Looking to buy or rent an ISO fork disc jig
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
Last time I used one I borrowed from a local framebuilder here in Portland, Oregon, no longer building. If anybody can help, I'd much appreciate it.
Quoted: 4195 Post(s)
Liked 3,837 Times
I no one close by steps up let me know. I bought Starmichael's when I was last in Portland. Andy
AndrewRStewart
AndrewRStewart
Quoted: 103 Post(s)
Liked 144 Times
I have a Phrunt Shui in Seattle I could send you to borrow. I think it would fit in the small USPS fixed rate box for like $6-7 each way.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Liked 5,790 Times
Damn, missed hooking up with you!
Liked 5,790 Times
Liked 3,837 Times
Mark- I would be interested in your experiences with the Incepi after you used it. Andy
AndrewRStewart
AndrewRStewart
blahblahblah chrome moly
Quoted: 1172 Post(s)
Liked 2,566 Times
Question, I know it's not as good as a dedicated jig, but if you had the hub and brake, could you just put the hub in the frame/fork and clamp the brake onto the rotor, use that to tack? Maybe small quick tacks so you don't melt anything on the hub or the brake?
I know I did that on a tandem once long ago, like in the '80s, but I don't remember the brake brand or how well that method worked.
I guess if the brake has a piston on one side only*, then you might need to shim the rotor/hub connection while tacking, then take the shims out for use, so the rotor ends up centered between the pads when they're retracted.
* I don't pay attention to disk brakes, are they even made like that anymore? I'm guessing hydro brakes come in from both sides equally.
Mark B
Mark B
Likes For bulgie:
Quoted: 321 Post(s)
Liked 263 Times
Mark B
Mark B
Quoted: 3464 Post(s)
Liked 2,827 Times
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Any reportable info on using the Incepi jig?
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Randomhead
Liked 3,686 Times
You would think someone bought one since Eric/Incepi was the first to have a post mount front jig.
It works just as expected. Really easy to loosen, file and swing back to make sure the brake boss fits the blade. Also, unlike the flat mount front adapter, the post mount gives plenty of torch access.
Liked 5,790 Times
This is a fork I started on 5 years ago, just now getting around to finish it up. I forgot that the SL dropouts I used are stainless, I took a lot of time to carefully file the small attachment area on the disk brake bit for a snug fit as I had to use silver alloy filler just on this region. A careful perusal will reveal some repair work, which has been effected.
Likes For gugie:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Thanks for the report on the tool. I bought one a few months ago and haven't had a chance to use it yet. Hopefully that will change soon.
