1st Generation Silver Shifters In Stock At Rivendell
Quoted: 405 Post(s)
Liked 430 Times
Just an FYI for those who care:
The 1st generation Silver downtube shift levers are in stock at Rivendell right now. These are the longer downtube-lever shaped ones, as opposed to the short-handled 2nd gen thumbie / barcon levers.
I'm not a compulsive Riv-checker, but it seems to me that these haven't been available for a long time. I've wanted a pair since I first saw them in the early Naughties... the Suntour Sprints they were copied from were the business. So, when I saw them in stock and I had the bread, I jumped on it. (Especially because the OEM LePree levers on my Fuji are pretty mediocre.)
--Shannon
--Shannon
verktyg
Quoted: 1036 Post(s)
Liked 1,236 Times
Dia-Compe "Silver" W Shift Levers
Last year I modified a Campy Veloce 10 speed RD to use with an 8 speed chain and 12-30T Shimano 8 speed cassette. I used longer Shimano pulley cage screws with .5mm washers on both sides of the pulleys to better fit the wider 8 speed chain.
I needed to find some down tube shift levers with enough wrap to cover that combination. DuraAce 8 speed levers wouldn't do it so I bought several levers rated for 8-9-10 speeds.
The first was a set of microSHIFT 10 speed indexable levers.
They worked pretty well in both friction and indexing mode but the stubby levers were designed for bar ends and looked weird mounted on the down tube.
The next day a set of Dia-Compe "Silver" W Shift Levers arrived. Besides looking much better on the bike they friction shift fantastic. The design is a take off on the old Suntour Power Shifters but the steps in the ratchets are much closer thus smoother.
They seem to be the same levers marketed by Rivendell. My only question is how durable are the black plastic spacers under the lock screws going to be? (gray on the Rivendell levers). Also, the ratchet mechanism is not as robust as on the old Suntour Power Shifters.
verktyg
Why the modified Campy RD?
Because I liked the way it looks and I wanted everything to be matchy-matchy - black and blue!
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 405 Post(s)
Liked 430 Times
They're an accurate reproduction of the 1985-86 Suntour Sprint shift levers. Pawl-and-ratchet action like the Suntour bar-con levers of blessed memory, but with many more teeth of much smaller size and a lever profile for downtube mounting. The only time I ever rode them was on a black-and-chrome Schwinn Circuit. (It was a club spare that I used in a junior crit when my bike broke.) The shift levers were one of my favorite things about one of my all-time favorite bikes.
And, yeah, the link in Germany_chris's post above is correct. I forgot to link the page.
--Shannon
Friendship is Magic
Bikes: old ones
Quoted: 26246 Post(s)
Liked 10,229 Times
...Velo Orange is selling a similar ratcheting downtube shifter, in two different versions on their website. The more expensive ones have additional pull distance, so the will work with 11 in the back. They are also selling the plastic washers separately. I, too, wonder why they are made from plastic. You can also find them on e-bay under the name "ene ciclo" . The levers themselves look a little more like Campagnolo NR levers. I ordered a set for a bike I'm putting back together in a month or two. If they are as good as everyone says, I might order more of the $55/pair ones. Maybe. Assuming they don't disappear again.
Crawlin' up, flyin' down
Quoted: 1006 Post(s)
Liked 2,465 Times
Note that in both cases, the price is for one, not per pair, so it's about $130 if you want the entire barcon package.
Quoted: 405 Post(s)
Liked 430 Times
Got the levers on Wednesday, installed them on Sunday at the co-op. Test rides seemed good.
Today was the first commute on the new shifty bits... They rock. Much faster than the straight-friction LaPrees, with way less lever travel per shift and overall. That's really nice on the front, since I'm running a road double front derailleur with 45/42/30 triple crankset. The LaPrees used their full swing to reach the big ring. The Silvers have travel to spare.
The shift to the granny is a double-double, 42x26 to 30x20. I make this shift once per ride to work, since the shop is at the top of the only hill on the ride. (8%, 1/2 mile) This morning, I had the best granny-shift since I put the triple on the bike. Almost a single motion. I need more practice on my double shifts, 'cuz it's so, so good when you nail one.
The shift feel is really, really nice. Almost as smooth as Simplex Retrofrictions, in fact. You can feel the little ratchet teeth, but it's almost subliminal, like a little "zzzzt" through your fingertips. It's nothing like the toothy feeling of a Shimano bar-end lever in friction mode. And the Silvers are so much quicker than the Simplexes. We'll see over time, but on balance I may like them better.
Yeah, 70 bucks plus shipping is a ludicrous amount of money to spend on downtube levers. But these are really, really good.
--Shannon
--Shannon
ambulatory senior
Quoted: 1953 Post(s)
Liked 3,633 Times
I've had a set of the grand comps and the silvers and both were great when new but they are more delicate than suntour barcons. An old set of barcons is my preferred. Ymmv.
Overdoing projects
Quoted: 783 Post(s)
Liked 1,215 Times
The supplied bolts are a bit rusty now on mine. I put them on the Batavus Randonneur GL a couple of years ago. I'll try to shoot some photos tomorrow.
Dia Compe makes these shifters for Rivendell.
They're also selling them under the Dia Compe brand as downtube shifters, bar ends, and stem shifters, available as ENE version as well.
Now available for 11 speed, rear shifter has a bigger body to pull more cable.
Quoted: 405 Post(s)
Liked 430 Times
--Shannon
Only 1 type of 10 speed ratcheting 'smooth' Silver shifters I know about and mine were purchased brand new as Dia Compe not Rivendell. They look identical to me.
Likes For Schlafen:
Quoted: 405 Post(s)
Liked 430 Times
How'd you like 'em as bar-ends? I always worried that they'd be too long. (Not that it matters... The pods aren't available for love nor money.)
--Shannon
Liked 2,465 Times
Quoted: 405 Post(s)
Liked 430 Times
(Definitions of "I can" may vary.)
--Shannon
Likes For ShannonM:
verktyg
Liked 1,236 Times
Ed Litton
Over the years Ed has painted several frames for me and I've bought a number of old frames from him that he had in those stacks of boxes "upstairs".
Two years ago to the day, I stopped in to see Ed. He'd just pulled this frame out of his upstairs stash and it was hanging on the wall. We'd been talking about him building a frame for me for years. It was my exact size so I bought it instead.
July last year, I ordered a new custom road frame from Ed, like this Della Santa track frame. Last week, he said I was number 3 in line!
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Liked 2,465 Times
Please tell us you heard that from Ed and not from Roland . . . .
Never used downtube or bar ends in the past so I tried it now just for kicks. Had them on for a couple months. Suitable for long distance riding where not alot of shifting is required, maybe for long stretches.
Painful if you ride in traffic or anywhere you have to shift often and precise, but this applies to all bar end, downtube, stem or any other weird contraption friction shifters in my book. Def more involved than brifters, not worth the effort for me. I would rather not put that much effort into shifting alone. Would pick brifters any day as they've been very reliable for me, But I prefer11 speed brifters, so there's that.
The Dia Compe bar ends work fine and the ratcheting is smooth but can't see how it helps in any way, wouldn't say it's a feature, they are friction only. I'd rather go for a indexed type next time, if ever, most likely never.
As far as pods availability, if I'm not mistaken, by looking closely at them, these pods look like Shimano, so if you can find similar looking Shimano pods you should be golden, probably cheaper as well. I would suggest trying to find 10 speed pods as the ones for lesser cogs may not have enough space for the levers, but I'm not a connoisseur in old tech so someone else may want to chip in.
I've sold mine in the meantime, they were paired to a 10 speed T6000 rear derailleur, no clutch, and 11-34 SLX cassette, so depending on your setup you may need the leverage as it's taken more than a gentle brush against the lever to shift the 34 cog, would say it could be even harder to shift a clutched derailleur, so lever length is adequate. You can position them so they flare out slightly if worried about hitting them with your knees when inline with the drops, but it never happened to me. My handlebars were Nitto B135AA so they are already flared.
The derailleur I used had a mtb pull so a bit of modifying was required. Bare that in mind for when choosing a derailleur. Allthough the new 11 speed lever for the rear derailleur has a significantly larger body for more pull, only by looking at it I woukd say it's not compatible with the 10 speed pods, there was a very small gap on the ones I used. Possibly downtube use only at the moment.
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
Brifter biased so to me they are simply archaic, there's just no other way to put it, 2/10 wouldn't do it again.
That said I have no use for bar ends, IMO a ridiculous place to put shifters, downtube only for me.
Brifters are extremely convenient and reliable.
Bar end mounted friction is more convenient than downtube mounted.
Bikes: 1988 Ross Centaur, 2010 Fuji Connoisseur, 2015 Raleigh Tamland 1, 2017 Raleigh Carlton, 1987 Team Miyata, 2012 Soma Stanyan, 2015 Cinelli Supercorsa, 1984 Miyata 1000, [2009 Scattante SSR], [1988 Falcon Competitor 105], [2016 Soma Wolverine]
Quoted: 26 Post(s)
Liked 12 Times
I have the 1st gen Silver shifters on one bike, the Dia-Compe ENE's on another, the MicroShift's on yet another bike, and the typical Shimano's on two more bikes - all installed bar end. Can confirm the Silver shifters are marginally too long for bar end installation, but I think the squared off end is more the issue than the length. The corners can inflict a special kind of pain when they catch your knee!
