For the love of English 3 speeds...
Quoted: 5779 Post(s)
Liked 2,576 Times
Another clue to correct or incorrect ball size is whee the cups it in the frame. Larger would widen the effective BB size, smaller would narrow it.
FB
Chain-L site
FB
Chain-L site
Quoted: 5 Post(s)
Looks to be a sporty version of the rod brake bike that was common for decades before becoming almost exclusively a bobby (police) bike.
I suspect that the top tube is horizontal and only looks sloped in the photo. The rims are the classic "Westwood" pattern that Raleigh produced for decades.
Probably right about the top tube, and also the ad says 24" wheels where I suspect 26" is meant.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Very old, rare, excellent condition. Can't speak for the tyre size but it's an exceptional old bike
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Finally - The Sun Makes an Appearance!
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
@DQRider, those are beautiful photos. I'm envious.
Gorgeous bike and scenery.
Our forecast calls for 73 on Saturday and 83 on Sunday! I can't wait.
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
Okay, it's torn apart again. I tried to take pictures, VV, but I wasn't able to take anything meaningful. Here's what I found.
1. As assembled, the spindle rotated smoothly with no play.
2. The long end of the spindle was definitely on the drive side.
3. No evidence of any cross-threading or galling of the threads. Everything screwed in and unscrewed smoothly, and were clearly meant to be installed where I assembled them.
4. The lock ring definitely only screwed onto the drive-side cup, which is weird, since both cups had the correct threads for the sides they were on...that is, the direction they turned to tighten was the same direction the respective cranks turned during normal pedaling. The lock ring was definitely threaded to be on the drive-side cup...again, no evidence of cross-threading or galling, everything in good shape.
5. If not for the lock ring, the chromed adjustable cup would be fine for a fixed cup on the drive side, and the painted cup on the NDS could be adjustable. However, the painted cup is definitely originally assembled as the fixed cup on the non-drive side. It's not chromed and shiny, but is dull and dark grey, inside and out.
6. I only disassembled things, I didn't do a test assembly of the spindle turned around and see what the crank clearance was like on the NDS cup, to see if anything was different.
7. Before I disassembled, I tapped a cotter in on the drive-side crank. The end of the spindle was flush with the outer side of the crank, like it should be. However, again, it was bound tight against the cup. Given the galling on the inner surface of the crank, I can only assume this has been a long-term issue with this bike. I wish I'd paid more attention to the fit of everything before I disassembled it the first time...I just assumed the tightness and grumbliness was due to dry, gummed-up grease (though there was plenty of that).
I might take you up on that offer of the crank, @Velocivixen. Let me mess with it for another day or two to see if I can figure something out, but I can't imagine anything I could do differently that would make a difference.
Quoted: 1299 Post(s)
Liked 103 Times
Inflate Hard
Inflate Hard
Liked 2,576 Times
OK, this is very straightforward.
How far in the fixed cup goes is irrelevant since the issue is strictly between the spindle, crank (located by the cotter) and cup. Moving the cup deeper into the frame won't change anything.
You have a few options on how to correct.
1- if it'll accept them, try smaller balls on the right side, which will move the spindle out a bit. 3/16" is likely too small, but maybe 6mm (available on the internet) may work and will buy you about 0.20mm.
2- move the outboard shoulder on the spindle out a bit as I described earlier (scroll back a bit). (still my favorite)
3- if you feel you can spare it and still have enough for a wrench, thin the outer wall of the fixed cup a hair by holding it flat against a belt sander. Good for at least 0.5mm which should be all you need.
4- if the hub of the crank can spare it, pare it back 1mm or so via the belt sander, or a die grinder. This may buy you over 1mm, but really depends on the crank/chainring weld.
Since it all went together except for the rub, you should only need 1mm or less. Any of the ideas above should give you that except for the 6mm balls. But if you're not comfortable with taking the 1mm from any one part, you can use a mix of 2 or more methods each each contributing a hair to get you the clearance you need.
If it were mine, I'd combine thinning the cup wall with moving the cotter position, since these are the two easiest (if you have access to power tools)
FB
Chain-L site
FB
Chain-L site
Liked 103 Times
Inflate Hard
Inflate Hard
Phyllo-buster
Liked 2,054 Times
Your BB assembly will always want to come loose.
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Both of them are all but useless, of course. They do help others see me, but they don't provide any illumination at all. I wonder if people had better night vision back when we weren't staring at screens all day...
Liked 103 Times
As bizarre as it seems, this is apparently the case here. The BB shell must have been threaded in reverse. I think your only option will be finding a spindle with an offset that will make it all work. Weird. Trying flipping the spindle for fun.
Inflate Hard
Inflate Hard
Wow, this is a strange mystery. So as I understand it the cups are on opposite sides than usual, and the lock ring is mated to the cup that is now on the drive side. Interesting.
Phyllo-buster
Liked 2,054 Times
You know, that is counter-intuitive. You would think that since the crank is moving clockwise on the right side and counter-clockwise on the left, RH threads on the right and LH threads on the left would be the way to keep the BB from coming loose. Apparently not, because BBs are always threaded the other way around.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Liked 103 Times
Wow, what a beautiful chainring and crank!! I thought those days were long gone, but this is one of the nicest I've ever seen.
Who ever came up with that design did a brilliant job.
Inflate Hard
Inflate Hard
Quoted: 3810 Post(s)
Liked 6,690 Times
The chainring and crank is probably the only part I like. If it's an updated Sports, @NormanF, where are the fenders? And the leather saddle?
Quoted: 147 Post(s)
Liked 8 Times
I wouldn't change anything about it: the design is clean, simple and timeless.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I previously mentioned a poor little ladies' Raleigh Sports that I found for a neighbor years ago and which she let rust in her yard. It's been in the garage for a year and my bride mentioned she'd like to have a handy bike to ride around the 'hood, so I fixed this up for her.
New tires, tubes and cables, lots of lube and a little cleaning. Subbed a nice Ideale saddle for the original plastic Brooks sprung saddle. Works fine.
Quoted: 294 Post(s)
Liked 9 Times
1968 Raleigh Superbe
Here's the '68 Superbe I bought a couple months back after a wiping it with an oily rag and lubing all bearings and hubs. Paid $50 for the bike and put another $75 in tires, tubes, saddle, fender bolts, and a sweet grip shift set and cables from from @YoKev.
Notice it has no dynohub, lights, or pump brackets. Sheldon said Superbes only "usually" come with that hub and lights, so I imagine this is how it came from the shop. Which is not to say said shop didn't swap everything to upgrade a return customer's Sport. I've seen other '68 Superbes without pump brackets. There's no sign they were broken off, so I assume the pump brazeon guy was sick in 1968.
Also notice it has a vinyl Raleigh mattress saddle instead of a B72 and no rack or saddlebag. This is solely because you forum members haven't kicked down.
Fun to tool around the hood in, but boy to I need a larger sprocket. What's recommended?
Hey; back in the '80s I didn't have a road bike. The club was doing a 'Metric Century' from Jamestown to Yorktown VA and back, which is 100K. So I scrounged around and put together an 'English' bike with 3-speed Sturmey-Archer coaster brake hub. No fenders or chain guard. I put a front caliper brake on it too. Tell you what, I made it, and I even passed a few guys on the way back. That is one bike that makes me wonder what happened to it. I got a new TREK 420T after that.
