Upgrade derailleurs from Shimano 105 to Ultegra
Bikes: 1978 Masi Gran Criterium, 2011 Bianchi Sempre, 2018 Pinarello Gan K
Quoted: 5 Post(s)
I have a 2011 Bianchi Sempre which came equipped with Shimano 105 components. Over the years, I have upgraded the brakes, cassette, chainrings, and chain to Ultegra parts. I would now like to upgrade both front and rear derailleurs to Ultegra as well. So far I have not been able to find Ultegra 10-speed derailleurs online, only 11-speed parts. I have three (3) questions:
1. If I retain the 105 levers which are indexed for 10 speeds, will an 11-speed rear derailleur work? That is, isn't the travel of the rear derailleur per shift, determined by the lever?
2. How does the cassette size (i.e. 10 or 11-speed) affect the selection of a front derailleur?
3. Can someone recommend a source for 10-speed Ultegra components?
Thanks in advance.
Thanks in advance.
Quoted: 1818 Post(s)
Liked 1,693 Times
10 speed Ultegra has been out of production for quite some time, about 10 years, so anything you find will be new old stock or used. Ultegra 11 speed had 2 generations neither of which will work with your 10 speed shifters. Ultegra 12 speed has recently been introduced. Even if you could find them, 10 speed Ultegra derailleurs offer almost no improvement over 105. A friend of mine broke a 10 speed Dura Ace rear derailleur years ago and had to replace it with a 105 rear derailleur. He told me that the 105 derailleur worked just as well so he never bothered to upgrade it
Likes For alcjphil:
Quoted: 1561 Post(s)
Liked 1,734 Times
Thanks in advance.
2. Cassette size mostly does not affect the FD
3. Ebay.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
To elaborate the shifter and derailleur work with a specific cable pull ratio, not just the fact that the shifter has 9 clicks or whatever. As drivetrains have added gears the amount of cable a derailleur pulls for each actuation of the shifter has changed. This is partially due to how much cable the shifter pulls and the geometry of the rear derailleur body.
Likes For cxwrench:
Quoted: 836 Post(s)
Liked 1,061 Times
As alcjphil mentioned in post #2 you're going to find it near impossible to find new Ultegra 10 sp derailleurs and I would agree if your 105's are working just keep them, not much, if any, difference in performance but maybe just slightly heavier. Of course, there may be a new 10sp Ultegra floating around the web somewhere that's not $200+ with any luck and there may be some good used ones on Ebay but always a gamble when getting used. Note that you can use either 6600 or 6700 Ultegra derailleurs as they have the same pull ratio. I own a 6600 Ult groupset myself and when my derailleurs and shifters wear out I'll have to get aftermarket stuff to work with the old 10 sp pull ratios. Shimano has kind of left us without many options for 10 sp components of that era.
Quoted: 5 Post(s)
Thanks for your reply. My Pinarello has 11-speed Ultegra components and its shifting is significantly smoother than the 105 Bianchi. That is why I am considering an upgrade.
Quoted: 1397 Post(s)
Liked 1,874 Times
the difference is often small - sometimes different pulleys and less weight
Quoted: 2026 Post(s)
Liked 1,096 Times
That's my experience also. I have a 10-speed Ultegra RD-6700 on one bike and a 10-speed 105 RD-5701 on another bike and the shifting is identical. If your 105 isn't shifting well, I agree with sch that a cable/housing upgrade is likely to fix it.
Quoted: 5 Post(s)
Thanks for your reply. I've changed the pulleys, cables, and chain. The cassette is relatively new.
Quoted: 3504 Post(s)
Liked 2,923 Times
EDIT: Not BIN, just opening bid.
Liked 2,923 Times
Of course, there’s absolutely nothing wrong with wanting to upgrade components “just because.” That’s part of the fun of this hobby/sport.
Liked 1,874 Times
the 10 spd Ultegra RD should weigh less than the 105 RD
example : 11 spd 105 / 5800 GS RD weighs 245 g -- Ultegra / 6800 GS RD weighs 209 g
