Help Descending
Help Descending
I always have trouble descending at a fair speed. I tend to brake far too much and often will go slower on a steep downhill than on a flat just because I am concerned about stopping distance. I have had one crash in the past related to my rear weal getting caught on a log around a sharp turn. I just had a bad road rash but ive since been extra careful. i also always worry about an injury that compromises my career ( surgical medical specialty). I feel like I will never go really fast and thats probably the right thing to keep safe but I do want to have the minimal speed for enjoyment. Any tips? Also what do you do with bad roads? Thats something I always worry about is losing control on patches of bumpy road or bad pavement or potholes. (I tend to slow down tremendously for those sections)
Liked 2,943 Times
Find better terrain, be assertive of the conditions, apply common sense & logic for the speed set out for achieving.
would you run on thin ice while wearing just socks?
-Oh Hey!
-Oh Hey!
Likes For Troul:
Enthusiastic Sufferer
Bikes: 2015 Specialized Roubaix, 2014 Salsa Fargo, 2013 Trek Remedy, 2014 Cannondale Synapse
Quoted: 124 Post(s)
Liked 311 Times
On some hills, 80-90kph is doable and safe ; good vis, good asphalt, no driveways, sweeping bends...
On other hills, 40-50kph might be the limit
Depends on your skills / brakes / experience / balls
Expired Member
Quoted: 3653 Post(s)
Liked 5,391 Times
Recognize and accept your limitations.
Quoted: 18349 Post(s)
Liked 4,502 Times
If you're having fun, you don't need to blast down every hill. Also keep in mind gravel or sand on corners. Even a wet surface can be different than a dry surface.
You mention "a log" on a corner. Was that off road? Keep in mind that if you are on a trail, there may be other trail users. Bikes usually are required to yield or slow down for pretty much everyone else on a trail.
Quoted: 822 Post(s)
Liked 1,955 Times
With your profession, I would entertain private disability insurance or get on Zwift.
We all crash eventually.
Likes For CAT7RDR:
Quoted: 1062 Post(s)
Liked 665 Times
I don't really like fast descents either. It may be that I have a mild fear of heights. It affects me when I'm skiing too. I figure that there's nothing special about going fast downhill except for the enjoyment, unless you're in a race, which I'm not. So if it isn't enjoyable, then I don't feel bad about slowing down.
Likes For Gresp15C:
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Don't feel alone. I think most of us that haven't had a lot of experience with descents are leary of them. I also brake more than I probably should. Afraid I will
lose control I think. I am amazed and impressed how fast the TDF riders go down the mountain descents. I almost wet my pants just watching them
Likes For frogman:
Quoted: 955 Post(s)
Liked 1,619 Times
How closely you listen to that voice ridding on your shoulder should be tempered with how long it will take you to recover if that little voice is right.
For me I start slowing down before I even hear that voice.
Next time I fall I am grounded for good...
Likes For zandoval:
Liked 4,502 Times
Ok, not the TDF, but if the car wasn't there, the rider may well have had a tour of the woods.
And the riders successfully navigating the corner aren't hitting that corner at full speed, with or without obstructions in the road.
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 86 Post(s)
Liked 106 Times
An older riding buddy told me "you go 5mph slower downhill after you have kids." That was definitely true for me. I'm slowly increasing my speed and confidence descending, but I think I'm doing it more carefully now, with better technique, than I did before. Doing the same descents repeatedly helps, because it's easier to focus on technique when you already know the road and what to expect ahead.
Likes For nathand:
If you're fine with your speed, keep at it, if you want to build up dh speed follow someone faster than you and watch how they do it.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2564 Post(s)
Liked 5,595 Times
Go to YouTube and look up some videos on cycling descending, there are many illustrating good technique and theory.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Liked 4,502 Times
If you follow someone down a hill, make sure you have better brakes than they have. As well as a reasonably rigid bike. I hit about 50MPH on a descent on my old Colnago... it was downright scary. Not nearly as bad on the newer bike.
Likes For CliffordK:
climber has-been
Quoted: 3406 Post(s)
Liked 3,539 Times
Pick a descent near you and do it regularly.
As you get more familiar with road, your descending confidence will increase.
Ride, Rest, Repeat. ROUVY: terrymorse
Likes For terrymorse:
Quoted: 4227 Post(s)
Liked 2,488 Times
Just do whatever you feel is safe for your situation...There is no need to feel ashamed for slowing down and being cautious while descending.
Expired Member
Liked 5,391 Times
I brake on descents. I can't shake the notion that some suicidal squirrel or turkey might choose me as their gateway to the Everlasting. It might not be rational. I don't know that such an encounter at 35 mph would end better than one at 50 mph.
Likes For shelbyfv:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
Generally, the pavement around here is so bad, braking on a steep hill is pretty much mandatory for me. I don't find high-speed pothole slalom with cars behind me a lot of fun. I top out at about 35 miles per hour.
Likes For livedarklions:
Tragically Ignorant
Liked 9,095 Times
From a probability perspective, it's definitely rational that the greater the speed, the higher the risk, both in opportunity to avoid and in effects of the crash. 35 mph is, for me, the happy medium where I feel I can see obstacles ahead of me in time to avoid them. What I can't say is whether a slower max speed than 35 mph would be a better line.
Obviously, all cycling is a series of calculated risks, and it's not surprising we'd vary in what we consider acceptable risk, or that we'd be looking at different risks. We all have our own skills and weaknesses, and we ride on different roads for different purposes. I'm a bit colorblind, which means that some objects have less contrast from their background for me than they would for someone with normal color vision. I can't prove it, but I think that makes it harder for me to spot potholes and other road obstacles.
Quoted: 383 Post(s)
Liked 690 Times
I just looked over my gpx file from descending Washington Pass in the North Cascades National Park - about 15 miles of descent. I hit 30-33mph a number of times and applied the brakes to keep it controlled probably driven by the drop off to my right. But latter I noticed the odo showed about 42 and now looking at the gpx file, I hit 45mph. I see I tapered up from the middle 30's to that 45 and then back down again. That happened a few times in that stretch. While I could tell it was pretty fast which is why I looked at the odo, there was no drop off so I probably felt more secure or safer due to the terrain as opposed to the real speed. The road's surface is pretty good (as it is a major cross-state bike route) but it has its irregularities. And, no, I do not generally do those kinds of descents and not in years. It was a blast
Quoted: 383 Post(s)
Liked 690 Times
Oh, that reminds me of the time on a steep descent, my bike started to shimmy wildly. Braking only made it a lot worse. Finally, I squeezed my thighs against the top tube and got it under control. It was completely terrifying. A friend behind me was also terrorized.
Quoted: 18397 Post(s)
Liked 15,492 Times
I take blood thinners. An extra 5 or 10 mph isn’t worth it. On the road bike I’ll under good conditions I’ll top out at about 32. On the loaded touring bike more like upper 30s.
In 2016 I did top out at 43 on a long descent in Montana, but the conditions were optimal. Smooth road, no traffic, no tight turns and no forest around that could produce large critters. In 2013 I just missed broadsiding a deer that ran out of the woods during a descent in PA. Not something I want to repeat.
Likes For indyfabz:
oik01,
It's fear. I am also trying to get over a case of it after a bad fall last year that shattered my wrist. I used to descend with reckless abandon even well into my 50's. I have no fear of speed, at all, it's the crashing part that I fear now, for obvious reasons. I am s l o w l y gaining back my confidence, and acknowledge it will take time.
One thing that helps me is only think line, look ahead and don't fixate on just in front of you and anticipate turns better. Trust your brakes, whatever kind they are, and just to be sure.think about changing pads and give them a service, so you know they are right. Good luck, and stay with it and push a little on each ride.
I'm 63 now and look forward to the day I can scream down a hill like the 18 year old inside of me used to......
I'm getting close!
I'm getting close!
Likes For drlogik:
Liked 2,943 Times
Quoted: 6177 Post(s)
Liked 4,794 Times
Don't go any faster than you are comfortable with. Maybe ride with some others that might get you some experience finding the correct line and speed to take curves at while going downhill. But if you don't have confidence, then I'd say don't.
Speed going down a hill doesn't really affect my times or average speed for a ride as much as just being able to put out a more steady and slightly higher, but manageable power for all the ride.
