Appropriate gearing for an 8-9yo?
Quoted: 1079 Post(s)
Liked 1,019 Times
Trying to figure out best gearing for my kid's racing bike and he's effectively no help in the process. We've switched around his gearing some and he just can't tell me if its better or not. Have the same issue with him and my oldest on their velodrome bikes as well, easy solution to that was gearing the bikes close to the USA cycling rollout for their age group. But I haven't really found recommended gearing based on age and every change I've ever made, taller or shorter gearing, has earned the designation of being better though after using some he was obviously slower. Current gearing is 45/14, seems to do ok with it but not certain if this is decent or not. Like his sister, on their velodrome bikes they're clearly better at pushing bigger gears then spinning which I need to work with them on.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), Yess World Cup race BMX, Redline Proline Pro24 race BMX Cruiser
Quoted: 345 Post(s)
Liked 186 Times
Russ - not sure what tire you're running, as that can change the gearing as well, but in any case that is an absolutely MASSIVE gear. Very seldom does a top rider run very far above the classic 55 gear inch BMX standard (44:16 on 20x2" tires, roughly)
My kids are running:
9yo - 42:16 / 54 gear-inch / 170" rollout
10yo - 40:15 / 55.75 gear-inch / 175" rollout
I'm running (as a 42yo inter):
44:16 / 54.9 gear-inch / 172.5" rollout
I definitely want to lower the gear a little for my 10yo, and I think I'm going to try going back to 43:16 for my own bike at my next race.
What your son is running:
45:14 is 64-65 gear-inch / 202" rollout.
Kids around that age can sometimes be successful running slightly higher gears than older kids because they often have trouble spinning to the same max cadence, but I'd say that is pretty extreme. Even the pros run less gear than that on the 8m start hills. Acceleration at the start is generally accepted to be far more important than pedaling later on the track.
BMX Ultra gear calculator is a pretty good resource that takes into account tire size as well.
Liked 1,019 Times
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
I didn’t want to chime in as I wasn’t super fast, but I remember friends that were faster running a similar setup.
I rode past a CHP speed trap trailer at 29mph. The fastest in our group of friends hit 30.
Hope that helps.
