Bent edges on rear hub-cassete connection
Hello,
Doing bearing change i managed to bend the rear hub edges where the cassette connects. I don't know how/if this will affect anything moving on.
Connecting the cassete works fine, and it moves perfectly. I think if anything, the dents and scratches may affect the dust seal there...?
Can anyone advise? Btw, this is a DT Swiss H1900 wheel with 370 hub and Shimano HG cassette.
Unfortunately i cannot attach pictures or urls.. ☹️
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,568 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
How on earth did you do that?
Well not sure but either when kicking the opposite bearing out.... or when I improvised a press to get this side out.The "press" had a round edge pressing here which i did not realize.
After it was bent, i un-bent it as you can see in the picture, with a small wrench..
Yeah, I know ... not smart.
Soooo ... is it dead? 😟
Bikes: lots
Liked 2,932 Times
Nah, it doesn't look like you killed it and it sounds like it works so keeping running it.
SE Wis
Quoted: 2742 Post(s)
Liked 3,389 Times
Might touch it up with a little emery cloth to knock the burrs down
Sometimes you get lucky and a socket fits just right. Tap it in, tap the high spots towards the socket.
