Shimano RX100 upgrade?
Got a Shimano rx100 7 speed derailleur. What’s a good option for upgrade or is it leaving it worth it? I’d also like to ditch the down tube shifters and upgrade to brifters. Thoughts, recommendations? Cheers!
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
That’s solid equipment, will happily interface with Shimano 8-9-10 speed shifters of the STI variety.
Just change the shifter, cassette and chain and adjust the RD, you’ll be fine.
Feel free to change it if you must, but ot at all necessary.
Likes For rccardr:
I have read many times that RX100 components are the same as 105 with a different finish. May/may not be true.
Bikes: 1994 Cadex CFR3, 2006 Scott CR1 SL, Rossin aero, Bertrand GB 2000, Spec Allez Pro
Quoted: 134 Post(s)
Liked 68 Times
Vintage Dales are great candidates for neoretro builds (especially if the rear spacing is 128mm and not 126mm). Lots of choice out there for brifters, kinda depends on your budget. But if I were to replace the RX100 groupset, it certainly wouldn't be for a performance wise pretty similar 8 speed groupset with the early brifters.
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times
Sounds like a case of upgrade-itis to me. If stuff is broken or worn out, then upgrading makes sense. If it is still working OK, "upgrading" doesn't make sense to me. Certainly not with the derailer. Maybe replacing the downtube shifters with integrated levers, but only if you are having trouble making the shifts or are reluctant to shift with the DTs.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
You could "upgrade" to Ultegra, but you would notice any difference. Spend yr $$$ elsewhere
Likes For thinktubes:
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,897 Times
I rebuilt my old (1994) Cannondale R500, with full 8 speed RX100. I went for DT shifters, but there are 2x8 RX100 STIs out there.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Cheapest option is to just pick up a set of new Shimano Tourney STI levers and stay 7 speed.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
Quoted: 4722 Post(s)
Liked 3,036 Times
I'd leave the current derailleur, unless you're a weight weenie. An upgrade to same era 105SC would save 57g, while 600 Ultegra would save 65g. You shouldn't notice any difference in shifting performance, unless there is something wrong with the derailleur itself. If you want to keep everything period correct there was a 7 speed Shimano RSX brifter during this era.
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
I also think, depending on the spacing (if it is 126 or 130), if the OP wishes to upgrade to brifters/8 speed, there are reasonably priced options to do so. Chain/cassettes are pretty reasonable, and 8 speed brifters are actually less pricey at times than 7 speed.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
What kind of bike are we thinking about spending money to upgrade? That’s a key to the correct answer.
Likes For Wildwood:
Quoted: 1561 Post(s)
Liked 1,734 Times
Otherwise you could get brand new Tourney brifters or Microshift R7. Unfortunately these newer brifters are all black.
By the way, if you have the RX100 FD-A550 front derailleur, that needs to be replaced by FD-A551 to function properly with brifters.
Quoted: 2338 Post(s)
Liked 2,822 Times
rx100 is solid and and underated.
Likes For squirtdad:
Edumacator
Liked 3,122 Times
Absolutely agree. But I guess I assumed the OP wanted to transition to 8 speed or at least brifters? I could be completely wrong on that.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
+1. RX100 on its own merits is good stuff. I think the only reasons to knock it might be the extra weight, and that the hubs use cruder "piston-ring" seals instead of the rubber seals used on higher-level hubs. But that's no issue as long as you repack the hubs when they need it.
My '91 Bianchi Eros came stock with an interesting mix of RX100 (brakes, levers, hubs, shifters) and Deore LX (crank, derailleurs.) Some time ago, I replaced the Deore parts with RX100 components to make it a completely RX100 road bike. Sometimes you just need a silly project.
RUSA #7498
Liked 1,734 Times
Did you actually weigh the components to come up with this? I kind of doubt there is that much difference in weight. The 105 1055 and the RX100 A550 groups look really, really similar aside from finish.
If you do the upgrade, let me know if you have interest in selling the downtube shifters.
I need a set, I have a bike that was converted to stem shifters.
Liked 2,568 Times
It's also possible that the higher-tier RDs are more hollowed-out for weight savings, but I haven't checked that closely yet.
Liked 2,822 Times
there are lots of sources for this data and Tmar is pretty much the expert. with shimano there is always some differences for groups in the same time, often weight.
Liked 11,897 Times
He can do that and stay with RX100. But he might not really care about staying with RX100, that's really just an aesthetic choice. It's probably a lot easier to find 105SC or 600/Ultegra STIs and RDs. Me, I like RX100, so I built up a bike around it.
Likes For genejockey:
Edumacator
Liked 3,122 Times
Will the RX100 index with 8 speed brifters as long as the cassette is compatible?
Liked 11,897 Times
You have to get the correct generation of RX100, but yeah, A551 STIs should work with an A551 RD, and I THINK those are both compatible with 1055 (105) or 6400 (Ultegra) STIs and RD.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
If you want to go triple, look for RSX brifters to go with it.. They were the spawn of 105 iirc.
Veteran, Pacifist
Liked 4,832 Times
I must have the wrong edition of this drivetrain - it is on a bike at a relative’s house I occasionally visit. Maybe it needs more use and maintenance. Stored in a dry garage.
Liked 1,734 Times
As I mentioned earlier, you do need to swap out the FD-A550 in favor of a FD-A551 if you want to upgrade from the DT shifted RX100 groupset, to the brifter shifted RX100 groupset.
