Tubeless Tire Question
One of my Topstone has tires that are set up tubeless. The bike has been on my smart trainer for the last year or so without have being ridden outside. I am going on a trip at the end of the month and would like to take this bike with me. What do I need to do in order to get the tires ready since the have not been rotated in a year. Thank you.
Quoted: 506 Post(s)
Liked 638 Times
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I would deflate the tire, remove the valve core, and dip a dipstick into the valve to see how much (if any) liquid sealant is remaining in the tire. If it hasn't been topped off in a year, I'm guessing it'll be pretty dry in there. If so, add sealant through the valve, using either the Stan's drip bottle or a plastic syringe. You want a couple of ounces of liquid in the tire. Once dispensed, replace the valve core, tighten it up, and inflate. Spin and bounce the tire a bit to distribute the sealant, and you're good to go.
Here's a video of the process, if that isn't clear.
https://youtu.be/3p6v0KMxWDc
Quoted: 1461 Post(s)
Liked 1,481 Times
My tubeless setups all go flat after a few months of inactivity.
If I were the OP, I'd definitely remove the tires from the wheels, and clean out the old/dried up sealant first. It's likely to be one big glob in there if the wheels have been sitting for a year without moving.
After doing that, I'd clean up the wheel, check the tape job to make sure it's still good, then re-install/seat the tire and add new sealant.
Likes For msu2001la:
