Crack in my MTB bike?
Hi folks, purchased a used Mountain Bike, a 2011 Giant Faith. Gave it a wash and noticed what I think is a crack. Hopefully its just the paint/gel coat splitting and it doesn't flex when I apply pressure or anything but hoping someone out there has seen this before and can confirm for me. Thanks all!!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You're kidding, right? No photos? How is anyone supposed to give you advice on something that is purely visual?
Likes For cxwrench:
LR÷P=HR
Quoted: 864 Post(s)
Liked 1,198 Times
Pic's
tinofenotti
Welcome to Bike Forums.
Just in case you haven't worked it out yet, you can't post pictures until you have Ten posts.
It's an anti-spam thing!.
Barry
Barry
Quoted: 1607 Post(s)
Liked 2,583 Times
You can still put pictures in your album. Maybe you could tell us where said crack is located.
Liked 2,583 Times
Picture assist
ignominious poltroon
Quoted: 2238 Post(s)
Liked 3,429 Times
That's a crack. You should be able to feel that easily.
Whomever sold it to you is a crook.
Likes For Polaris OBark:
Quoted: 836 Post(s)
Liked 1,060 Times
Doesn't look good but take it to a shop so someone can see it in the flesh which will be more accurate than anyone here could could do with just a photo.
Quoted: 4197 Post(s)
Liked 3,849 Times
Pull the post out. Drip oil into the seat tube with the bike positioned so the "crack" is on the bottom, wrap paper towel around the crack. Come back later and see if the oil wept out through the crack and into the paper towel. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Clark W. Griswold
Quoted: 4346 Post(s)
Liked 3,982 Times
That is a crack and for future reference if you decide to stick around always post photos for visual if you have an issue you don't you just needed to make a few more posts till you get to 10 which is super easy because this is a bike forum and you must obviously love bikes to join a bike forum and there are always plenty of active threads to join in. Welcome and enjoy, and yeah still a crack.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Originally Posted by tinofenotti;
hopefully its just the paint/gel coat splitting
Likes For Rogerogeroge:
Quoted: 961 Post(s)
Liked 1,627 Times
OK Andy... Ya got me... Why oil?
Likes For jccaclimber:
Quoted: 453 Post(s)
Liked 104 Times
Why? your assuming that the seller knew it was there.
Being that the buyer said they needed to wash it to find it, would indicate that the bike was sold is a dirty condition, which would indicate that it was being used prior to purchase, and the seller possibly didn't know it was there.
The question then should be, why buy a bike that's dirty/not washed, as it can potentially (like in this case) have major issues not immediately visible.
If you're going to buy a dirty bike, the price should reflect this, no mention of if they buyer paid market value or less, not a lot of info supplied to go on.
Quoted: 714 Post(s)
Liked 798 Times
That was a predictable failure and I'd bet that every one of those frames will fail in the same spot. Putting a bend in that section of tube, that is subjected to resisting the force of the shock spring with every hit, turned that tube into a hinge that flexes with every suspension cycle.
Likes For dsaul:
Liked 3,429 Times
Yup. I am also presuming that the seller was a sentient being capable of a cursory inspection, or had at some point ridden the bike. There is no chance that crack appeared coincidently.
Or covered it up.
See previous response.
Well, we have no idea what the OP paid, but the seller does have a moral (and probably legal) obligation to disclose known issues.
Liked 3,429 Times
Re-reading, the O.P. says "gave it a wash." We have no idea how dirty it was.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
That’s a shame. It’s a pretty cool bike
Genesis 49:16-17
Genesis 49:16-17
Liked 2,583 Times
I'm not so sure it's more than a scratch. You'd expect a crack there at the outside of the curve. May be where a stick got jammed between the frame? It looks bad, but that's an aluminum frame. I think the oil drip is a good idea.
Bikes: lots
Liked 2,932 Times
Quoted: 961 Post(s)
Liked 1,627 Times
OK... So whats the FIX!
External or Internal Sleeve?
External Support Bracket?
Cut out the tube and graft in a steel one?
Cover with a Decal and Ebay it... NOoooo!
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,213 Times
Remove all the parts and send the frame off to recycling. Then start looking for a new frame. There’s not much that can be done to aluminum frames for a long term fix.
Stuart Black
Stuart Black
Likes For cyccommute:
Find out if the seller was the original purchaser of the bike. Doesn't giant have a lifetime warranty on their frames and rigid forks for the original purchaser?
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
