Drop bars with Quill stem
I have a quill stem on a bike that currently has flat handlebars in.
It does not have a faceplate like most modern stems but simply has one hex bolt which tightens it or loosens it and so to install handlebars you have to remove everything and slide them in.
I'm wanting to put drop bars on the bike. Is it possible to use them with this stem or will the curves and bends not be able to slide on?
Thanks
Thanks
Quoted: 513 Post(s)
Liked 448 Times
If the clamping area of the stem is narrow enough to clear the bends in the drop bar and the clamping area of the drop bar is the same as your flat bar, yes. That's how we did it in the olden days.
Quoted: 1074 Post(s)
Liked 295 Times
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 116 Post(s)
Liked 209 Times
Thanks
Thanks
If in doubt about your stem, post a photo. The bars in question too.
Notice how the stem's clamp has a narrow section? It's typically near the clamp-bolt. When sliding the stem onto the bars (much easier than sliding the bars into the stem), you rotate the stem so that the narrow section of the clamp is on the inside-radius (tight) side of the bar.
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
It's like riding a bicycle
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Some, but not many, old stems have a small set-screw near the large clamp screw that facilitates opening the "hole", allowing an easier bar insertion. If yours has one, use it or you'll be fighting it.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
punk kid.
Bikes: 1970's Nishiki, Late 70's Centurion Super Elite
i just have a good screwdriver, or sometimes you can use a hammer pry, to wedge open the clamp. some tighter fits may require two people
Quoted: 116 Post(s)
Liked 209 Times
I don' think they'll fit, as it appears to an atb stem. Road bars need a relatively narrow stem clamp to get around the bars, and I'm not seeing it here.
The good news is, stems are inexpensive. But, this appears to be a riser stem, is that correct? Either way, many shops have bins of used quills that should be cheap.
Good luck!
Good luck!
Quoted: 1856 Post(s)
Liked 664 Times
i would just do a test fit without brake levers et cetera and see if you like it, for bar fit, ability of the stem to clamp the bar, the overall appearance (painted stem, aluminum bar), and position of the bar. It will also tell you if you NEED another stem.
