Help identifying unknown Raleigh
Unlike the other $50 raleigh from the other post, it got sold, this one is for $50 as well but has been on the market for 2+ weeks. Is it even worth it just for the frame, I have no idea what raleigh it is. Could be a Canadian version only.
Quoted: 1818 Post(s)
Liked 1,693 Times
That is a 1970's Raleigh Sprite. Would have been useful to see the drive side components. These sold new in Montreal for about $150
It appears to be a 5 speed. They were also produced in a 10 speed version
Person is offering me this bike as well $50 for both, the cabling looks messed up but looks better condition
Quoted: 790 Post(s)
Liked 1,760 Times
While a bit on the heavy side these were good basic hi carbon lugged frames that have very nice paint that seems to last and look good even after nearly 50 years. If your up for doing a bunch of cleanup and service work your self the price isn't bad either it wouldn't make sense if your going to pay some one else to do the work on this level bike. I would see if you can make bundle deal for both bikes for $75 but would be fine to get both for $100.
Quoted: 702 Post(s)
Liked 672 Times
Quoted: 702 Post(s)
Liked 672 Times
That Sprite would make a nice commuter but it looks like it will need a complete tear-down, head-set, bottom bracket, hubs, etc.. I've done it numerous times. It's time consuming but those old Raleigh's were built to last. I would offer $25.00 and then roll up your sleeves.
https://imgur.com/a/LvcvFV7
I got more pictures, since I got the bike for $25, the tires had no air and I forgot to bring a pump. so I rode it for 10-15 minutes but it wasnt 100% safe as the roads are terrible in Montreal. Surprisingly the breaks work fine but the friction shifter is jammed. I am unsure if I want to keep the original housing cables, they look like they have a soft texture and appear similar to tires also I cannot tell the size of the tires without having to take off the tires since there are no markings and I am unsure if that is the original stem or bar. The fenders have rust, not sure if I can save these?
Liked 1,693 Times
Tires on a Raleigh Sprite are 27 x 1 1/4. Can be difficult to find these days
Did you ride the bike with no air in the tires? That could destroy your rims
The brake self adjusters were seen around 1973-1974. However yours are not installed correctly
Quoted: 790 Post(s)
Liked 1,760 Times
Improperly installed setup safety adjusters seemed to be a standard OEM feature on mid 70's Ralieghs.
Quoted: 702 Post(s)
Liked 672 Times
Those rims are toast. You can update them to aluminum 700C as there is plenty of room to slide the brake pads down in the calipers.
I updated the bike and did all the maintenance and sold it to a friend for a $100, made $50 profit as I put $25 into it after buying it for $25. It got stolen from his apartment building lol!
If you ever see a raleigh with 27 wheel damco's and drop bars, you know it was stolen!
