V-brakes vs. Center-pull brakes
#126
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The mystery continues.
Likes For Rolla:
#127
Habitual User
Quoted: 4942 Post(s)
Liked 8,081 Times
I've always thought it was the orientation of the cable across the top of the brake arms, but I've been been working in shops since a little before V-brakes actually came out. I guess it would be more correct to say lateral pull...or horizontal pull. I do remember being told to only use V brake compatible levers at the time because they had greater cable pull but less leverage as the brake arms themselves were longer and thus more powerful/had greater leverage.
Likes For Eric F:
#128
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Likes For Lombard:
#129
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Oh, well, now that we're being technical, the badge may have been slapped onto the tailgate in 1992, but the rest of Piece Of *beep* Chassis No. 573 - and the idea that turbocharging a V6 is a substitute for V8 displacement - are deeply rooted in the 1970s and 1980s, wouldn't you say?
#130
Quoted: 8275 Post(s)
Liked 9,033 Times
And how's that working out for ya?
And neither is the 504. I've had multiple vehicles that I bought new that had some or all of these things, and every single one of them proved to be an expensive out-of-warranty headache. And don't even get me started on the whole oversized-alloy-wheel, low-profile-tire thing!
I can't even imagine how much worse the pollution and fuel prices would be if there were no controls. Having measured the tailpipe emissions of thousands of cars since 1983 I can see the difference modern tech makes.
I agree that the factories could build simple, economical cars but that's not where the money is.
#131
Sock Puppet
Liked 863 Times
#132
Liked 9,033 Times
Turbochargers are more common now than ever before. It's a way to get more power from a smaller engine. Chevy has released a full sized pick-up with a 4 cylinder turbo engine.
#133
Quoted: 792 Post(s)
Liked 1,494 Times
My point was that American cars became much more reliable post 1990. In the 1970's, the American car that went over 100,000 miles was the exception unless you gave it extreme TLC. Now it's pretty much expected. Granted there were exceptions like the Dodge Dart. Most American cars of that era were a joke. Is it any wonder Japanese imports almost made the US auto industry collapse in the late 1970's.
#134
Quoted: 792 Post(s)
Liked 1,494 Times
Actually that body came out in 1982. I had a 1986 with the crappy 2.8 engine and I drove that thing for 18 years.
#135
Liked 9,033 Times
After she got the bonus check she could buy any car she wanted.
If you ever saw "Absolute Power" Clint the jewel thief escapes in the dark green Typhoon early on. That's one of the ones I serviced but I never met him.
Likes For big john:
#136
Habitual User
Liked 8,081 Times
Likes For Eric F:
#137
Quoted: 792 Post(s)
Liked 1,494 Times
Likes For sjanzeir:
#138
Quoted: 1083 Post(s)
Liked 686 Times
I was never a bike shop guy, but was racing and working on my own bike since before v-brakes. My understanding was always that "linear" related to cable pull ratio of the lever and brake system, not the direction of the cable related to the brake arm. I'm just a guy on the internet, though.
Likes For Jeff Neese:
#139
Liked 9,033 Times
#140
Habitual User
Liked 8,081 Times
#141
Habitual User
Liked 8,081 Times
I'm not sure that I'm correct. I'm only stating my understanding of the term based on the information I recall from many years ago. The accuracy of my memory is highly suspect.
Likes For Eric F:
#142
Liked 686 Times
Thank you. I will try adjusting them again. I had to monkey with them quite a bit to get them to work at all. Once I got them to basically work, I didn't want risk having them set so that one pad constantly rubs against the rim after braking.
But this is what I mean. Back when I had center-pull brakes, I never this sort of problem.
One thing that got skipped in this entire thread is discussion of the venerable center-pull caliper brake that I think you are talking about. They were used on a lot of bikes back in the 60s and 70s and beyond. That was one of the upgrades from a Schwinn Varsity to a Continental, for example. You're right - they are pretty much "set-it-and-forget-it".
They still make them and some people still use them. Here's one example.
Dia-Compe DC-750 Center-Pull Front Brake, 62-78mm, Silver
And here's an interesting article at ReneHerse.
Why I Choose Centerpull Brakes
#143
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2579 Post(s)
Liked 5,636 Times
Noticed zero braking difference on my Schwinn Varisty and Continental. Compared to ‘modern” brakes, they both equally sucked - especially with the little level brake levers that ran parallel to the upper bar.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#144
I always thought that it was because the cable pulled directly across between the two arms a predictable amount, rather than pulling the straddle cable up and trusting that to move the arms together a distance which varied based on the length of the straddle cable.
#145
> Were you able to get them at least serviceable?
Yes. Thank you. I read the article about "why I choose centerpull brakes." The author makes some good points, about a few different kinds of brakes.
Likes For walterbyrd:
#146
Rhapsodic Laviathan
#147
Quoted: 792 Post(s)
Liked 1,494 Times
#148
Quoted: 581 Post(s)
Liked 921 Times
cyccommute Rolla sjanzeir Jeff Neese
'Direct pull' brakes are absolutely defined by the way the cable is oriented across the top of the arms. These brakes fix a design flaw with centre-pull cantilever brakes - that the more you pull on the brake, the higher the yoke goes and therefore the less leverage the brake has working to stop the bike. 'Direct pull' brakes have the cable pulling the arms straight together, so doubling force at the lever will approximately double the force at the brake, while doubling the force at the lever for a centre-pull cantilever makes some increase less than double the force at the brake. This is not to say cantis are necessarily bad brakes - I have had many great rides on canti equipped bikes on rough terrain, but decent quality V brakes (direct pull) were an immediate upgrade when they came out.
And how do we know that it is the cable orientation and not the amount of cable pull that defines linear-pull brakes? Because there are 'short pull' linear pull brakes for touring/Cx/bmx bikes that use the same short-pull levers as you would use with road calipers or cantilever brakes. There are also cable-actuated disc brakes that work with short pull levers. The difference between the brakes is the way the cable actuates the arms, not the amount of cable puleld.
As for the... *ahem* 'people' splitting hairs on whether what is called a 'cantilever' brake can be described as a 'centre pull' canrtilever brake, please, . . . . . The 'road centre pull' brakes like the Weinmanns pictured above haven't been included on a new bike in decades, so in a discussion of 'cantis vs Vs', it is absolutely appropriate to differentiate by calling 'cantis' 'centre pull', because that's literally what they are, just like how 'direct pull' brakes are literally also a type of 'cantilever' brakes. Kind of like how what used to be called 'clipless' pedals are now regularly, and not incorrectly, called 'clip in' or 'clip' pedals - the toe clip and cleat pedals that 'clipless' pedals replaced aren't really a thing anymore, so correcting people on the distinction only indicates who in the discussion thinks too highly of their own intelligence.
#149
Quoted: 792 Post(s)
Liked 1,494 Times
And how do we know that it is the cable orientation and not the amount of cable pull that defines linear-pull brakes? Because there are 'short pull' linear pull brakes for touring/Cx/bmx bikes that use the same short-pull levers as you would use with road calipers or cantilever brakes. There are also cable-actuated disc brakes that work with short pull levers. The difference between the brakes is the way the cable actuates the arms, not the amount of cable pulled.
#150
Quoted: 581 Post(s)
Liked 921 Times
Ummm... no, it isn't.
You were wrong all along-
It was not a Pony, it was an Excel.
Pony was an unbelievably crappily made rear wheel drive car that was never sold in the US.
Excel was an unbelievably crappily made front wheel drive car that WAS sold in the US.
Maybe some of the other stuff you said was correct, but I can't be bothered to look if you don't have the respect for the history of Hyundai in the USA that I think is appropriate.
