Fat Guy Wanting a Nicer Bike
Likes For phughes:
I weigh 290 at 6'1" yes I am hefty. I built my own wheels, Velocity Atlas 36 spoke laced to Shimano hubs. They hold up fine, dont go out of true. For tires i run 32mm Gatorskins. I venture onto some rough gravel also.
Bike choice is a Gunnar Crosshairs. I like steel bikes.
My other bikes are a Surly Karate Monkey and a Specialized Fuse aluminum.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
I can say this from experience as a former 300+ pound person. When I was heavy, the issue with me and drop bars was a big deal because of where on my body I was storing the fat. This varies a lot from person to person. I agree you OP shouldn't let anyone tell OP what will or won't work, but should definitely try riding a drop bar before buying one.
Likes For livedarklions:
Friendship is Magic
Bikes: old ones
Quoted: 26382 Post(s)
Liked 10,362 Times
...for the issues you describe, I can't suggest much more than learning more about wheels and constructing them. A modern box section alloy rim with at least 36 spokes, laced to any sort of decent hub, with the spokes tensioned to maximum recommended tension for the rim, and well balanced as to equal tensions, ought to work. I'm riding on a variety of wheelsets like that here, on a number of different bikes, mostly on 700x25 0r 28 tires, sometimes on 27"x1 1/8 or 1 1/4. And I'm averaging in the 250-260# range, so not a good climber. My wheels seem to do OK, at least the ones I build myself.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 365 Post(s)
Liked 457 Times
Just buy a WABI Thunder, have 32/35c tires spec'd and enjoy yourself more than you thought you could.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Quoted: 822 Post(s)
Liked 1,955 Times
The only thing I can add, after popping multiple spokes on a few different rear wheels and bikes, is I learned to lift myself off the saddle when going over rough tarmac, gaps, expansion cracks and other jarring surfaces.
Likes For CAT7RDR:
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 564 Times
Jamis Coda S2 ... broke numerous spokes on both rear and front wheels, after replacing them (and subsequently breaking them) I just bought a new wheelset. Fast-forward to two days ago and I realized one of my spokes while riding was super loose. I took it to the shop and they're going to do a tune on it, but my bike is down until the 28th ...
For wheelsets, check out Velomine for some options:
https://www.velomine.com
I must have dyslexia or something. I originally read "Nice guy wants fat bike."
Likes For Daniel4:
Quoted: 1034 Post(s)
Liked 1,289 Times
You may want to consider a touring bike. The Surly Long Haul trucker can haul up to 300 pounds according to Surly. I have hauled a total of about 270 pounds on my Long Haul Trucker with no issues. That isn't normal for me, but I have done it.
New rims for your current bike would work well though. Welcome to the forum, and enjoy the ride!
Tragically Ignorant
Liked 9,095 Times
That's good advice for any weight rider (unless you're on a recumbent, lol). A lot easier on your butt as well.
Tragically Ignorant
Liked 9,095 Times
B.U.F.F. I'm pretty much an ignoramus when it comes to wheels, but given your screen name, I suggest you get some B-52 imagery on your bike.
Welcome to the Forum! Let us know what you end up doing and how it works out. Have fun.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Serious option, tandem bike wheelset. Should easily work for you.
Also look at a cyclocross or gravel bike instead of pure road bike for tire clearance larger than 28. Almost a road bike in geometry but can fit often 38’s.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I like the idea of getting gravel bike, the 40 mm wide tires are quite luxurious. I still try to ride light by missing the potholes, rough spots, don't jump curbs or do bunny hops or stand on the pedals if any of these things can't be avoided. As you get more confident with the wheels on the bike, you can start going to some thinner tires and eventually get a second set of wheels. I'm not sure how these wheels will stand up to my weight (200 lbs) since I haven't put too much mileage on them but they have stood up to my riding for the last few months.
If you are bored because your bike is in the shop, then you really need an additional bike. I am constantly working on swapping gear from bike to bike so one of my bikes is normally isn't in riding condition but I normally have a standby bike so I am always able to ride.
With a mighty wind
Quoted: 1086 Post(s)
Liked 858 Times
Get a steel gravel bike, use 23-25 internal width rims, 32-36 holes, brass nipples, light purple locktite on the threads, and handbuilt by a solid builder. Ride 38-45mm tires.
The final product should be 22-23lbs. It’ll be a tank. And really really fun.
For perspective, it’s about 6lbs heavier than a super light carbon on top or carbon beast that you absolutely will destroy.
So many options on the market but in your position, I’d probably go for the Surly Disc Trucker people have been mentioning bit most any bike that fits what I just mentioned will be great.
Liked 1,289 Times
I ran across this today while looking for somehting else. Keep in mind though, evidently a lot of manufacturers include the bike weight in the total load capacity. https://www.thebikeseat.com/bicycle-load-capacity.html
