New Retro-style Cranks
Old 03-20-15, 07:40 AM
Rocket-Sauce
Port
Rocket-Sauce's Avatar
Quoted: 983 Post(s)
Liked 1,861 Times in 1,062 Posts
Enduro Bearings start shipping TorqTite threaded PF bottom brackets, plus prototype?cranks?
with external bearings
This is very cool. Built up on a bike with Electra Ticino sheriff's star hubs, TRP gum hood levers, etc. Could be very cool.
But DAMN expensive at $800!
Rocket-Sauce is offline
Old 03-20-15, 08:33 AM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2608 Post(s)
Liked 1,699 Times in 935 Posts
Let's see the bike!
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Old 03-20-15, 08:43 AM
Rocket-Sauce
Port
Quoted: 983 Post(s)
^^Sorry, I meant it would go nicely on a bike built up with other modern retro bits.
Old 03-20-15, 08:47 AM
Wileyone
Wileyone's Avatar
Quoted: 1858 Post(s)
Liked 606 Times in 403 Posts
For $800 it should come with a Bike and a Blonde.
Wileyone is offline
Old 03-20-15, 09:16 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Well, how much would a new NR crank cost in today's dollars? I'm thinking a lot.
Crank looks nice.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 03-20-15, 09:27 AM
davester
davester's Avatar
Quoted: 930 Post(s)
Liked 1,291 Times in 487 Posts
That does look pretty, but also pretty darned expensive. The article also says that it's machined, suggesting that it is not cold forged and therefore likely to be flexier than forged cranks.
davester is offline
Old 03-21-15, 01:28 PM
Rocket-Sauce
Port
Quoted: 983 Post(s)
I'll bet it is stiffer than the original Super Record because of the beefier arms, and much stiffer BB. But it is probably not even close to modern external bearing BB / cranks.
Old 03-21-15, 01:44 PM
Scooper
Decrepit Member
Scooper's Avatar
Bikes: Waterford 953 RS-22, several Paramounts
Quoted: 634 Post(s)
Liked 69 Times in 57 Posts
Rene Herse?
- Stan
my bikes
Science doesn't care what you believe.
Scooper is offline
Old 03-21-15, 03:35 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1565 Post(s)
Liked 1,295 Times in 865 Posts
Cold-forged arms have the potential to be stronger than pressure-cast arms of similar dimensions.
So it's the cold-forged arms that can be, and usually are, slimmed down for a lower weight, and that are thus going to be inherently flexier.
These ones have the look of 1990's billet crankarms, which while often made from higher-grade forged billet than cast arms, may not realize the optimization of grain orientation that forged crankarms can achieve.
Does the new bottom bracket utilize a square taper interface or some new splined interface on one or both sides(???).
I'd want to see evidence of a solid record based on at least a year of professional race testing before plunking down that sort of dough.
dddd is offline
Old 03-22-15, 09:57 AM
MnHPVA Guy
Quoted: 16 Post(s)
Liked 24 Times in 11 Posts
The external bearings are clearly shown in the photos.
MnHPVA Guy is offline
Old 03-22-15, 10:07 AM
MnHPVA Guy
Quoted: 16 Post(s)
Just like steel, stiffness (Young's Modulus, AKA Modulus of Elasticity) of aluminum does not vary with heat treatment or forging. Different alloy composition can have a barely measurable, but insignificant, affect on stiffness. Yield strength and fatigue resistance can be greatly improved, but not stiffness.
Old 03-22-15, 11:45 AM
ezln64
Bikes: 98 LeMond Zurich, 78 Benotto Track, 07 LeMond Poprad, 90 Masi team track funny, 85 Columbia 5 Star repop, 87(?) Gazelle AA Super
sugino 75 dd is also the new classic external bearing option, can't find a good photo as of yet
edit: found some decent shots!
File Type: jpg
File Type: jpg
ezln64 is offline
Old 03-22-15, 12:03 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Apparently the Street fixie market has Money to spend, or that is the assumption ..
I doubt there are a Lot of Velodromes Being Built. other than 1 every 4 years for another Olympics
fietsbob is offline
Old 03-22-15, 04:12 PM
steelbikeguy
steelbikeguy's Avatar
Quoted: 1829 Post(s)
Liked 3,375 Times in 1,580 Posts
I saw those cranks at NAHBS. Very flashy, and nice to see such an homage to Campy cranks. They are a bit chunkier than the Campy cranks, due to the the fact that they are CNC'ed instead of forged.
It's not obvious, but there is a bit of "dish" to the spider. The outboard bearing requires that the crank arm sit further outboard than on the vintage Campy, so the spider arms are angled a bit inward to maintain the right chainline.
I was intrigued by the fact that the web between the arm and spider that was prone to cracking on the vintage Campy crank exists on this modern interpretation. I asked if they were planning to file out the web to avoid cracks.
steelbikeguy is offline
Old 03-22-15, 05:59 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3587 Post(s)
Liked 3,400 Times in 1,934 Posts
The problem with CNC machined parts isn't that they're more flexible than forged parts, but that they're not as strong.
JohnDThompson is offline
Old 03-23-15, 06:08 AM
Rocket-Sauce
Port
Quoted: 983 Post(s)
Sorry, I thought that was obvious that these have external bearings. I realize how my post may have been a little unclear. I meant that these are likely not as stiff (especially in the spider) as even entry-level modern external-bearing cranks like 105, Athena, Apex....
rickrob
Classic and Vintage Sales
4
04-13-19 10:37 AM
noglider
Classic & Vintage
18
04-02-18 12:02 PM
DubT
Tandem Cycling
35
04-15-12 01:37 AM
realestvin7
Classic & Vintage
37
07-15-11 10:28 AM
realestvin7
Classic & Vintage
23
07-13-11 04:08 PM
