magnetic toe clips
magnetic toe clips
Hello people: While on the net, a pop-up came for them. No clipping in just place your shoe on it and you're in. What do youz think about that?
IBBY
IBBY
climber has-been
Quoted: 3427 Post(s)
Liked 3,564 Times
Thread Killer
Quoted: 3137 Post(s)
Liked 1,705 Times
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
Power it with that 12V truck battery!
Quoted: 6963 Post(s)
Liked 10,963 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
I prefer Velcro.
John
John
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
They are not equipped with a firm mechanical connection comparable to standard clipless pedals. The force of the magnets can be impacted by several factors including magnet size, dirt, wear, and direction of force applied. Unintendedly disconnecting from the pedals is possible at any time.
Likes For Chuck M:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I'z think the OP is a troll. Youz may think different.
Quoted: 18413 Post(s)
Liked 15,536 Times
Bikes: The Good Book of bicycling
Quoted: 535 Post(s)
Liked 36 Times
i use strapless bicycle toe clips; amazon has tons of them.
https://www.amazon.com/EVO-Double-Qu...086361&sr=8-24
this is just one example, there is no need for straps and i have yet to break the plastic after years of riding.
hello people and corn heads too: I like that strapless idea. One of my bikes I have the old style with the straps and it's mostly metal. Those are just plastic correct? Which one do you like?
IBBY
IBBY
climber has-been
Liked 3,564 Times
Quoted: 696 Post(s)
Liked 910 Times
Hi Larry!
Liked 15,536 Times
I don’t need cleats or magnets. The force binds me to everything.
Likes For indyfabz:
Friendship is Magic
Bikes: old ones
Quoted: 26415 Post(s)
Liked 10,380 Times
...I'm currently patenting an idea to use magnets for helments, called MagnetoHelm ®, instead of straps.
They will be marketed toward the demographic of riders with a metal plate in their heads, from previous crashing.
Quoted: 206 Post(s)
Liked 460 Times
3 seconds on duckduckgo yielded this result: https://hustlebikelabs.com/
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,637 Times
For downhill mtb it tends to make sense. MTBers don’t tend to be out of the saddle hill climbers like roadies, unless they are highly competitive. Most I know just mash the pedals on climbs, myself included. Holding your foot more securely on descents while MTBing makes good sense.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Thread Killer
Liked 1,705 Times
I would be very surprised if that were true.
In fact, I think I’d wager good money that there certainly are magnets strong enough that, when sized to fit the area of a typical cycling pedal, could resist any amount of pull force a rider might generate.
For example, here are 1.25” diameter round magnets with up to 95lbs pull force available on Amazon. A magnet on the shoe working with a magnet on the pedal would be expected to have even higher pull force. I would be very surprised if anyone was pulling their foot off the pedal with anywhere near that kind of force.
I’d further wager that the major obstacle in magnetic pedal/shoe attachment is not generating sufficient retaining force, but rather how to overcome such sufficent retaining force to make rleasing easy, natural, and safe.
Liked 10,963 Times
You're actually taking this OP seriously?
Quoted: 2494 Post(s)
Liked 738 Times
Where have you guys been? There are at least four or more different designs of magnetic retention pedals on the crowdfund circuit and probably a couple have been vaporware, but the technology is here to stay. Way too heavy and overpriced for me to consider, but from several posts I've read, the very idea strikes some of you as preposterous. Go to a hardware store and see where neodymium magnets have gone while y'all were sleeping. Some of them are DANGEROUS they are so strong. The real issue with magnetic pedals isn't whether they will retain your foot, they've got that part pretty well covered. Will you be able to release on command?! Getting that dialed for the different tastes and abilities or riders is the tricky bit.
Quoted: 3241 Post(s)
Liked 2,512 Times
climber has-been
Liked 3,564 Times
