Proper spacing when hanging bikes in garage by one wheel?
Bikes: Stevenson Custom, Stevenson Custom Tandem, Nishiki Professional
Quoted: 367 Post(s)
Liked 195 Times
Thought I would go for the trifecta.
We've discussed: (1) hanging bikes by one wheel in the garage, (2) issue of unheated but insulated garage for storage, so for (3) what is recommended as the distance between bike hangers if you hang them front wheel/handlebars, rear wheel no handle bars, front wheel handlebars, etc.?
I know it depends on handlebar width, mine run 38-44.
Thanks for your recommendations.
Take Care
Take Care
If I own it, I ride it
Bikes: Lejeune(14), Raleigh, Raysport, Jan De Reus, Gazelle, Masi, B. Carré(4), Springfield, Motobecane(2), Greg Lemond, Andre Bertin, Schwinn Paramount
Quoted: 591 Post(s)
Liked 656 Times
No set distance. Just enough to provide clearance. I hang mine, alternating front wheel hang, rear wheel hang.
Likes For CV-6:
Quoted: 767 Post(s)
Liked 1,897 Times
I'd guess about eight inches. I base that on a hanger kit I have where the bar is, I think, 48" long and holds six hooks. Bikes get hung staggered front up/front down. Depending on surrounding clearance, hanging and removing can be a bit dicey.
Quoted: 752 Post(s)
Liked 732 Times
I've got everything from 2 wheels on ceiling hooks spaced 12" center to center. I also have a 16" offset between bikes. I'm sure 9' center to center would work, but 12" makes it easier to get them in and out. 9" would probably be fine with a wall rack and enough space to handle them in an ergonomically correct manor.
Likes For bark_eater:
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
I settled on 12" between hooks, and am content with that. Some bikes are a little snug, but it's not a big deal to swing one neighbor out of the way with my shoulder while hanging one up or taking it down.
Likes For ThermionicScott:
Likes For shoota:
Habitual User
Quoted: 4828 Post(s)
Liked 7,819 Times
The bikes on the wall are spaced at about 15". I could probably go a little tighter if I was trying to make things more compact.
Quoted: 1601 Post(s)
Liked 2,187 Times
I don't recall spacing on this configuration. I had the problem of height limitation. Removed the front wheel to rotate the bar and then hang the wheel on the pedal. Worked fine.
P8031673 on Flickr
Now the spacing here is 10" which is a problem with upright bar bikes. This also allows alternating direction of the bikes or not.
P1000485 on Flickr
P8031673 on Flickr
P1000485 on Flickr
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 248 Times
Great question ! I am getting ready to install hooks for hanging my bikes. Very helpful to see the examples.
Edumacator
Quoted: 2384 Post(s)
Liked 2,930 Times
For those hanging them on the wall, how do you keep them from pivoting back and forth against the other bikes? Or you just push them aside when needed?
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 577 Post(s)
Liked 685 Times
Names of all posters here will be noted as having a greater problem that has created this problem.
Likes For sd5782:
Habitual User
Liked 7,819 Times
Gravity pulls the bike against the wall with enough force to keep them in place, but they are still easy to push aside, when needed.
Likes For Eric F:
feros ferio
Quoted: 1384 Post(s)
Liked 1,293 Times
You mean bike hoarding? I resemble that remark, and I am one of the small players in that game.
Bikes: Yes
Quoted: 3228 Post(s)
Liked 3,851 Times
That's your answer right there. The space between the hooks should be the width of your handlebars. I've got mine lined up, handlebar-to-handlebar, with a second row that let's me use the space in between. I tried hanging alternate bikes from the rear wheel, but that's awkward to hang or take down. The second row is also tricky, since it needs to squeeze between two sets of handlebars, so you might want to leave an extra couple of inches if you plan to do that.
BTW, the RubberMaid FastTrack system lets you move the hooks.
If you're just screwing hooks into the wall, you'll either need an additional board to screw into or you'll be limited by where the studs are.
My Bikes
My Bikes
Bikes: Yes
Liked 3,851 Times
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 367 Post(s)
Liked 195 Times
Thanks posters for your advice and the pictures really help.
Why ask the question?
The wealth of perspectives and solutions provided above.
Take Care
P.S. Will post when I've got the garage storage done.
Take Care
feros ferio
Liked 1,293 Times
Point well taken. I do envy folks with ample storage and workshop space.
Quoted: 367 Post(s)
Liked 195 Times
AndyK and BFisher what wall hook rack systems do you use?
Are they still available?
I like it that you can adjust the hanger placement to fit different bikes as your collection changes without making more holes in the garage walls.
Take Care
Take Care
Edumacator
Liked 2,930 Times
I built that awesome custom bicycle holder when I thought I would limit myself to 6 bikes....oops. Now I have to figure out another system and sell/rehome the custom, wheeled monster.
Likes For jdawginsc:
Bikes: Yes
Liked 3,851 Times
I started out with a 4-foot rail and two hooks. Then N+1 happened.
My Bikes
My Bikes
Edumacator
Liked 2,930 Times
I use the Rubbermaid FastTrack Rail system. It's still being sold at places like Home Despot.
Sort of expanded like the US railroad systems in the gilded age?
Quoted: 4741 Post(s)
Liked 3,860 Times
I hang mine all by the front and stagger the heights. (Makes putting them away far easier.) 11" apart, heights staggered 12". Lower hook at 72" off the floor. I could narrow up the spacing but hanging my heavy farmers market bike and road bikes hammered from rides is easier with a little extra room.
Quoted: 3788 Post(s)
Liked 6,572 Times
I don’t have a garage but instead a 170-year-old basement with a relatively high ceiling. My hooks are spaced 12” apart, and I stagger hanging by front and rear wheel.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4667 Post(s)
Liked 5,764 Times
The objective is to pack them as closely together as possible. Some people are in the unenviable position of being limited in their bike purchases by storage space. For those people I recommend making friends with those that have more storage room than bikes (I know, how can this be?) and bone up on the Zero Bike concept.
small ring
Quoted: 437 Post(s)
Liked 925 Times
standard 16" stud spacing works if you stagger the hook height
The ones to the right work good, the ones to the left are a little too close together vertically
72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Likes For droppedandlost:
