Poor Man's Parts Cleaner
Looking at a grease clogged derailleur that is in really good shape but gunked up. This was a nice video on parts cleaning if someone can't afford an ultrasonic cleaner. I have seen loads of palm sanders for cheap at garage sales.
Likes For etherhuffer:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
that's clever!!
I wonder if anyone who is a reloader and and a cyclist has tried parts in a brass cleaner
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3884 Post(s)
Liked 6,479 Times
He should do the same test with the solution and time, but without the sander.
WD-40 and paper towels are basically all I've ever needed for filthy bike parts.
Likes For SurferRosa:
Quoted: 753 Post(s)
Liked 737 Times
If I was trying to process lot of parts, I would use a tumbler to polish after running through an ultrasonic. Mechanical cleaning devises are primarily time savers, but ultrasonic cleaners will clean mechanically inaccessible surfaces like inside a chain link, or a carburetor. In practice I use OMS or WD-40 and a toothbrush and a rag/ paper towel. But with the tonnage of bike parts and old tools collecting around me I am seriously considering finding an ultrasonic cleaner and maybe a tumbler. If you look on Ebay there are folks selling parts in various mechanical states, but spotlessly clean and polished. I figure that's what their using.
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
IMO (and apparently, I'm wrong, and that's okay), I'd never use Calcium, Lime, Descaler solution on aluminum parts. Just my two cents. I use Branson degreaser.
It is a very clever idea, and I'll try it with a larger container. Sprockets above 26T cannot fully fit into my ultrasonic cleaner so I mostly scrub those by hand. This might be my work around. Thanks for posting.
Bob
Bob
Quoted: 1083 Post(s)
Liked 686 Times
The cheap ultrasonic cleaners from Harbor Freight, or similar ones from Amazon, work great for bike parts. Just bite the bullet and buy one - they come in handy for a lot of other things too. For example:
https://www.amazon.com/Industrial-Li...4-135149aa9081
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Cool!
Commence to jigglin’ huh?!?!
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Skip the WD-40 and buy a can of mineral spirits. The only difference is the 25% mineral oil in the WD-40 that you don’t need and that leaves a film of oil on everything you “clean” with it.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,217 Times
The whole ultrasonic bath thing for cleaning bicycle parts is pretty silly to begin with. There is nothing on a bicycle that needs to be that clean nor will it stay that clean.
Stuart Black
Stuart Black
I like the toothbrush approach cause of the reuse principal and, well I just like handling stuff and getting greasy!
I use the toothbrush approach with great success. The only thing I can't clean to my satisfaction is the inside of rear derailleur bodies.
Quoted: 3464 Post(s)
Liked 2,829 Times
Chevron 325 solvent was the go to. Unfortunately not available in SoCal any more.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
Clean is good.
Immaculately clean is more a statement about the cyclist than the bike.
Unless it is a bike for Show over Road.
Bikes: 48 Alleluia, 52 Blondin, 57 Cattaneo, 68 CNC, 55 Dujay, 46 Herse, 76 Singer, 48 LeGreves, 55 Metropole, 62 Holdsworth Cyclone, 49 Carpenter, 55 Condor, 65 Masi Special, 81 Sequoia, 76 Eisentraut, 72 Proteus, 60 Paramount, 77 Trek TX700, 82 Ross
Quoted: 79 Post(s)
Liked 137 Times
Ultrasonic cleaners
I would have agreed with this statement until about a year ago. For decades I had used mineral spirits, WD-40, degreasers, and lots of various brushes and rags. I was getting sick and tired of it. Last year I bought an ultrasonic cleaner to clean chains, as I was converting all my bikes to hot wax (a decision I'm very happy about). Now that I have the ultrasonic, I use it all the time for other parts and love it. No more breathing fumes, and little or no scrubbing. Saves time and does a better job. No more accumulation of stinky used mineral spirits.
Likes For Duke7777:
Freewheel Medic
Liked 2,195 Times
Respectively, I disagree. I'd replace my ultrasonic cleaner in a fast second if it stopped working.
Bob
Bob
Likes For pastorbobnlnh:
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
For aluminum parts in the ultrasonic cleaner, I've had great success using this: https://www.aircraftspruce.com/catal...s/09-00810.php
I usually fill the cleaner with water, and place parts and solvent in ziplock bags. Uses less solution, and keeps the debris contained.
The cleaner's heating option alone is sufficient is many cases, as any resilient grease wipes right off.
Likes For panzerwagon:
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
What about using an ultrasonic toothbrush...? Best of both worlds...
Quoted: 753 Post(s)
Liked 737 Times
señor miembro
Liked 6,479 Times
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
So I guess my old coffee can filled with 2" of Coleman Lantern Fluid is too basic...? Even if I swirl it?
Likes For Bill in VA:
Quoted: 4559 Post(s)
Liked 2,802 Times
I would just disassemble most rear derailleurs for proper cleaning. Usually it's the pulleys that need cleaning. The rest, meh, I rarely detail-clean the entire derailleur body with cotton swabs, etc., since they'll be dirty again after a couple of rides. So far with those I've disassembled the only tricky bit was winding the spring back up. But, sure, tossing a disassembled RD into an ultrasonic cleaner would be handy.
Main reason I'd consider an ultrasonic cleaner is for chains so I could resume waxing. I like riding waxed chains. I just don't like the initial cleaning to get the factory lube off the new chain. I'm in an apartment, so most solvents are out.
Quoted: 753 Post(s)
Liked 737 Times
Any one got a recommendation for an ultrasonic cleaner? The Amazon/chinamart units all look about the same. I was going to get a 10l one with mechanical control knobs in the hope that simpler is better for long term durability.
magic box
magic box
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
The time that this approach shines is for a restoration/renewal of a customer's vintage bike. They appreciate the showroom cleanliness, even if it won't last with the bike's eventual use.
