the needing to heat to unscrew a bolt/screw etc in order to loosen. Here is a quote pulled from the Loctite website.or
Application and operating temperature, perfectly clean threads, no oil, moisture, residue of any kind on or in any of the threads and strict adherence to torque specs.
And yet still as noted above, the Italian cup and many other may still go rogue at anytime despite our best efforts.
Still have never needed the hot wrench for any fastener that was only being held with threadlocker, nothing truly "Permanent" with 10's of 1000's of nuts and bolts IME.
Likes For merziac:
#248
Liked 11,860 Times
It's that time again!
Mind you, it's supposed to rain tomorrow. I don't know about you guys, but I'm getting too old to ride in the rain, so if it's actually raining tomorrow morning, I'm out!
#249
Quoted: 275 Post(s)
Liked 940 Times
I'm a definite "Maybe". I really want to get the Paramount out, but I don't know if I can make it.
#250
Quoted: 96 Post(s)
Liked 450 Times
Same here, too much of a baby to take my steel valuables out in the rain, the clean up is a horror to my sensitivities!
