Useful bike-specific tools
I'll primarily be maintaining 1 road and 1 gravel bike (both Giants with Shimano groupsets). Over the years, I've built up quite a bit of general tools. I already have hex sets (SAE and metric), torx, pliers, channel locks, hammers, etc... This is what has turned me away from purchasing a complete "home bike mechanic" set - I already have half+ the tools.
What I'm wondering is, which bike-specific tools would you recommend purchasing e.g. to work with:
1. The chain
2. Disc brakes/rim brakes
3. Torquing the fasteners down to a specific spec (I have a HUGE truck torque wrench, not useful here)
4. Any other useful tools for dereilleurs, headset, or other general bike work?
One thing I did see were these sprocket brush tools that I want to grab, and perhaps the Park Tool 4B book or whatever its called. In general, I'd prefer Park or some other quality tool brand but even just general tool types and what they would be used for could be useful. Thanks.
1. The chain
Quoted: 194 Post(s)
Liked 204 Times
I cannot say what bike specific tools you need because I am not that familiar with your bikes; however, I would not be too put off from purchasing a set of tools if it had some very useful ones for my purpose just because I already have some of them. There will always be some unusual task that may require more than one of a particular tool, or one where tools have to be used in non-standard ways. For example, yesterday I was using two sockets plus a nut and bolt to press out a sleeve from one end of a rear suspension unit, and of course the nut required the same size socket.
Plus anything offering a 10 mm socket or spanner should always be considered....
If you do your own chain/cassette maintenance and replacements, a chain tool, chain pliers, and cassette lockring tool are IMO "must haves". If you do your own wheel/hub service, IMO cone wrenches are a must if any of your wheels have cup&cone bearings (not needed if your hubs are sealed bearing designs). These are all relatively inexpensive, even if you go the higher quality route (Part Tool or Ice Toolz).
Depending on how experienced you are with mechanical work and judging torque by "feel", a set (1/4" and 3/8" drive) of inexpensive torque wenches might be a good buy as well - the 1/4" drive in particular if you work on carbon components. Ditto a set of metric Allen wrench drivers (sets of 13 ranging from 2.5mm to about 10/12mm are available) if you don't have them already. But a pair of even lower-end torque wrenches are going to cost you around $50 or more. The set of Allen wrench drivers can be had for <$20.
Many other bike specific tools exist, but you may or may not need them depending on the precise equipment you have.
Just my proverbial "two-cents worth".
Last edited by Hondo6; 09-09-21 at 06:35 AM. Reason: Add info inadvertently omitted in the original.
Quoted: 2604 Post(s)
Liked 1,928 Times
By all means get yourself a CT-3.x chain tool, and the Shimano cassette lockring tool (FR-5.2). I suspect the 5.2G can be made to work with 12 mm through axles, if you have those, but I haven't personally verified that. The big CT-3 is worth having in your toolbox over the dinky little versions. I've done fine with regular pliers to get quick links off, so I don't think chain pliers are required. A good cable cutter is great, although you can get by with a Dremel cutoff wheel.
Think about what you'll need to fix common problems on the road. Each of my bikes has a seat bag with a spare tube, patch kit, tire levers, and multi-tool. Add your choice of either inflator and CO2 cartridges or a pump. (Note my flat tire kit gets a lot more use than the multi-tool.)
For the rest, wait until you need a tool to buy it. Steel bike with integrated derailer hanger? Might want a derailer alignment gauge. Wheels breaking spokes and/or going out of true? Load up with appropriate size spoke wrench, truing stand, and tensiometer. Unless you buy the Park catalog, there's always going to be a tool you didn't think of; and if you do buy one of everything, you're going to be sitting on a bunch of unused, expensive tools.
Quoted: 2338 Post(s)
Liked 2,822 Times
if you think you will be doing this on a regular basis buy good tools it is cheaper over time.... a $10 chain can work well until it doesn't but the $37 park works so much better and will last forever
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
I'll second the PCS-10. I used to have a PCS-1, which I named Mister Wobbles, for obvious reasons. Even if you get a different brand stand, it should have a vertical adjustment to raise and lower the bike. Your back will thank you.
One tool I have, that is not bike specific, is a 6" Dewalt trigger clamp. It works like a dream for adjusting rim caliper brakes.
Also, a JIS +2 screwdriver for those derailleur set screws (they're not Phillips).
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,466 Times
These are the bike specific starter tools which I have amassed so far:
1. Mini torque wrench: Amazon.com : Topeak Nano TorqBar 6 with 5 Tool bits, 6nm : Sports & Outdoors (there are also 5nm and 4 nm versions)
2. Tripod bike stand: Ultralight Bike Repair Stand | Feedback Sports
3. Cassette lock ring tool: Amazon.com : Park Tool FR-5.2 Cassette Lockring Tool - Fits Shimano, SRAM, SunRace, SunTour, Chris King, Others : Sports & Outdoors
4. Chain link tool: Amazon.com : Park Tool CT-3.3 Bicycle Chain Tool : Sports & Outdoors
5. Chain quick link pliers (for both opening and closing quick links): Amazon.com : Super B 2-in-1 Master Link Pliers (The Trident) : Sports & Outdoors
6. Chain wear checker: Amazon.com : Chain Checker Plus II, Black : Sports & Outdoors
In addition to the above, I also have Park Tool CWP-7 (crank puller), BBT-22 (bottom bracket tool), CG-2.4 (chain scrubber) and a 2 quart Crock Pot for chain waxing.
Likes For SoSmellyAir:
Liked 1,466 Times
I agree that a torque wrench is mandatory for carbon fiber components. Luckily all the bolts for the carbon components on my bike are 6 Nm, so I bought this reputable but inexpensive one: (Amazon.com : Topeak Nano TorqBar 6 with 5 Tool bits, 6nm : Sports & Outdoors). An additional advantage is that this mini torque wrench fits where others do not, e.g., forward bolt of Cannondale Save seat post (15 mm offset).
But neither comes with any Allen driver sockets. Those have to be purchased separately.
Last edited by Hondo6; 09-09-21 at 06:52 PM. Reason: Add info and correct poor wording.
This is probably going to make me sound like a complete dummy but I swear the"fifth hand" thing someone gave me has kept me from setting more than a few bikes on fire and walking away.
Quoted: 965 Post(s)
Liked 1,629 Times
The Pedro's unit you linked looks quite nice - much nicer than the one I have now. Might need to consider getting one of those myself.
Liked 1,466 Times
Good catch on the chain wear checker. Can't believe I forgot that in my first comment above - pretty "bike specific", and even a cheap version can save $$$ via avoiding premature chainring and sprocket wear-out. It really is a pretty essential tool.
I also forgot to mention the chain whip. Without one, the cassette lock ring tool is not all that useful.
Thanks folks. I ended up purchasing a Pedro chain checker, master link tool, rivet tool, and torque wrench. That should get me a good start and the ability to replace my own chains as necessary and make sure my fasteners are tightened properly. Should I need to replace my cassette and such (or maybe even to do a deeper clean down the road) I’ll get a whip and the proper lock ring adapter thing when necessary. I also forgot to mention originally that I already had a bike mechanic stand.
Quoted: 2432 Post(s)
Liked 638 Times
About 20 years ago I bought a cheap heat gun and I've used it countless times. Because it expands metal it will help break loose frozen bolts like chainrings, seat posts, ect. Nice for installing headset cups/lower bearing races, pressfit bottom bracket bearings, removes wheel decals and all kinds of other stuff you wouldn't think of. You can get one for less than $30.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
1) bike work stand
2) chain whip
3) crank puller
4) cassette lock ring tool
5) bottom bracket removal tool
6) cable cutter (gotta get one of these myself)
2) chain whip
3) crank puller
Liked 1,466 Times
Liked 1,928 Times
I've got a Pedros cable cutter that works well enough. Beats pulling out the Dremel to cut cables and housing.
Of course, perfect is the enemy of good enough. Wonder if anyone can find a Hozan for Christmas?
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
It’s hard to beat the Park CN-10. They are heavier duty than many others. The Pedro’s, for example, have sheet metal handles while the Park’s are forged solid metal. They are a little less flexible. They also have a better crimping mechanism for cable ends.
Stuart Black
Stuart Black
Liked 4,217 Times
Stuart Black
Stuart Black
Bikes: 2000 Santana Sovereign SE; 2005 Co-Motion Speedster; Kona Kilauea with various dorky commuter accoutrements; Mercier Kilo TT fixie; Burley Fladbed trailer for groceries, bags of cement and the like.
Quoted: 95 Post(s)
Liked 85 Times
My precisely engineered custom chainwhip has worked like a charm for years. Just used it last night.
Liked 1,466 Times
I like it! Environmentally-conscious product made from recycled materials, with that highly sought-after rustic, distressed, salt-of-the earth look and feel. On top of that, probably works better as a self-defense weapon than the $11 one I bought from Amazon years ago. Perfect product to heal our divided nation.
Liked 1,466 Times
