Mini Pump Decision
Quoted: 200 Post(s)
Liked 65 Times
Mini Pump Decision
I want to buy a new Mini Pump. I will retire my Silca frame pump for two reasons. I want a pump with a hose, and I don't want to pay $19 with shipping for a difficult to find pump head gasket that will fit my Campy head.
I have narrowed my choice to two pumps. The Lezyne Road Drive and the Silca Tattico.
I like the Lezyne pump for the following reasons.
It comes in chrome color.
It's a little longer measuring 11 inches.
The mount is aluminum.
What I don't like is the fact that the screw on head often unscrews the valve cores.
What I like about the Silca Tattico is that the head won't remove my valve cores.
I should add that this pump will be used on a road bike with700 X 25 tires.
I would appreciate input from those that have used these pumps.
I have the Lezyne Road Drive, and I like it a lot. If you can comfortably carry the large size that you mention, the extra volume is nice.
When I install a new tube, or add it to the pack I carry on the bike, I check to see that the valve core is tight.
When I use the pump, I don't screw the head onto the valve stem super-tightly (not necessary), and I use the bleed valve to relieve the pressure in the line before removing the head from the valve stem.
So far, I have had no problems with accidentally unscrewing valve cores.
As a side note, I would add that the Lezyne Road Drive is Presta only. That's fine for my bike, but I also carry in my kit one of the Schrader to Presta adapters that are sold by Cantitoe Road. That allows me to provide a roadside assist to someone who's running Schrader valves.
Quoted: 200 Post(s)
Liked 65 Times
I gotta say, the Lezyne Road Drive feels like quality stuff to me.
My only concern was the unscrewing-the-valve-core-thing that I had read about, but in practice, that hasn't yet been a problem for me.
Quoted: 200 Post(s)
Liked 65 Times
I have the Lezyne floor pump. It is the older one in which the air cannot be bled. On occasion, the valve core does come off when I unscrew the head. Being that I am home, it is not too concerning.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I put a dot of low strength threadlocker on my removable valve stems. I also bought a second Lezyne pump for the in line gauge. If I did it again I’d get the Silca with the digital gauge.
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
I'll second (or 3rd, or 4th...?) a thumbs up on the Lezyne Road Drive. I haven't had any problems with it unscrewing the cores. If you have the space for it, get the largest one- I've got the medium, and it's fine, but the extra volume of the large would make pumping up easier. Also a shout-out to the Lezyne Mini Floor drive which I've got on my touring bike- slightly fussier to use (getting the head screwed on and off the base of the pump...), not as sleek as the Road Drive, but you can get it with a built in pressure gauge and being able to leverage against the ground/hold it with your foot makes pumping up pretty easy. And it has a reversible presta/schrader head.
Quoted: 2952 Post(s)
Liked 3,106 Times
Another vote for the Lezyne.
Likes For caloso:
Quoted: 506 Post(s)
Liked 638 Times
Likes For KerryIrons:
I've given some thought to going with frame mounting, and having the extra niceness of the Micro Floor Drive. I'm only running 55 psi, though, and it's not too hard to get there with the Road Drive.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 253 Times
I also vote for the Lezyne, I've owned my Road Drive for about 9 years and it's still working great. One word of advice on the Lezyne, make sure you get the longest one of the model you chose, the longer ones are easier to pump with, and they're not stupidly long either, nor weigh that much more than the shortest one.
I think the Silca Tattico is overpriced and heavy at 165 grams vs 110 for the large Road Drive. Since the Road Drive is about an inch and a half longer, it would, or should be easier to pump up to higher pressures than the Silca. And really, who needs bluetooth on a pump? LMAO!
Another mini pump that is liked by a lot of people is the Topeak Race Rocket HP, I own this pump as well. My opinion is that the Lezyne takes a bit less effort and strokes to fill my 25c tires than the Topeak does, it takes about 60 strokes more to get to 80 than the Lezyne does. So, for all around effort the Lezyne wins. Having said all of that, the Topeak is not a bad pump, in fact it's one of the better ones that I would rank 2nd behind the Lezyne. The problem with most mini pumps is that they simply cannot get up to their rated psi, and most would be lucky to get to 75psi without some sort of herculean effort! I sent back over a dozen mini pumps because they all failed to get past 75 psi. I once saw a test of 40 or 45 or so mini pumps, and the Lezyne road drive took the least number of strokes of all of them by a minimum of 50 strokes from the next best one!
I doubt there are more than a half a dozen pumps that can get to 90 or more psi, while some will scream they don't use more than 80psi you have to keep something in mind, those pumps that can't make to 90 makes them real difficult if not impossible to get to 80! And you want to avoid struggling to get air into a tire while out on the road. So Lezyne, in my opinion, and others here, as well as a test I saw, is the absolute best mini pump to have.
Likes For rekmeyata:
Thread Killer
Quoted: 3134 Post(s)
Liked 1,702 Times
I haven’t used the Tattico, which looks like a stick grenade or something, but I do have a few Lezyne Road Drives in service and find them to be very good pumps, largely in that they reach road pressures easily, and I only use the Medium size ones. I’ve not had problems with unscrewing valve cores, maybe because my cores are snug, or maybe it’s to do with the way I thread and unthread the hose…dunno. Anyway, I like the look of the Lezyne Road Drives better than the Tattico, and honestly, for as infrequently as I need to use the minipump, looks are like 50% of the value in owning one!
Quoted: 1397 Post(s)
Liked 1,876 Times
we have three mini/micro pumps - all work fairly well:
Topeak Microrocket AL (162 mm L / 65 g)
Lezyne Pocket Drive (149 mm L / 75g)
Birzman Mini Apogee (137 mm L / 78g)
Decades ago when I did a lot of road riding I used CO2 cartridges and not positive but I believe I used a Zefal Quick Fill or something like that
Liked 2,967 Times
I'd go Lezy if I didn't already have the Mini Morph Pump [with slightly hard to read Gauge] .
I can get to 80 psi with the MM, & I'd expect the lezy to get there with less effort. # HighPSIproblems
-Oh Hey!
-Oh Hey!
Quoted: 347 Post(s)
Liked 418 Times
I have a Lezyne Carbon Road Drive (142mm, 80g) that is currently my 'to go' minipump. I also carry a Lezyne CO2 with 1 cartridge.
A have a Berbeiri Carbon One (142mm, 55g) on the 2nd road bike.
I've been thinking of getting the Berbeiri 'NANA Ultralight' which is claimed to be 25g and 139mm has anyone tried this version?
Quoted: 4397 Post(s)
Liked 4,843 Times
I'm surprised there aren't more votes for the Tattico. It's a fantastic micro-pump and the quality is outstanding. It's particularly effective at high pressure too. The seals don't get hot like most normal pumps, so the effort required to keep pumping is far more consistent. It's almost as good as a full-sized frame pump.
Good round-up by Cycling Tips here:-
https://cyclingtips.com/2019/08/the-...ike-45-tested/
Tattico came out tops for high pressure road use, but I wouldn't bother with the BT version reviewed above. It's expensive and buggy. I returned mine for the standard one and just use a pocket digital pressure gauge.
Likes For PeteHski:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I have no experience with the Silca, but my Lezyne mini has been reliable for several years now. I always carry a valve core tool and give the core threads a tweak before and after using the thread-on hose. No issues.
Quoted: 6963 Post(s)
Liked 10,961 Times
I have the Lezyne pump, but no longer use it. I now own two Tatticos and one of them goes on every ride.
The Lezyne is lighter, but feels like a cheap toy in comparison to the Tattico.
One thing to note, though, is that Lezyne makes a wider variety of pumps...One of their pumps that is designed for high pressure road tires will get your 700-25 tires filled up with fewer strokes.
Quoted: 313 Post(s)
Liked 680 Times
I've got one of these also. A great little pump (on the very few occasions I've needed to use it).
Over the hill
Quoted: 998 Post(s)
Liked 1,204 Times
Maybe they changed the design? My Road Drive (bought late last year) has presta and schrader. It gets a little hard for me to pump at about 90-100 psi, but that's about as high as I run anyway.
It's like riding a bicycle
Likes For urbanknight:
So, thank you for that information!
I'll have to check to see exactly what hoses were supplied with my two Road Drive pumps. I've only used the thread-on Presta connection.
Edited to add:
OK, I checked, and both of my Road Drive pumps are equipped with hoses that have thread-on Presta on one end, and "slip fit" Presta on the other end.
I guess at some point Lezyne changed which style of hose came standard with the pump, and which was only available as a separate purchase.
Likes For John Valuk:
Liked 253 Times
Liked 2,967 Times
And yet, the Lezyne uses less strokes and less effort to put in the same amount of air as the Tattico does. The Tattico takes 193 strokes to get to 80 psi while taking more physical strength, while the Lezyne Road Drive long takes just 117 with a lot less effort. I think I would much prefer using 76 less strokes and less effort over using a 33 gram heavier "solid" feeling pump.
-Oh Hey!
-Oh Hey!
Liked 10,961 Times
