Clinchers: Unsafe at any speed?
Location: "Gosh honey, you pass more like Tony Rominger..."
Bikes: 2005 Scott CR1 Pro - 1992 Panasonix Fixed Conversion 60tx20t
I had a real interesting experience today- I was going down a moderate descent this morning at 30+ mph and my front tire blew out and the tire rolled of the rim as soon as I braked to a slow enough speed where I could control the bike (fortunately this didn't happen at the 30 mph rate!). I'm lucky I didn't damage the rim due to the glass like surface I was riding on.
I have some nice used Mavic 36 spoke training tubulars that I just got of at ebay for $50.00. I can't wait to get those on- at least they will stay on the rim and the leak is usually slower.
No wonder the pros don't use clincers at their 60 mphs descents - they'll kill you!
"How did all those 'Keep Off the Grass' signs get there?"
Aluminium Crusader :-)
sounds like you're looking for an excuse to use those tubulars
There's nothing worng with clinchers, so I'd bet there was something wrong
with that tyre, like a sidewall cut, etc. Tyres have gotta be regularly checked
for damage, especially the sidewalls
don't forget that tubulars can roll off a rim if they're not glued properly,
and/or if it's 110 degrees
Quoted: 15 Post(s)
Liked 27 Times
any front tire that blows out on a descent is dangerous. doesn't matter if it's clincher or a tub.
as far as tubs not rolling, i guess you never saw the TV coverage of Beloki doing his smackdown in the '03 TdF.
Yeah, except that 99 out of 100 front-wheel blow-outs at speed with clinchers will end up rolling the tyre while 1 out of 100 tubs will roll... Comparing the exceptions of either case isn't valid.
I think its more of a case of people not doing the required tyre maintenance. It only takes ~1min to check your tyres before heading out.
If you hit some glass while descending, I dont think it makes too much difference if your on tubulars or clinchers, there is no air, still probably gonna get rim damage
TREK 2300 owner
Bikes: '04 Trek 2300, '77 Panasonic Touring Deluxe
... my front tire blew out ...
If you heard it explode then my guess is the tube was not seated properly inside the tire. Did you recently do any tire/tube work on that wheel?
A small glass puncture should not cause your tube to explode. On the otherhand a huge cut would.
Glad you survived unscratched!
..rickko..
" I can't wait to get those on- at least they will stay on the rim and the leak is usually slower." I have blown out way more tubulars than clinchers. And tubies can indeed roll, especially on decents where you are braking a lot and heating the rim. Do yourself a favor and stay with clinchers for genral riding. Unless you have nearly infinate money to spend on cycling tires. This is the vioce of expereince speaking.
Chairman of the Bored
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
Oddly enough I have only had one blowout ever while riding, and that was a result of riding a tire with a torn sidewall when I was about 12, causing the tube to poke out....it eventually popped.
I keep hearing of all these high speed blowouts, and I can only think of one thing....heat and air expansion. Ideally for fast descents, you want a tire with pretty good air volume, and a less extreme pressure. Most of the stories I heard were from people who like running 130psi+ pressures on 23c or smaller tires. There is one guy who claims blowouts on 25c tires at 35mph flatland (he's known for pretty tall tales)....his story I have serious doubts on....I think he hit some glass.
1/2 a binding 1/2 a brain
Bikes: Serotta Ottrott ST, Titus RX100, Seven Sola 29er HT in the works
Originally Posted by Bob S.
snip Congratulations on riding the blowout upright to a safe stop. snip
+1. I'm glad you're alright.
As far as the ensuing debate...
I've ridden glued on tubulars and clinchers fairly equally over the past 20+ years. They both have their advantages and disadvantages. And yet the debate still rages on.
As far as your particular circumstance, I agree that the safety factor of a flat on a high speed descent is going to be in the favor of a glued on tubular. That glue will give the tire casing purchase during braking more than the bead of a clincher. That's a pretty compelling reason to choose tubulars if you ride a lot of long, fast descents.
But to be fair, there are some glaring disadvantages with tubulars. One in particular that rarely gets mentioned is the sketchy interface between the rim and casing when a spare is mounted after a flat in wet conditions. When you consider that more flats happen when riding on wet roads, then that circumstance bears some consideration. I gringe at the thought of having that situation pop up for me. A wet tire casing on a wet rim is pretty worthless for any amount of braking or cornering.
Portland Fred
Originally Posted by catatonic
I keep hearing of all these high speed blowouts, and I can only think of one thing....heat and air expansion. Ideally for fast descents, you want a tire with pretty good air volume, and a less extreme pressure. Most of the stories I heard were from people who like running 130psi+ pressures on 23c or smaller tires...
BTW, you can have blowouts with large tires. I've had 2 700x28's blow out (one on a very hot day, and the other resulted when I hit half a beer bottle and it sliced completely through the tire). Years ago, I had a 26x1.5" explode on me while I was riding, but I was at max pressure before the ride, and it was 100 degrees.
When you are going down very long steep hills, don't ride your brakes since this can cause your rims to heat up. When you know you'll be riding in conditions that heat your tires, it might be a good idea to ride at slightly lower pressure than normal.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
I guess you missed the rear tubular tire rolling off the rim on Joeshba Beloki's bike in the '03 Tour de France? Dude had a compond fracture of his femur and a broken collar bone. Beloki still isn't near on form as he was when he finished 2nd in the '02 Tour de France.
Originally Posted by tlupfer
yep, because you never hear about rolled tubulars...
Isaias
Bikes: Ridley X-Fire (carbon, white)
Quoted: 7 Post(s)
Originally Posted by DRLski
you could always go tubular clinchers, solve both problems
Scum, Freezebag!
Bikes: 2007 Leader 796R w/ 10sp DA and 2005 Jamis Dakar XLT FS MTB
and...
...unavailable for comment.
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
Originally Posted by EventServices
30mph is considered "barrelling"?
I was waiting for this.
In Transition
I get at least one puncture a week. 3 on descents just this season. Never had a clincher roll. Maybe if it happened in the middle of a really high speed turn and quickly enough to instantly deflate but I can't imagine the circumstances that would cause that except maybe . . .a stray bullet? Wait. . .is this the exploding derailleur thread?
Bikes: Trek 5500 OCLV, Trek Fuel EX 9
As much as I love this forum and the great information that gets shared here, you have once again reminded me to be discerning when accepting statements at face value without seasoning first with a dash of common sense.
Location: In the middle of horse country, in The Garden State
Originally Posted by webist
To me it is.
Resident Old Fart
Bikes: Douglas Precision Ti
Wag more, bark less
Wag more, bark less
