Can I mix different-brand hydraulic brake levers, calipers?
Bikes: 2000 Santana Sovereign SE; 2005 Co-Motion Speedster; Kona Kilauea with various dorky commuter accoutrements; Mercier Kilo TT fixie; Burley Fladbed trailer for groceries, bags of cement and the like.
Quoted: 95 Post(s)
Liked 85 Times
Must hydraulic-brake lever and caliper be the same make/model to work together, or can some be mixed?
Has anyone tried a hack combining different makes?
For example, could I connect a TRP Hylex drop-bar lever to a Shimano Saint disc caliper or to a Magura HS33 rim-brake caliper?
I can imagine there might be not only mechanical connection issues but also hydraulic-pressure/volume issues with some, or all, combinations. But it seems like if the specs were the same or close, one could hack a mix.
A goofy idea, perhaps. I'm only interested in knowing if it's possible, not if I'm nuts!
Quoted: 581 Post(s)
Liked 921 Times
Unless you can find someone who has successfully tried it, assume the answer is no, for all the reasons you listed.
And even if someone claims to have done it successfully, you don't know their definition of 'successful' - maybe the calipers actuate but you have to pull five times harder on the lever. Maybe 1mm of lever movement will make the wheel lock up.
Similar experiments have been tried with pairing the various styles of cable actuated rim brakes with levers made for both long-pull (V and disc) and short pull (caliper and cantilever) brake levers, and claim to have been successful, but only because they don't seem to know how properly functioning brakes are meant to work or feel.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
With hydraulics, it's all about piston diameters. If piston diameters match, exactly, I'd try it (only for myself and very carefully).
This is the exact analog of cable pull mismatches on V-brakes versus cantis or road calipers. And I see a lot of those on donations in our non-profit shop. Somehow they work and people ride them.
Quoted: 453 Post(s)
Liked 104 Times
Realistically, stick with one brand, and don't mix and match brands or types of brakes.
You have a few major issues you have consider
Fluid type, there are 2 main fluids used for MTB brakes, DOT and Mineral oil, SRAM and Formula uses DOT fluid, Shimano, Tektro (TRP) and Margura use mineral, all of these can (and do) have different spec fluids, different types are total incompatible, and even if they use the same basic fluid type may not be compatible with each other.
Open and closed systems, All current disc brakes use an open system (i.e. one with a reservoir) Magura HS brakes use a closed system (no reservoir) and are not interchangeable with open systems.
Stick to the same brand and type and you should have no issues with them working, although mixing older and new systems, say with Shimano and different spec hoses may result in lower performance than if all designed to work together; research & try at your own risk.
Currently there are no options for hydraulic drop bar rim brakes like Magura HS brakes which is what you appear to be looking for? SRAM has a hydraulically actuated rim brake (may not be currently available, research this) Magura used to offer HS-66 brakes (drop bar hydraulic rim) but these have been out of production for 2+ decades
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
First you would need to make sure they use the same type of oil. If you look at Hope RX4 calipers for instance they have different versions with different seal rings. Then you would need to make sure both brands fittings work on your hose. Finally you would have to tolerate whatever leverage you get
Genesis 49:16-17
Genesis 49:16-17
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Nope. Tried this a couple times w/ parts laying around at the shop. Doesn't work. It wasn't the piston size at all, it was the connecting hardware. One example: Shimano XTR caliper/hose to a Tektro lever. The hose was too small and neither the Shimano nor Tektro barbs/olives would seal.
Quoted: 792 Post(s)
Liked 1,494 Times
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
A number of people who like their Magura calipers but hate the crappy plastic POS levers swap them out for Shimano levers on their mountain bikes. “Shigura” setups supposedly work brilliantly.
So there is one combo that works.
Likes For Kapusta:
Bikes: lots
Liked 2,932 Times
Quoted: 4788 Post(s)
Liked 3,909 Times
Now if I could only do the same with my Prius. I learned to drive in a Willis Jeep. Never saw power brakes until I was well into my 30s. Every car I buy has more power than the last. TG for anti-lock braking.
Likes For 79pmooney:
