BBB PowerPull or Icetoolz 04d2?
I tried to read the reviews and they are about even. Many good reviews with some bad reviews mixed in saying both tools completely stripped the cranks and stuff. Think they are about even? or is one clearly better than the other? I like the Icetoolz one because it includes the 14mm nut socket which I don't have. A socket set is pretty expensive and that built in function would help a lot.
Quoted: 836 Post(s)
Liked 1,058 Times
+1. No worries about the quality of this tool. Also has two sized tips for different crank axles. You only need an adjustable wrench if you have one and don't want to buy a socket. I would also add that it's hard to tell with the bad reviews on the other two removers if the reviewer was using them properly. Sometimes people don't screw them all the way into the crank threads resulting in stripping them out and blaming it on the tool.
