Control set-up for drum brake on late 70s tandem?
I am working on refurbishing a late 70s/early 80s Mairag tandem that has an Atom drum brake, Mafac cantilever brakes, and two brake cables running from the right brake lever.
The left lever controls the front cantilever brake, and the right lever controls both the rear drum brake, and the rear cantilever brake. Is this a departure from the norm? From what I read, the drum brake was more typically controlled by the left lever, and both cantilever brakes were controlled by the right lever.
This bike had another change made to it at some point, with shifters moved from down-tube to bar-end, and a rather unusual (IMHO) cable routing for the same, so a brake control modification might have been done at that time.
How would you set up these brake controls? I am planning to return it to the normal set-up with the left lever controlling only the drum brake. But am very interested in other opinions about how to set these up, including any perceived advantages/disadvantages of each alternative. Thanks!
I'll post more about the bike in the "classic & vintage" forum in a couple of weeks (hopefully), when I have before and after photos.
This is not uncommon though it is difficult to balance the braking force of the shared brakes. More typically done is to control the drum brake with a friction bar end shifter. Or, some folks give control of the drum brake to the stoker in which case there are many ways possible to actuate it.
Quoted: 623 Post(s)
Liked 396 Times
My Tandem has the thumb shifter on the left inside of the drop bar. I can actuate it with my left thumb. I have bar end shifters and hydraulic rim brakes. This was the standard setup on Burley Tandems with drop bars. The Hydraulic rim brakes were a big improvement. Magura currently only makes the flat bar versions of the hydraulic rim brake.
