Grease stain a sign of inexperience?
Likes For LarrySellerz:
Quoted: 3498 Post(s)
Liked 2,911 Times
Dirty chain...
climber has-been
Quoted: 3417 Post(s)
Liked 3,548 Times
Folks around here call chain grease stains on your calf a "rookie mark", or a "newbie tattoo".
Ride, Rest, Repeat. ROUVY: terrymorse
Likes For terrymorse:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
It's the sign of someone who puts the wrong foot down when they stop.
Likes For Rolla:
Quoted: 9652 Post(s)
Liked 6,364 Times
What's the right foot?
Fortunately, the solution to those oily, greasy stains is as close as the nearest dumpster. Vodka cleans them right up!
Likes For Reflector Guy:
Quoted: 20808 Post(s)
Liked 9,450 Times
So, I struggled with this one, too, but I found a little trick - if you hold your hands out, palms facing away, and make a right angle with your index finger and thumb on each hand, the side that makes an uppercase "L" is the Left and the other side is the right, obviously.
Likes For WhyFi:
Quoted: 1034 Post(s)
Liked 1,289 Times
It doesn't just happen to noobies people. I was on the bike, straddling it.
Guest
Liked 3,270 Times
Quoted: 822 Post(s)
Liked 1,955 Times
Rookies! Real pros know how to tattoo with just the big chainring.
Likes For CAT7RDR:
ignominious poltroon
Quoted: 2229 Post(s)
Liked 3,412 Times
It is the sign of someone who doesn't use wax.
Likes For Polaris OBark:
Quoted: 6945 Post(s)
Liked 10,945 Times
Likes For Koyote:
Quoted: 3241 Post(s)
Liked 2,512 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
TBH, this happens to me from time to time when I'm carrying or moving the bike--like in a roadside flat situation or loading or unloading from a car. It very rarely happens during riding--once every couple of years, maybe?
I wear black socks, however. Couldn't tell you if those are getting tattooed.
Likes For livedarklions:
Liked 9,450 Times
Likes For WhyFi:
Tragically Ignorant
Liked 9,098 Times
Thank you very much. This is a very good suggestion. I believe that through this way, we can find a suitable chain lube for ourselves.
For most riders, a new chain lube is a major financial investment. It's important, then, to prevent rust or corrosion from damaging your chain lube.
The condition of the chain lube is our most important consideration. Before each ride, we must develop a habit of checking whether the chain lubes are sensitive, and whether the chain lubes are working when riding at night. Although riding is good, if you do not master the correct chain lube, it is easy to cause physical injury.
The biggest concern people have with chain lube is how long the chain lube will last. Generally speaking, the service life of an chain lube is three to five years, and the factors affecting the life are mainly the following aspects.
1. One of the best ways to ensure that your chain lube will last for many years is to avoid contact with bodies of water.
2. chain lubes are one of the most important parts of an chain lube and can last a long time, depending on many factors. A thorough inspection every few months is recommended. The chain lube is the only contact part between the chain lube and the ground. With the right speed, clean terrain, and a good PSI setting, chain lube will last the longest.
3. You wouldn't know under what conditions your chain lube would suddenly fail.
4. chain lube can effectively block the muddy water and sand particles driven by the chain lube when riding.
The custody of Cycling Pants is indeed a big problem.
And will pay attention to my words in the future.
Tragically Ignorant
Liked 9,098 Times
Quoted: 2698 Post(s)
Liked 486 Times
Happens to me literally every day, my right leg has a few faded marks that I didn't scrub out in the shower well enough and i havent even ridden today yet
Quoted: 957 Post(s)
Liked 1,619 Times
So very Sexy!!!
Likes For zandoval:
Tragically Ignorant
Liked 9,098 Times
Liked 6,364 Times
Quoted: 3943 Post(s)
Liked 7,286 Times
Likes For tomato coupe:
Liked 6,364 Times
I'm confused.
Liked 10,945 Times
Likes For Koyote:
Quoted: 18404 Post(s)
Liked 15,496 Times
I’ll get one from time to time while out on tour. A loaded bike can develop a mind of its own, especially when you dismount on uneven ground.
Pro tip: Try removing it with sunscreen.
