To update Di2 components to latest software version or not
Quoted: 800 Post(s)
Liked 512 Times
Checking the front and rear derailleur in the E-Tube app shows there are software updates for both. Having been around non-bike related technology for years, I know the perils of updating stable systems to the latest and greatest versions. I also know Shimano has a hit-and-miss approach at times with software. So...
If my bike is working fine, is the risk of updating to the latest software versions worth it? Or should I stick with the 'if isn't broken, don't fix it" approach?
BTW these are minor updates for both. Going from versions 4.0X to 4.0Y for example. Not major whole release updates.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You plugging it in to do the update or via the app? I would only do it if I can plug in via the PCE02.
Quoted: 800 Post(s)
Liked 512 Times
No, I am doing the update via Bluetooth. From my iPhone to the rear derailleur. The Shimano 12 speed Di2 setup does not require the EW-WU111.
Quoted: 18883 Post(s)
Liked 10,645 Times
I would go for v.latest unless I knew of a problem with it. Which is what you're asking. 🙂
I'm guessing the software for each trim level and generation is different, which one do you have?
ignominious poltroon
Quoted: 2184 Post(s)
Liked 3,336 Times
I did a firmware update in 2015, mainly because I wanted to see if I could do it with a virtualized Windoze running in Mac OS X. It worked. I decided to quit while I was ahead, and haven't done so since.
Unless something is malfunctioning, or you want to add a component, there really isn't an imperative to do it. Even if the probability of bricking it is small, it would fsck to have to pay someone to unfsk the system.
I'm assembling a bike for someone else at the moment, and will have to do firmware updates on her system, since I am mixing generations of components. I can hardly wait.
Quoted: 871 Post(s)
Liked 725 Times
Update if you don't mind needing a backup plan in case it bricks, like taking it in to the LBS.
I've done some Di2 upgrades over Bluetooth that didn't take, luckily didn't brick. Then I went a super long time not touching it because everything worked, until I had some RD issues and chose to try updating using the wired connection. That issue ended up being something much simpler to resolve, but I won't risk bricking by trying over wireless anymore when wired is an option.
Quoted: 3185 Post(s)
Liked 2,020 Times
There was a period where updating via BT was a problem as the WU111 unit would partly update then lose the connection mid update, which would subsequently fail and brick the system. Don't know if they fixed that. Ive had 2 Di2 systems for several years and have never updated as my attitude is don't fix what ain't broke. The systems do what they are supposed to do, shift perfectly and I'm not messing with that.
Likes For Steve B.:
Quoted: 1217 Post(s)
Liked 1,281 Times
There have been hundreds of thousands of updates done to Di2 systems since 2015, 99% without issues. If you are a hammer everything looks like a nail. If you look for people who say its a bad idea trust me you will find them, ask and you will find tens of thousands of people who still believe the world is flat. I check from time to time if an update is available if so I update it via Bluetooth without issue. If given a choice I set all my devices to auto update and haven’t a regret.
Likes For Atlas Shrugged:
Quoted: 800 Post(s)
Liked 512 Times
Thanks for all the advice folks. I guess in the end it comes down to what my risk level is. Still not certain what I'll do. Trouble is I did not buy the bike from the LBS so if I do brick the system, I am taking it into the shop without any support. And I HATE that feeling/doing that.
Advocatus Diaboli
Quoted: 4717 Post(s)
Liked 1,526 Times
Quoted: 309 Post(s)
Liked 664 Times
If it helps, I am running the very latest firmware on my 12-speed Di2. No idea what the update added/fixed, but everything still works and there were no dramas.
Likes For tempocyclist:
Advocatus Diaboli
Liked 1,526 Times
Likes For Sy Reene:
