What is a hybrid a hybrid of?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
At their inception they were ostensibly a hybrid of a road and a mountain bike. Given what mountain bikes have become, that doesn't seem to be an apt definition any more. Are they currently hybrids of anything, or did the name just outlive the concept?
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,991 Times
I think the name sort of outlived the concept to a point.
Pennylane Splitter
Bikes: Yes
Quoted: 1798 Post(s)
Liked 1,439 Times
Kinda like asking the owner of most Sport Utility Vehicles or a Cross Over vehicles what's the difference from a true off-road vehicle or station wagon, isn't it? Just raise the body up a few inches, put on some sportier (and bigger) wheels/tires and you're done, maybe throw in an all-wheel-drive system to make yours unique from the neighbor's vehicle (not necessarily a 4WD system).
I always thought they were a cross between a road bike and an urban bike of years-gone-by (Schwinn Collegiate & Suburban models come to mind). You combine the frame and seating style of a road bike with the larger tires and flat handlebars of an urban bike, and there you have it. Maybe throw in some design characteristics of the old rigid MTBs of the past, (as you suggested), and a touring bike for added 'street credibility'
Likes For skidder:
Quoted: 6193 Post(s)
Liked 4,809 Times
Just like tire sizing, it's continued use of the term by the masses. So pretty much your last suggestion...
Likes For Iride01:
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
They've become hybrids of hybrids and other hybrids.
A while ago, some local dude put a Trek Zektor up for sale and called it a hybrid in the add. Even though I wanted the bike and made the highest bid, when I tried to explain to him that this was a flat-bar road bike and not a hybrid, he blocked my ass and canceled my bid!
Likes For sjanzeir:
Guest
Liked 3,270 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
Modern hybrids are just flat bar gravel bikes.
Likes For wolfchild:
Guest
Liked 3,270 Times
Likes For Rolla:
Liked 2,488 Times
There are some higher performance hybrids out there which have 1X drivetrains. carbon forks, hydraulic brakes, braze-ons to mount all manner of accessories and enough frame clearance to run 700 x 40 mm - 50 mm tires. The only difference is the style of handlebars.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
In about 1996.
Stuart Black
Stuart Black
Likes For cyccommute:
Guest
Liked 3,270 Times
Can you show an example of one of these higher-performance 1X hybrids that has a carbon fork, hydro discs, gear braze-ons, and big tire clearance? I don't think I've encountered one.
Likes For Rolla:
Liked 4,218 Times
Looking at Trek. The Checkpoint ALR 5, for example, takes up to 45mm tires and has a 46/30, 11-34 drivetrain ( 23 gear inches). The Verve 3 takes the same 45mm tires with a 46/30, 11-36 drive train (22 gear inches). The Dual Sport 4 takes up to a 54mm tire with a 1x 42 tooth crank and 11-50 cassette (23 gear inches). The Verve and the Dual Sport are definitely hybrids.
Even if you compare the Checkpoint to a FX1, the FX doesn’t come out all that badly. Yes, it will only take 38mm tires but the gearing is lower than the Checkpoint by just a squidge (30/34 vs 28/34).
Stuart Black
Stuart Black
Liked 4,218 Times
Thanks for clarifying that when you said earlier that "modern hybrids are just flat bar gravel bikes," you really meant that "some higher performance hybrids" are like gravel bikes.
Stuart Black
Stuart Black
Quoted: 2281 Post(s)
Liked 1,710 Times
When I've talked about my hybrid bike in the past to someone, they thought I was talking about a motorcycle with an electric motor drive and a gasoline engine to charge the battery.
Guest
Liked 3,270 Times
The Trek FX Sport 4 is damned close. The Sirrus X 4.0 is closer as it can take at least 42mm wide tires and maybe wider.
Neither the Trek nor the Sirrus has tubeless-ready tires or wheels, so maybe that's what distinguishes them from true gravel bikes. I suspect the geometry is different as well, but I haven't bothered to compare.
IMO, all of this just further establishes that "hybrid" is an outdated term for a vague-at-best bike category.
Likes For Rolla:
Liked 2,488 Times
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
A hybrid is a bike that does everything poorly. LOL. So they are sold to beginners that are poor at knowing anything about bikes.
Likes For GamblerGORD53:
Guest
Liked 3,270 Times
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I'm trying to remember the first bikes I recall being called hybrids. I seem to remember them being a mountain bike style frame, and flat bars with tires and drivetrain of a road bike. But I suppose with hybrid implying a combination of two bike types, your thought that the name outlived the concept to be accurate.
Likes For Chuck M:
Guest
Liked 3,270 Times
Originally Posted by wolfchild
Marin DSX and Marin Muirwoods ??...both of them look like beefed up hybrids.
They call the Muirwoods a “transit / urban” bike, which I guess is the new “commuter.”
Marin’s actual hybrids have little in common with gravel bikes.
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
A lot of marketing semantics in the bicycle sales world
Likes For dedhed:
Guest
Liked 3,270 Times
Quoted: 1581 Post(s)
Liked 1,189 Times
I use it as a flat-bar road bike; would make a perfectly competent 'gravel' bike with a simple tire change. I find the 32s fine for the surfaces I ride: paved and dirt roads; the occasional hard-packed, non-technical dirt trail.
Oh, and yes: the term 'hybrid' is utterly meaningless in today's bicycle market.
Likes For badger1:
Liked 4,218 Times
Interesting. They call the FX Sport 4 a "fitness bike for riders who want the speed of a lightweight road bike with the comfort and control of a flat handlebar," so I guess it's a "hybrid" of a fitness bike and a flat-bar road bike.
A “gravel bike” is kind of nebulous as well. There’s racing, all road, gravel, bikepacking, etc. It’s just as open a term as “hybrid”. In fact, “hybrid” is probably a better name since gravel bikes are just road bike built to act like a 1990 mountain bike or a 1990 mountain bike modified to act like a road bike.
Stuart Black
Stuart Black
